I also had many cases with damaged LNA, so I bought a couple for replacement, it appears that they are fake, consume twice more current and heating a lot, but they working and I can resolder it when next one will be damaged.
I think the main issue why it is damaged is a grounding issue. Some of devices don't use third terminal for ground on mains socket and it leads to a high AC potential on it's GND pin and enclosure. For example official Raspberry Pi power supplies don't have grounding terminal and have such issue.
Usually PSU which has Class II Equipment label has such issue.
If you're using equipment with such PSU (label 2 without ground terminal), you're probably seen sparks during hdmi or other connectors connection.
I suspect that damage happens during connection, when signal line appears connected before GND pin, so it leads to about 100 V AC voltage on the LNA and it leads to damage.
The current is within safety limit for human, but not for LNA...
Once I even damaged USB sound card dongle due to this issue with official Raspberry Pi power supply. Just because it was connected to a power amplifier with Class I power supply. Usuall my RPI is connected to hdmi display which is also uses Class I power supply, so it had ground through hdmi cable and I was connected power amplifier on the fly with no issue. But when I do it when hdmi was disconnected, it leads to sound card dongle damage, because RPI had high AC potential on it's GND.
This is even more important if you're using grounded antenna tuner or antenna.
