How do I make a balun?
I live in Copenhagen Denmark and want to receive DBT TV from Malmo Sweden and I have a .3 meter long indoor tabletop log-periodic antenna(mounted outside on the back porch), but all Swedish TV signals are very weak, and even with an adj. gain antenna preamp (up to 30db adj. but has no LTE filter), I can only see a few hours of one Malmo TV station per week.
I have found that no satellite TV or local TV cable-tv services do not offer but only 3 of the 8 possible Swedish freeview TV stations, so that is not a good option.
The local Copenhagen transponders give a strong signal and I have no trouble receiving them, but their broadcast is of little interest to me! A coat-hanger attached to coke cans works well for local signals!
Due to restrictions on what I can attach to my back porch of my apt. building, I cannot mount anything but a satellite dish or a small non-obtrusive antenna on my tiny back porch.
It may be that I am only receiving one strong Swedish TV station, but only occasionally, that is about 30-miles away because of atmospheric skip and the situation seems hopeless, but I have not yet explored all my options
The antenna has no balun and when I tried inserting a standard TV 300-ohm line to 75 ohm balun to connect to the preamp the signal was gone completely.
I am connecting the front of the antenna directly to 75-ohm coax and making connections by tightly winding many turns of silver plated 32AVG stripped wire-wrap wire around the front most element pair, near the center boom (which is plastic).
Surprisingly, when I bought a mushroom Yagi antenna of 4-ft length, there was no reception of any but the local Dan channels, so this desktop antenna is the best solution so far for what I have to work with.
Reception was much better before LTE/4G service started many years ago. I have found there is now a 20-DB DVB antenna preamp available with LTE/4G filter, but I haven't tried this option yet.
If I was to purchase a LTE/4G filter I would still need to build a balun to connect coax directly to the antenna, would inserting a filter before the preamp help with such a weak signal?
I have some discarded TV/Internet routers that multiplex TV and broadband internet on the same 75-ohm coax cable, and I see within the RF shielded box connecting directly to the 75-ohm F-connector a 3-4mm ext. diam toroidial core used to match the cable to the broadband internet processing chip section of the router.
Please, can some rf guru's help me, give me some help in using this small ferrite core to wind a balun to interface the antenna to the 75-ohm unbalanced antenna preamp?
BTW, I am very experienced in electronics design and have the ability make my own PCB for circuits, but know only so little about RF.
