Author Topic: $20 LCR ESR Transistor checker project  (Read 5331134 times)
0 Members and 231 Guests are viewing this topic.
Offline vinceroger
« Reply #2600 on: September 08, 2016, 07:34:44 pm »
This video helped me regarding setting up avrdude etc and the programming side of things
Offline belzrebuth
  • Country: gr
« Reply #2601 on: September 08, 2016, 07:51:07 pm »
Thanks!
I guess I'll wait for the usbasp to arrive (15-20 days)
I don't what's wrong with my arduino.
I tried flywheels avrdude -c avrisp -p m328p -P COM4 -b 19200 and I got the same error with no wires attached so it must be the arduino.
I don't know why it doesn't communicate properly with the avrdude command.
Thing is that I'm able to to upload sketches via the Arduino IDE .
If it was something wrong with the drivers or so ,wouldn't it be unable to work with the IDE as well?
If there was a way to send the files within the IDE maybe it could work but I don't know the way.
Offline vinceroger
« Reply #2602 on: September 08, 2016, 08:00:25 pm »
someone may have some idea whats wrong dont give up just yet double check your wires are on the correct pins on the atmega 328p etc as we have all made mistakes in the past. for my usbasp programmer ive also brought the socket and hard wired it to my ic pins so any time i want to update the firmware i can easily although i do have the tl 866 programmer too avrdude seems quicker.
Offline belzrebuth
  • Country: gr
« Reply #2603 on: September 08, 2016, 08:11:28 pm »
Do u have a link for the socket?
Is this it?
http://www.ebay.com/itm/AVR-ATMEGA16-Minimum-System-Board-ATmega32-USB-ISP-USBasp-Programmer-For-ATMEL-/201622104604?hash=item2ef19d2a1c:g:w8sAAOSwzLlXhUNE
I might get a tl866 myself although whenever I need a 27cXXX or something a friend of mine just burns me one but tl866s are nice for the price and handy if you need an eprom in a hurry..
Offline vinceroger
« Reply #2604 on: September 08, 2016, 08:21:01 pm »
no thats the wrong one in that ebay link its just a small 10 pin socket the part you have already ordered plugs into it.i will see if i can find a link
http://uk.rs-online.com/web/p/idc-connectors/6257252/
« Last Edit: September 08, 2016, 08:29:40 pm by vinceroger »
Offline vinceroger
« Reply #2605 on: September 08, 2016, 08:32:07 pm »
Is this it?
can you take you atmega ic out and put the files on a disk/usb stick then maybe a local computer shop in your area will burn the files to the ic cheap/free for you saves waiting too.
« Last Edit: September 08, 2016, 08:34:26 pm by vinceroger »
Offline belzrebuth
  • Country: gr
« Reply #2606 on: September 08, 2016, 10:52:33 pm »
I managed to write the firmware. :)
My arduino was ok too, but I was an idiot and the isp sketch I kept uploading wasn't the correct one..
I tried Files>Examples>Arduino ISP and uploaded that and it worked!
It was in front of me the whole time.
Anyways,thanks for all the help!(especially flywheelz for the guide/commands)
Now I think I have to calibrate it..
« Last Edit: September 08, 2016, 10:55:20 pm by belzrebuth »
Offline flywheelz
« Reply #2607 on: September 09, 2016, 04:25:19 am »
Good job!  Another one for the team  :-+
The following users thanked this post: belzrebuth
Offline belzrebuth
  • Country: gr
« Reply #2608 on: September 09, 2016, 08:09:41 am »
Is there a YouTube video or a manual/guide on how to calibrate this thing?
I've found some videos on YT but they're for different firmware versions..
I shorted pins 1-2-3 and entered selftest mode but I get some random values along the way.
I then put a 320nF polyester cap (no 220nF as advised but said >200 so it should be ok) and then I'm not really sure what I was doing.
In the end the test completed and now I seem to have a functional unit but I think I may have to recalibrate it properly.
I followed the instructions here (seems to be pretty close to my version).
