Author Topic: NanoVNA Custom Software  (Read 1011344 times)
0 Members and 13 Guests are viewing this topic.
Offline gf
Re: NanoVNA Custom Software
« Reply #2075 on: April 30, 2022, 08:07:15 pm »
on lower 400kHz always used gain 0 in any case for all (on enabled AGC)
Not remember why i use this (possible need enable, but at this moment i not have free time for tests).
I'm surprised that gain 3 is used at all below 300 MHz, if it cannot be calibrated:
... but in less ¬300MHz range not possible calibrate Gain 3 due to overflow in any case.
Offline joeqsmithTopic starter
« Reply #2076 on: April 30, 2022, 08:09:19 pm »
Shown with the 100uOhm and 1mOhm resistors using an average of 10 and gain of 3.    I think this is the first time I have been able to discern between these two parts using the Lite.
Offline DiSlord
  • Country: ru
« Reply #2077 on: May 01, 2022, 07:52:02 am »
LiteVNA test firmware
I enable AGC in all range for tests
This fw also contain new traces for S21 measures (Series R/X and Shunt R/X and Q)
Small improvements for LCD draw and SD cards
« Reply #2078 on: May 01, 2022, 01:19:34 pm »
Just loaded.  It appears to be for the small display.  I'll go ahead and run it anyway.
Offline DiSlord
  • Country: ru
« Reply #2079 on: May 01, 2022, 02:25:53 pm »
Archive contain 2 firmwares LiteVNA 64 for big and LiteVNA 62 for small displays
« Reply #2080 on: May 01, 2022, 02:50:19 pm »
I don't think I ever sorted out where you have them archived.
https://www.eevblog.com/forum/rf-microwave/nanovna-custom-software/msg3928550/#msg3928550
https://www.eevblog.com/forum/rf-microwave/nanovna-custom-software/msg3928592/#msg3928592
https://www.eevblog.com/forum/rf-microwave/nanovna-custom-software/msg3930395/#msg3930395
I never joined that groupio mail list for beta testers.  Is that the only way to gain access?
Anyway, the new firmware does appear to correct the AGC limitation.   Shown with a 1mOhm, 0.1mOhm and short.   Graph is S21, not resistance.   Not anything useful below 50kHz but certainly improves the lower region.
Offline gf
« Reply #2081 on: May 01, 2022, 09:11:52 pm »
If there is no error in my calculation1), then 1mOhm shunt has S21 of -91dB, and 0.1 mOhm -111dB.
Noise floor is still too high for that use case. Ideally, you'd rather need a noise floor of say -120dB, or even lower.
You could try to increase the averaging further to 100x or 1000x. Rather reduce the number of points, if it becomes too slow.
But even if you can further reduce the noise floor, I wonder whether the gain calibration will be accurate enough at such low levels.
The discontinuity at 400 kHz is quite large, too.
1) https://cds.cern.ch/record/1415639/files/p67.pdf, page 88, "3. shunt admittance", for Y1=Y2=1/50, and Y=1kS and Y=10kS
« Reply #2082 on: May 02, 2022, 01:23:34 am »
Math seems in the ball park.
Some time ago when I made these two standards and transformer, I used my higher end equipment.   I am using them with the Lite only for a fringe case.   The original NanoVNA did a much better job of it.
10x average takes a very long time to run.  One sweep maybe 6 minutes or so.  100X about an hour per sweep.   Compare with a few seconds on my vintage VNA.
« Reply #2083 on: May 05, 2022, 11:59:40 pm »
Working on a rotor to make 3D radiation measurements.
« Reply #2084 on: May 08, 2022, 01:19:44 pm »
5 deg resolution.
« Reply #2085 on: May 10, 2022, 12:15:16 pm »
I was wanting to try something a little more directional on the new 3D mount and decided on putting a simple antenna together with a discarded bean can.
https://jacobsalmela.com/2013/09/07/wi-fi-cantenna-2-4ghz-how-to-make-a-long-range-wi-fi-antenna/
The can I used measures 109mm x 73mm.  From their drawing, this can should be good for 2.1GHz, or a wavelength of 143mm.    After construction, the Lite showed very poor SWR so I added a few stubs to try and tame it.
« Reply #2086 on: May 10, 2022, 12:21:37 pm »
CAN9
Running the can at 4GHz.
CAN10
Comparing the 4GHz radiation pattern with running the same setup at 5GHz.  It looses all directivity.
CAN11
Comparing previous data sets with the same setup at 2GHz (1.94GHz).
CAN12
Looking at the 2GHz data in 3D.
« Reply #2087 on: May 10, 2022, 12:27:58 pm »
CAN13
Moving the bean can further away and running a much higher resolution sweep.   Next time I have beans, I'll lengthen the waveguide.
This was a paper I had read on making these measurements.
https://www.ets-lindgren.com/WhitePapers/APM.pdf
« Last Edit: May 10, 2022, 12:38:19 pm by joeqsmith »
« Reply #2088 on: May 11, 2022, 11:44:07 am »
Using the newer 3D plotting with the wire frame disabled.   This scan was taken at 2 degrees or 16,200 data points.   Imagine taking that by hand.
