Author Topic: $20 LCR ESR Transistor checker project  (Read 5223420 times)
GraemeG and 13 Guests are viewing this topic.
Offline indman
  • Country: by
« Reply #2375 on: August 12, 2016, 08:12:02 pm »
If you're looking for the latest k-firmware, check the revision of "trunk" at https://www.mikrocontroller.net/svnbrowser/transistortester/Software/ and compare that to your local copy. You can do the same for the m-firmware ("Markus") to see if there's anything new, but the revision isn't relevant.
Dear NickNI - participant of the Russian speaking forum VRTP.RU  created very evident illustrated assistant on use of SVN of an array. I translated this document into English. I think that it will be useful, especially to beginners! https://yadi.sk/d/NrdXtqc_uBCPZ  :)
Offline hapless
« Reply #2376 on: August 12, 2016, 08:18:23 pm »
Thanks for the effort. I suggest also posting a link to the original article as a courtesy to its original author.
Offline indman
  • Country: by
« Reply #2377 on: August 12, 2016, 08:27:11 pm »
Offline lordstein
  • Country: co
« Reply #2378 on: August 12, 2016, 11:14:25 pm »
Thanks!  :)
To speed things up, I made a few assumptions about the tester and compiled the firmware. Unfortunately, I can't test it right now. If this doesn't work right, try to describe the problem in as much detail as you can, and I will adjust parameters and have another go at it.
thanks for help me
i installed mandires
the screen show this when i test a kia 7812a (voltage regulator?)
this is a a970 pnp transitor ( no diagram of bjt pnp transitor )
since i dont know which screen i have, i upload a photo from it, where i can search the type of screen?
i used the same efuse config that i used for trunks firmware
« Last Edit: August 12, 2016, 11:16:27 pm by lordstein »
Offline hapless
« Reply #2379 on: August 13, 2016, 12:03:34 am »
Yes, the tester can't correctly identify integrated circuits, including voltage regulators. This is normal.
As for the lack of icons... I think you found a small bug.
Code: (diff) [Select]
518c518
< #if defined (SYMBOLS_24X24_V) || defined (SYMBOLS_24X24_H) || defined (SYMBOLS_32X32_H)
> #if defined (SYMBOLS_24X24_VP) || defined (SYMBOLS_24X24_H) || defined (SYMBOLS_32X32_H)
Try the file that I've attached now.
Edit: Your screen's controller is ST7565 with SPI interface. I know that because that's what I compiled into the firmware, and it obviously worked.
Edit 2: Delay set to 5 seconds rather than 3, default contrast is now 5 and the encoder should work better thanks to a post (2396) by mauroh.
« Last Edit: August 15, 2016, 10:52:01 pm by hapless »
Offline madires
  • A qualified hobbyist ;)
« Reply #2380 on: August 13, 2016, 11:07:09 am »
Yes, he did. Thanks for the report and bugfix!
Offline stj
« Reply #2381 on: August 13, 2016, 02:40:38 pm »
518c518
while it's nice that you included the license in that zip, you *should* have also included any files you changed.
Offline hapless
« Reply #2382 on: August 13, 2016, 04:05:54 pm »
You're most welcome. :)
I should have put the filename in the previous post (thought I did, but apparently was in too much of a hurry), but other than that, no, I should not have included the changed file in my archive. Markus will do that when he changes it in the SVN. I posted the simple change that I made, and it is absolutely trivial to make it for anyone who's looking at the source. Someone who cares only about the stuff that comes out after it was compiled should be able to read the license, the instructions, and have the necessary files to complete the task they set out to perform, that is, to flash the microcontroller. When you download a game, do you really want it to contain all the source code files that the last reviewer had changed? All you care about is the executable and any files that make it run. This is no different.
The following users thanked this post: GBowes
Offline stj
« Reply #2383 on: August 13, 2016, 07:15:58 pm »
your missing the point.
including any changed files helps people understand hardware they may not have in front of them.
and try to remember that this is OPEN SOURCE.
Offline hapless
« Reply #2384 on: August 13, 2016, 08:06:26 pm »
How am I missing the point? The source is freely available, and my patch is out there for everyone to see. Including the file in the archive would thus have been redundant and also confusing for someone who had downloaded it just to flash it. I should also mention that if I were to submit this change as a file, it would not be the changed file, but the very text you see in my post inside a .diff file. So I guess I don't see your point. Do elaborate on what goes against someone's learning or open source in the way I did it.
« Last Edit: August 13, 2016, 08:08:03 pm by hapless »
Offline GBowes
« Reply #2385 on: August 13, 2016, 09:06:44 pm »
STJ,
FWIW, I think Hapless has the correct approach for Open Source software. He passed out a simple correction that anyone could make to their own files. If they chaged it, they would understand the change.
