Author Topic: VNA test jigs and fixtures?  (Read 3730 times)
Offline cdevTopic starter
« on: July 08, 2020, 02:49:47 am »
I would like to build some test PCB boards for testing individual compnents in a controlled impedance way, testing self resonsnce, etc.
 Also, how you made them.
Offline Jay_Diddy_B
Re: VNA test jigs and fixtures?
« Reply #1 on: July 08, 2020, 03:22:57 am »
You can the board I use in this picture:
In the top left of the board, there are three 3 \$\Omega\$ resistors in parallel, This is to make a low inductance 1 \$\Omega\$ standard.
This is from this thread:
https://www.eevblog.com/forum/projects/high-bandwidth-current-injector-for-impedance-measurements/msg3026052/#msg3026052
Also look at this thread:
https://www.eevblog.com/forum/projects/shunt-measurement-of-capacitor-esr-and-resonance-frequency-with-a-vna/
Forum member, graybeard, does some component measurements with a VNA.
Regards,
Jay_Diddy_B
Offline mark03
« Reply #2 on: July 08, 2020, 03:32:37 am »
HP has a nice app note on the subject:
https://www.electro-photonics.com/images/products/AN1287-9.pdf
Also check out Henrik Forsten's blog:
https://hforsten.com/trl-measurements-with-homemade-vna-and-open-source-software.html
Here he walks through the measurement of a surface-mount capacitor's S parameters.  The results are a remarkably good match to the data sheet.
Even if your VNA only supports the basic OSLT cal, you can still play with TRL and others using scikit-rf and python.
Offline joeqsmith
« Reply #3 on: July 08, 2020, 03:57:09 am »
Offline joeqsmith
« Reply #4 on: July 08, 2020, 04:02:57 am »
One of member rf-messkopf's fixtures.   He was very helpful in getting my home made standards sorted out and has a good website you may want to check out.
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #5 on: July 08, 2020, 04:22:47 am »
what bandwidth? i've made one "out of the" world class real (semi processed) wood quality + fiber FR4 hybrid test fixture, maybe good up to a GHz or two... edit: updated version on later attachments...
« Last Edit: August 15, 2020, 07:20:26 am by Mechatrommer »
Offline TheUnnamedNewbie
  • mmwave RFIC/antenna designer
« Reply #6 on: July 08, 2020, 11:13:02 am »
If you can push up to a high enough frequency, TRL is the way to go for any custom jig-specific calibration. Downside is that you need a line that is a quarter wavelength or so long, so it is not really realistic under a few GHz.
The best part about magic is when it stops being magic and becomes science instead
"There was no road, but the people walked on it, and the road came to be, and the people followed it, for the road took the path of least resistance"
« Reply #7 on: July 08, 2020, 12:35:40 pm »
@joeeqsmith
I notice you are using toroids to couple to your crystal test fixture. Do you just calibrate the test with the balun? do you use a resistor of the appropriate value for the load? (50 ohms, 200 ohms, ?) what kind of resistor do you use thats non-reactive?
@mechatrommer
Good idea to place them all together one way or another.  So they are not lost immediately! (they would be on my desk right now)
Thats a major worry of mine, if I don't make some good way to keep them together.
I'm concerned about making a calibration standard where all of the needed components are right together.
I can easily see myself losing individual tiny SMA ones. So I think I am going to make up my own.
Unfortunately, it seems most of my SMA hardware is likely some other metal than gold :{
Seems that I should buy some real gold plated SMAs for my standard-making, though.
« Last Edit: July 08, 2020, 04:46:01 pm by cdev »
« Reply #8 on: July 08, 2020, 04:47:56 pm »
Your software is much much nicer on the eyes than the nanovna software
Showing my low frequency SOLT and fixture for GHzish experiments.
https://www.eevblog.com/forum/rf-microwave/nanovna-custom-software/msg2638257/#msg2638257
Offline joeqsmith
« Reply #9 on: July 08, 2020, 07:35:13 pm »
@joeeqsmith
Yes it is calibrated with the two impedance matching transformers.   Yes, I calibrate with some resistance but then verify with other parts.   ALL parts are reactive but at DCish where I am workin, its not really a factor.   There's a fair bit of detail posted in that thread with the 20dB attenuators where I show some really crude builds for a reference.
Offline profdc9
« Reply #10 on: July 13, 2020, 02:30:35 am »
I designed a component testing jig using a ZIF socket.  There are also spots for other components as well.  I used it up to about 200 MHz with good results and 400 MHz with decent results, the limitations being the standards you can fit in a ZIF socket.
https://github.com/profdc9/VNA/tree/master/fixture
The following users thanked this post: cdev, SilverSolder
Offline Smokey
  • Not An Expert
« Reply #11 on: December 04, 2023, 05:24:56 am »
This fixture is only $60 from aliexpress:
https://www.aliexpress.us/item/3256802374699500.html
The following users thanked this post: biastee
Offline DaJMasta
    • medpants.com
« Reply #12 on: December 04, 2023, 09:40:36 am »
Those fixtures are configured for LCR meters, so they've got the interface for it and probably a lot less bandwidth than you'd want for RF characterization.  While proper fixtures are normally quite expensive, every so often you can find someone clearing out an RF lab with a bunch of custom fixtures for sale - may not be perfect for the parts you're thinking of, but probably cheap and designed for high bandwidth.
If I were trying the same, the PCB route seems like the best option.  It will be the closest to the configuration in circuit and you can build your reference planes on the same material/process, plus SMA PCB connectors are super cheap, so it's easy to just make a few boards and solder in parts under test.
