Author Topic: $20 LCR ESR Transistor checker project  (Read 5223244 times)
Offline GraemeG
« Reply #10275 on: August 10, 2026, 02:21:38 am »
The battery check is usually done about every 10 s when running functions/tools. When the voltage drops below BAT_LOW the display will show the battery status and the tester powers down after 3 seconds. Maybe the interval is too long for a small battery like in the TC1. You can change the interval in main.c, in function CheckBattery():
After testing again I learn I should check everything twice (maybe 3 times!) before posting and showing my ignorance. The battery check is definitely working for me in both the zener and capacitor leakage tests. After the battery voltage drops below BAT_LOW a few seconds later the low voltage is displayed and the unit turns off. Exactly as you described madires. I don't know what I was imaging before  :palm:
Offline Yuriy_K
  • Country: ru
« Reply #10276 on: August 11, 2026, 10:58:55 am »
Added Rbe measurement for the k-firmware. Modified the Cg calculation for the Arduino Mega.
I found a bug when measuring resistance, so I replaced everything...
« Last Edit: August 17, 2026, 12:58:28 pm by Yuriy_K »
The following users thanked this post: stj, Polf
Offline Yuriy_K
  • Country: ru
« Reply #10277 on: August 14, 2026, 10:06:56 am »
An option for measuring the external frequency of both quartz and ceramic resonators using T-testers with an ST7735 instead of an Xtal.
For slower models, the above addition is required. I have a similar solution working on a T4 with an ST7565, but I can't test it with the ILI9341 I have because I don't have enough memory. Anyone willing to take the risk and check?
The range I tested was from 32768 Hz to 48.0 MHz, the measured external frequency was 70 Hz to 70 MHz.
« Last Edit: August 17, 2026, 01:02:33 pm by Yuriy_K »
The following users thanked this post: N9XYP