On the other hand you released a "version" called svn 684 but only included two files. This version is in a version system that doesn't exist except on your machine.
As best I can tell comparing to my SVN copy, these files are NOT the same as those in the k version repository and if I incorporate them into my svn, I potentially create a problem down the road. If Karl-Heinz modifies his version of these two files I would lose your changes and may not know why. If he doesn't change them but references something that you have now removed from those files, my build would fail. Either way, I would probably report it as a bug when, in fact, it was the result of changes from you that I mistakenly thought were part of the same branch.
Open Source means the source is available and modifiable by anyone. You are free to create a proper branch and continue maintaining and distributing it but if you are going to modify Karl-Heinz version of the code it would be far better if you had done it as Hapless did (the author was informed of the bug and left up to him when to include it in his official release) or JUST distributed the recompiled versions that would get replaced the next time a build is done.
This, of course, is just my opinion, but while you may be an experienced programmer, you have obviously never dealt with serious software maintenance and distribution.
The following users thanked this post: hapless
Offline stj
« Reply #2386 on: August 13, 2016, 10:03:48 pm »
the files i zipped are clearly marked "changed files"
of course they dont match the svn - you need to diff/compare them.
HOWEVER.
they do show people the correct settings for the hardware.
because the makefiles hosted by karl are generic and pretty bad.
(being polite about it)
they have badly configured contrast, incorrect included features etc.
i go to a lot of trouble to finetune those makefiles - display contrast, voltdrop from the battery etc.
it's only right that i share them afterwards for others to use.
Offline hapless
« Reply #2387 on: August 13, 2016, 11:35:43 pm »
I don't know whether to laugh or cry, but it sure feels like I'm getting a degree in psychology or something of the sort here.  :o What I'm trying to say is that I have finally puzzled out what this is about. Basically, the idea is to include the changes done to the configuration file to match the hardware (unless I missed something again). I don't mind doing that, but don't see the point right now anyway. That's because I used mostly the defaults and simply enabled some of the features that I thought the hardware has. There was no tweaking, since I had no way of knowing at the time which exact tester the person asking for the firmware had. I think it would be a better idea for owners of different devices to share their specs and measured voltages and resistances, best contrast settings, and so on, so that tweaking any firmware (hey, who says there have to be only two, right?) to support those testers would be more straightforward. A forum is not the best place for such a collection of data, but a website with a database... why not?
Any takers?  :-DD
Offline stj
« Reply #2388 on: August 14, 2016, 04:11:53 am »
the hard part is getting people to answer questions like "what's the best contrast value".
they cant be bothered repying once the firmware works!
then there is the curse of the devil's operating system - Win10
i have been getting a number of people recently who couldnt program the tester with AVRdude.
it looks like win10 cuts the command-line buffer short, possibly terminating it at a back-slash.
i have to get win10 victims to program the flash,eeprom and fuses in 3 seperate passes!  >:(
Offline roli_bark
« Reply #2389 on: August 15, 2016, 02:15:52 pm »
I bought the Banggood version:
http://www.banggood.com/DIY-M12864-Graphics-Version-Transistor-Tester-Kit-LCR-ESR-PWM-p-986954.html
( 'Orignal'   :-DD  Hiland DIY M12864 Graphics ... ) . I understand it's the 12864 LCD module.
I want to update its firmware.
- Can it be found in the "trunk" (k firmware)  ST7565 ?
Which of them  mega328_st7565, mega328_st7565_kit, mega328_T3_T4_st7565, mega328_T5_st7565, mega328_wei_st7565?
- Can it be found in the "Markus" (m firmware) ?
Offline Willem52
« Reply #2390 on: August 15, 2016, 04:40:41 pm »
The Banggood tester firmware you can use:
https://www.eevblog.com/forum/testgear/$20-lcr-esr-transistor-checker-project/?action=dlattach;attach=245484
See https://www.eevblog.com/forum/testgear/$20-lcr-esr-transistor-checker-project/msg997651/#msg997651
« Last Edit: August 15, 2016, 04:48:52 pm by Willem52 »
Offline roli_bark
« Reply #2391 on: August 15, 2016, 05:32:17 pm »
Thanks !
But I still wonder whether in the repository there's a 'k' ("trunk") or 'm' ("Markus") version for the 12864 LCD ?