« Last Edit: September 09, 2016, 08:23:57 am by belzrebuth »
Offline belzrebuth
  • Country: gr
« Reply #2609 on: September 09, 2016, 08:30:48 am »
There are also instruction on the calibration process on the ttester.pdf manual!
Offline stj
« Reply #2610 on: September 09, 2016, 10:32:51 am »
you did it correctly.
Offline vinceroger
« Reply #2611 on: September 09, 2016, 10:35:39 am »
Im glad you have managed too get your tester working they are good meters in my opinion,
Offline madires
  • A qualified hobbyist ;)
« Reply #2612 on: September 09, 2016, 03:28:26 pm »
Yeah, these simple and cheap testers are awesome! Sometimes I'm amazed how much we can achieve with the firmware. And it's still fun to add new features and improve measurements.
Offline flywheelz
« Reply #2613 on: September 09, 2016, 05:43:07 pm »
I agree with madires, amazing gadget!  The other thing that stands out from this project is a type of people that are involved in it.  Everyone from developers, fw cookers, helpers, etc, I would be honored to shake your hand for the job well done.
While testing, I found 1.12k svn690 seem to detect this JFET ok but 1.24m trendy having a bad day at the office.
datasheet
https://www.fairchildsemi.com/datasheets/MP/MPF102.pdf
Offline madires
« Reply #2614 on: September 09, 2016, 07:36:09 pm »
If you're talking about the pinout, k and m-firmware differ. J-FETs are often symmetrical. The k-firmware will display the assumed Source and Drain pins, but they could be also vice versa. IIRC, Karl-Heinz explains that in the documentation. The m-firmware checks if the J-FET seems to be symmetrical and displays "x" for the Source and Drain pins to indicate that. A measurement of the Gate-Source and Gate-Drain capacitance would identify Source and Drain or a symmetrical J-FET reliably, but the Tester's circuit doesn't support that. It would require a DC bias and an AC based capacitance measurement.
Offline flywheelz
« Reply #2615 on: September 09, 2016, 08:48:53 pm »
Ohh  :palm:
Its another feature that I miss took as a bug or error, oops.
P.S. I am not sure why but 1.24m seems snappier to me than 1.12k @8MHz.  Can't wait to see how it will fly with 16MHz xtal.
Thanks for the explanation.
« Last Edit: September 09, 2016, 09:05:12 pm by flywheelz »
Offline flywheelz
« Reply #2616 on: September 10, 2016, 01:22:33 am »
A pack of 16MHz crystals came today.  Replace the 8 for 16 on my Color-kit AY-AT tester.  The holes were a biatch to clean out for the new crystal.
When I plugged in the battery, the tester started up just fine.  It seem to work normally with 8MHz fw build.  Feels faster refresh/test times.
Next, I've flashed a 16MHz fw but not seeing any difference  from 8MHz fw:-//.
Am I missing something?
Can I test the crystals with the tester?
Fuses are set to F7/D9/04.  I know some people set efuse to 0xfc, but my atmega can't take that, 0x04 works.
Update:
After more testing, with 8MHz fw and 16MHz xtal, the capacitance test values are doubled.  With 16MHz fw they are reported correctly  :-+
« Last Edit: September 10, 2016, 04:32:05 am by flywheelz »
Offline flywheelz
« Reply #2617 on: September 10, 2016, 02:51:21 am »
Compiled 1.12k svn690 with xtal test and flashed it.  The original 8MHz crystal is detected as 8MHz exactly.  The ones I got today read as 14.6342KHz but sometimes not detected.  Is this limitations of tester or did I get crap crystals?
Offline TheBay
  • Country: wales
« Reply #2618 on: September 10, 2016, 03:57:10 am »
I've got a MK-328 on it's way from HK, can't wait to have a play with it.
One question I have though, does anyone know where I can buy a AVR-ICSP 8 Pin cable to fit the Mini Pro TL866A? rather than knocking one up,
I would use this quite often and wondering if there is an off the shelf cable, buying the bits to make a cable costs more than buying a USBASP!
