Thanks everyone for taking the time to go through the design, really appreciate all the input!
1. Filter Simulation & S-Parameters (@BigBoss, @G0HZU)I should have clarified this upfront: the notch filter was designed and tuned in
Qucs-S using vendor Touchstone (.s2p) measured models for every component (Murata GRM series capacitors and Coilcraft CS/LS series wirewound inductors) rather than ideal parts. The nominal values and resonant tanks already compensate for component ESR, parasitics, and Self-Resonant Frequencies (SRF), which is why simulating with ideal lumped elements at these exact values shows a distorted response. I'm running sensitivity and Monte Carlo sweeps next to check notch depth stability against standard component tolerances.
2. Tuning Strategy (@G0HZU, @BigBoss, @rf-fil)Thanks for the trimmer suggestions (
@BigBoss,
@rf-fil). Given the Q degradation compared to C0G/NP0 ceramics at this frequency, I'll go with
@G0HZU's idea instead: adding secondary parallel pads across the critical tank capacitors for bench "select-on-test" trimming with high-Q discrete caps.
3. Inductor Coupling & Spacing Question (@G0HZU, @rf-fil, @tchicago)Ground under series line (@tchicago): Noted on the parasitic capacitance risk, I'll review the ground plane relief under the series CPWG pads/traces.
Coil coupling question (@G0HZU,@rf-fil: Since I'd prefer to avoid adding individual shielding cans if possible: would increasing the spacing between filter tanks (e.g. 4–5 mm separation with continuous ground between them) provide enough isolation or would shielding cans still be strictly necessary in practice?
4. Quick question on the R19+L8 branch (@G0HZU)Regarding the DC block on the R19+L9 branch: I tied it straight to GND, my assumption was that since pin 1 is just RF-IN and the DC supply comes in through pin 3, that branch didn't need isolating. Could you help me understand why grounding it there without a DC block cap would bias off the PGA-103+? Trying to understand the internal bias behavior better.
5. PGA-103+ Ground Vias & LDO Thermals (@G0HZU)Ground vias: Good point, the PGA ground paddle already has 6 vias (0.2mm drill), trying to minimize solder wicking, but I don't have many around the footprint for a low-inductance RF ground return. I'll be adding more around it.
LDO dissipation: The LDO tab (5V net) has a dedicated top copper polygon for heat spreading, I'll size it once I lock down the final input voltage for the ~100 mA.
Solder mask relief: Good call on leaving that flexibility for shields later, I'll keep it in mind depending on how testing goes.
6. Output Stage (@rf-fil)Swapping the discrete output bandpass filter for a dedicated 137 MHz SAW filter is a great suggestion. I`ll look into available parts and footprints now.
7. Chambering & Input Protection (@dobsonr741)Good point on chambering, I'll look into splitting the Cauer notch, LNA and output BPF into three separate shielded compartments instead of just spacing them out. On real component sims, yes, same as mentioned above, all discretes were simulated using vendor .s2p files rather than ideal models, so SRF/ESR/Q are already accounted for. Input protection is something I'd missed completely though, antiparallel diodes at the input plus a switchable attenuator both make sense. I'll look into low-capacitance diode options that won't mess with the notch filter's input impedance.
Thanks again to all of you, this has been super helpful for a first RF design.
