Author Topic: high power mixer?  (Read 1447 times)
Offline CopperConeTopic starter
  • *knock knock*
high power mixer?
« on: July 09, 2018, 04:21:25 am »
Can you mix high power signals? Like if you had two high power signals you want to efficiently mix without amplification afterwords.
Offline helius
Re: high power mixer?
« Reply #1 on: July 09, 2018, 05:16:08 am »
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #2 on: July 09, 2018, 07:34:42 am »
Nonlinear mix, not linear superposition (audio mixing).
Here's an example at power: http://davidberning.com/technology
Only used as a DC transformer, but that's one possible application of a mixer: synchronous modulating and demodulating at a driven clock frequency.
I don't know of any general method for high frequencies.  At low frequencies, it's just ordinary power electronics.
Seven Transistor Labs, LLC
Online Wolfgang
    • Electronic Projects for Fun
« Reply #3 on: August 08, 2018, 12:02:13 am »
Do you want a "transmit" mixer ?
What frequency range should it have ?
What are the power levels ?
Is efficiency an issue ?