( and whether the 12864 is the ST7565 ? )
« Last Edit: August 15, 2016, 05:44:00 pm by roli_bark »
Offline mauroh
    • Mauro Pintus
« Reply #2392 on: August 15, 2016, 06:58:57 pm »
The correct repository for the DIY Banggood tester is mega328_st7565_kit for the k version
For the m version you need to compile it by yourself changing the proper lines on the config file
I posted the compiled 1.23m few post back and here you can find also the latest 1.24m
https://www.eevblog.com/forum/testgear/$20-lcr-esr-transistor-checker-project/msg1003108/#msg1003108
Mauro
« Last Edit: August 15, 2016, 07:12:16 pm by mauroh »
Offline Harm2k16
« Reply #2393 on: August 15, 2016, 07:58:03 pm »
Hi STJ,
Me again... ;)
I'am trying to compile (how it's done, i'am an absolute n00b with this) the .hex and .eep files for my lcr-t4 tester with your original un-modified Makefile.
I've installed WinAVR (latest) and set-up the directories (maps) on my hdd with the files from the SVN- repository (downloaded the whole tarball).
It seems to be working, at least i see no errors, had to replace the msys-1.0 file in the utils\bin directory of winavr.
...but my output TransistorTester.hex- file is 103kB in size! Your files are a .hex- file of 83kB (8MHz version) and 89kB (16MHz version) in size.
(I've used your supplied Makefile to compile.)
How is this possible?
Any help, comments, e.t.c. is -dearly- appreciated.
TIA.
Offline roli_bark
« Reply #2394 on: August 15, 2016, 08:21:45 pm »
 ... here you can find also the latest 1.24m
Mauro
Many thanks Mauroh.
I think he fixed some display issue version v2 :
https://www.eevblog.com/forum/testgear/$20-lcr-esr-transistor-checker-project/msg1003295/#msg1003295
Still, What are proper config.h lines to change to make it (and future repository 'm' versions) work with the banggood LCR ?
« Last Edit: August 15, 2016, 08:30:34 pm by roli_bark »
Offline hapless
« Reply #2395 on: August 15, 2016, 08:57:46 pm »
[...]I think he fixed some display issue version v2[...]
Yes, he thinks he did so, too. He can't be sure because of the lack of feedback, but, as stj mentioned a few posts ago, when something works, people tend to just grab it and disappear.  :D
[...]Still, What are proper config.h lines to change to make it (and future repository 'm' versions) work with the banggood LCR ?
The  configuration in config.h is not set in stone for any tester. In config_328.h, you need to set the display driver to
Code: (C) [Select]
 *  M12864 DIY Transistor Tester
 *  - ST7565 display
 *  - rotary encoder at PD1/3
by commenting out the corresponding #if 0 and #endif and uncommenting the currently commented ones, and in config.h you can choose some of the options that you want to be enabled, again, by uncommenting the corresponding #define statements. You'll want the encoder, the voltage reference, and the frequency counter because that is what the hardware is designed with, the rest is up to you.
Offline mauroh
    • Mauro Pintus
« Reply #2396 on: August 15, 2016, 09:59:35 pm »
List of all changes you need to make on the config.h to have the m-firmware working correctly with M12684 DIY Kit
Config.h Changes to work with M12684 DIY KIT (Banggood)
Section:
 *  - ST7565 display
Uncomment entire secion and comment other LCD sections
Comment the following line to:
//#define LCD_OFFSET_X
Change the following line to:
#define LCD_CONTRAST     5
Section:
 *   Hardware options
Uncomment
#define HW_ENCODER
#define HW_REF25
This should be already
#define UREF_25           2495 //Tipical output of TL431AA (you shuld measure it?)
Section:
 *   port and pin assignments
Change to
#define ENCODER_A        PD1       /* rotary encoder A signal */
Mauro
« Last Edit: August 16, 2016, 10:26:02 am by mauroh »
Offline stj
« Reply #2397 on: August 15, 2016, 10:08:40 pm »
Hi STJ,
Me again... ;)
TIA.
newer versions of gcc make larger files :(
the answer is to overwrite gcc with a slightly older version.
i use the one bundled with the ARDUINO IDE.
https://www.arduino.cc/download_handler.php?f=/arduino-1.6.10-windows.zip
The following users thanked this post: Harm2k16
Offline hapless
« Reply #2398 on: August 15, 2016, 10:53:05 pm »
Section:
Change to
Mauro
Thanks, don't know how I missed that one. Corrected.
Offline roli_bark
« Reply #2399 on: August 16, 2016, 05:31:17 am »
Mauroh,
Excellent ! - That's exactly what I needed.
One wonder though:
'hapless' says uncomment:
 *  - ST7565 display
while mauroh says uncomment:
 *  - ST7585 display
What gives ?
« Last Edit: August 16, 2016, 05:36:18 am by roli_bark »
