The attached photo shows the only wire strippers I have that can be used with thin wires. Hopefully, it can help for a size comparison.
Of those tools, the one on the left is my most recent purchase, it can be set for 30 AWG Kynar, and works fine for that, but I bought it for 0.6 mm diameter solid-core wire (for solderless breadboards etc). It can also be used to snip wires.
The OK/Jonard tool hasn't been used in years (I found it in the back of a tool drawer just now); I think I damaged it at some point, but I've not retried it.
The Knipex 12 12 02 is physically massive in comparison to the others. It's the only tool I own that can reliably strip 30 AWG PTFE stranded wire as well as a range of other wires, but it has that size/weight disadvantage; it isn't a very general-purpose tool as a result.
In the other photo, there's a close-up of some wires stripped with the Stripmaster Lite. The red wire is about the thickest copper wire supported by the tool. The black stranded wire is 10/0.1mm. The thick blue insulation wire is silicone wire, and the thin blue is 30 AWG solid-core Kynar.
There's a circuit board in the photo, which shows the use-case where one end of the wire is soldered first, and then the other end is cut and stripped. I placed it between pin headers, to try to make it realistic since boards will have other tall components on them. I was able to comfortably strip the wire down to 19 mm of insulation remaining, although I could probably reduce that to 17 mm or so with more creative positioning of the tool. So, I think 19-20 mm is comfortably realistic in that scenario.
To be honest, I really like the Stripmaster Lite. It's the only pair of wire strippers I use regularly, since it will do the thin solid-core Kynar wire extremely well, plus the 10/0.1 mm normal PVC stranded wire for general PCB connections when prototyping. Those are the two wire types I use regularly.
Since I don't wish to strip thicker solid-core wire with the Stripmaster tool (I don't know if it would support it, but I don't want to risk damaging the blades), for that I will just use the lower-cost Knipex tool on the left in that photo (model 11 82 130) which is fine, but probably there are better and even more lower-cost tools around than that. Still, that tool is fine for my purposes, and seems durable.