Next step is add some sort of auto align and measurement readouts.  Maybe a basic field calculator.
« Reply #2089 on: May 13, 2022, 05:08:00 pm »
Rather than having an auto alignment for the antenna, I just rifle through the data to find the peak and consider that head on.   Showing calcs for the half power beam width.  Both azimuth and elevation are calculated.  For the front-to-back ratio I plan to use the BASTA standard.
Without a chamber and reference antennas, it's more just for the fun of it.
http://www.mobi-antenna.com/uploadfiles/2017/07/201707241212321232.pdf
Offline metrologist
« Reply #2090 on: May 13, 2022, 05:23:58 pm »
Motors for rotor system.
Would you be willing to create a block diagram of your system setup?
« Reply #2091 on: May 13, 2022, 06:16:30 pm »
If you read those few links I had posted and watched the video, it should have been fairly clear but let me try and expand on it for you.
I have the PC tied to the LiteVNA using USB.   I have two M-Drive motors as my document describes fitted with a gear drive.   These are configured for multi-drop on an RS-485 bus.  One motor is used for the azimuth (horizontal) the other for elevation (vertical).   There is a separate power supply for the two motors.    The RS485 to USB adapter is connected to the PC as well.    The LiteVNA has two ports.  Port 1 connects to the AUT (antenna under test) and Port 2 to the reference antenna.    The LiteVNA sends the signal out Port 1 to the AUT.  The signal is then received by the reference antenna on Port 2.   The software tracks the signal strength while it moves the antenna.
Currently, the software starts by pointing the AUT downwards and sweeps the azimuth from 0-360 degrees.  The elevation is then set to the next angle and the process repeats until the elevation has swept from 0-180 degrees.   This gives us our full sphere.
I made a quick block diagram for you but it isn't very helpful as there really isn't much to it.  There are lots of papers and videos on this subject if you are interested.   Maybe the following videos will help.  I hate to guess what that whole setup costs.
Block diagram shows PORT1&2 swapped to my current setup.
« Last Edit: May 14, 2022, 12:16:56 am by joeqsmith »
Offline metrologist
« Reply #2092 on: May 13, 2022, 07:08:41 pm »
Thanks Joe
« Reply #2093 on: May 14, 2022, 09:11:49 pm »
Shown is the Vivaldi I attempted to copy from our friend who was experimenting with RADAR.   There is also a poorly constructed dipole along with a fresh can of pork and beans.  Used the Dremel tool to cut off the bottom of the can and removed the ring from the top of the original can.  After that, it was easy enough to solder together.  I moved the mounting bracket to center the antenna.
The dipole sort of radiates like we would expect.
« Reply #2094 on: May 14, 2022, 09:14:37 pm »
The Vivaldi compared with the dipole.
« Reply #2095 on: May 14, 2022, 09:21:41 pm »
Showing the new bean can antenna pointing downward compared with the Vivaldi and dipole.  Stubs had to be retuned after extending the waveguide.
« Reply #2096 on: May 14, 2022, 10:46:27 pm »
Showing the SWR after extending the waveguide and adjusting the stubs.   It seems to improve the side lobes.
Offline FPSychotic
« Reply #2097 on: June 24, 2022, 02:02:24 pm »
I'm not able to make work the nanoVNA solver lite/v2 +4 for the liteVNA.
Anyone have it running in windows 11? I really having a bad time trying to understand the issue, no idea if it is the software that just won't run as it is deprecated, it can run but I had something wrong with the National instruments runtimes that Im unable to understand even what they are, what they do , just unable to make it work.  Other softwares works. I don't want disturb, sorry if this not proceed.
« Reply #2098 on: June 24, 2022, 02:51:53 pm »
I don't have Windows 11 installed on a PC to try it.
https://forums.ni.com/t5/NI-Package-Manager-NIPM/Does-LabVIEW-software-support-on-windows-11/td-p/4177747
Windows 11 was announced long ago; and there have been many Windows Insider releases to allow companies like NI to port their products such that they would be fully functional by the time Windows 11 started deployment to user systems.
Telling me that NI is "targeting support in 2022 H2" is basically telling me that they failed to support their user base. The majority of software companies worked hard to get Windows 11 support available contemporaneously with the release of Windows 11. Why didn't NI?
Until I actually try it, I wouldn't trust what I read on the internet.
Windows ships with a lot of software.  When Notepad fails to run with a new release, they have a big problem.
Talking with a friend who has ran some basic tests with the 64-bit LabView on 11 and no problems.   I would imagine he's done a decent shakedown.
« Last Edit: June 24, 2022, 03:17:54 pm by joeqsmith »
The following users thanked this post: FPSychotic
« Reply #2099 on: June 25, 2022, 01:16:09 am »
I would start by installing the drivers and making sure your PC recognized the VNA.  I use the standard drivers with Windows 10.  If 11 doesn't find it, you need to locate proper drivers.  If that works, then you need to install the latest the National Instruments 2021 SP1 64-bit runtime and NIVISA.   Then you will need the 64-bit sound dll.  Don't expect anything to work if you are mixing 32-bits and 64.  If you still can't get it to work, then I suggest going to one of the open source applications.  Actually, you may want to just start there.
