An option for measuring the external frequency of both quartz and ceramic resonators using T-testers with an ST7735 instead of an Xtal.
For slower models, the above addition is required. I have a similar solution working on a T4 with an ST7565, but I can't test it with the ILI9341 I have because I don't have enough memory. Anyone willing to take the risk and check?
The range I tested was from 32768 Hz to 48.0 MHz, the measured external frequency was 70 Hz to 70 MHz.
If you don't need a frequency higher than 25 MHz, you can use an HCF4060BE. It's powered by 9V, and the output is divided by a 10 k
resistors.
I added Rbe measurements for individual transistors with an input voltage divider, for Ube > 0.8V. I updated all the firmwares...