Offline jh15
Re: $20 LCR ESR Transistor checker project Stickey needed, where do I start?
« Reply #2619 on: September 10, 2016, 04:11:12 am »
thousands of posts, where and what do I buy?
Tek 575 curve trcr top shape, Tek 535, Tek 465. Tek 545 Hickok clone, Tesla Model S,  Ohio Scientific c24P SBC, c-64's from club days, Giant electric bicycle, Rigol stuff, Heathkit AR-15's. Heathkit ET- 3400a trainer&interface. Starlink pizza.
Offline stj
« Reply #2620 on: September 10, 2016, 04:30:07 am »
the crystal test is limited to about 12MHz, you cant test crystals running as fast or faster than the tester.
the 16MHz crystal makes the cap tests more accurate because of faster sampling though :)
so what did you NOT enable??
i couldnt build a hex for AY-AT with the crystal test without running out of room!
The following users thanked this post: flywheelz
Offline flywheelz
« Reply #2621 on: September 10, 2016, 04:49:33 am »
stj,
CFLAGS += -DFONT_5X8
#CFLAGS += -DFONT_8X12thin
CFLAGS += -DWITH_XTAL
#CFLAGS += -DWITH_UART
Offline flywheelz
« Reply #2622 on: September 10, 2016, 05:08:39 am »
Thousands of clones testers, to each his own.  Not knowing your need, I will list a few.  There are kits or already built versions.  Buy where you trust and price you like.
Well known as Banggood version
http://www.banggood.com/DIY-M12864-Graphics-Version-Transistor-Tester-Kit-LCR-ESR-PWM-p-986954.html
Highly regarded as a nice choice GM328R.
http://www.ebay.co.uk/itm/331873741389
Already built unit Nice case, zif board, 3 test clips, very good for bench/field use
http://www.banggood.com/MK-328-Transistor-Tester-Capacitor-ESR-Inductance-Resistor-Meter-LCR-NPN-PNP-MOS-p-1010347.html
Fancy multi colored custom firmware, only one does higher voltage zener test,  Note: No multi color open-source firmware for this model
http://www.ebay.com/itm/2016-Transistor-Tester-TFT-Diode-Triode-Capacitance-Meter-LCR-ESR-NPN-PNP-MOSFET-/182170556129?hash=item2a6a3616e1:g:Ep8AAOSwnNBXX9D9
Russians favorite
http://www.ebay.com/itm/12864-Mega328-ESR-Transistor-Resistor-Diode-Capacitor-Mosfet-Tester-w-Test-hook-/321963237498?hash=item4af681207a:g:sBMAAOSwa-dWhWzn
I purchased this one.  Color lcd AY-AT, slowish refresh rate, kit has some diode array input protection but this seller smds are not soldered, some other sellers got smds soldered already.
http://www.aliexpress.com/item/2016-DIY-kits-TFT-LCD-M328-Transistor-Tester-LCR-Diode-Capacitance-ESR-voltage-meter-PWM-Square/32649811953.html?spm=2114.13010608.0.56.J7yA7x
Lately, some kits arrive with blank chips so you have to flash open source firmware  yourself.
Must read, all you ever wanted to know, the birth and the evelution of the infamous transistor tester and more
ttester.pdf manual
« Last Edit: September 26, 2016, 06:26:02 am by flywheelz »
The following users thanked this post: PaulS, stryker, julian1
Offline jh15
« Reply #2623 on: September 10, 2016, 05:36:34 am »
Thank you, I have one of these, years ago didn't remember details, and wanted to figure it out, or buy another that I can trust.
Offline stj
« Reply #2624 on: September 10, 2016, 05:39:06 am »
narrow down your choice by saying if you want it ready-built, or if you want a kit.
if a kit, it's down to the banggood, the GM328r and the AY-AT
because you want the rotary encoder with it.
the AY-AT has the better display.
the banggood has an optional case - although that may be useable with the others with a bit of modding.
