Author Topic: $20 LCR ESR Transistor checker project  (Read 5419020 times)
0 Members and 215 Guests are viewing this topic.
Offline indman
  • Country: by
« Reply #1300 on: September 23, 2015, 05:01:18 pm »
In the last audits of a firmware the author added the new mode of measurement of inductance. It is necessary for operation of this mode in case of calibration (Selftest mode) there will be a parameter "Cap for L meas?" - the condenser for measurement of L.
in case of which it is necessary on T1 - T3 to connect capacity =10nF to 20nF which in case of measurement needs to be connected further parallel to the measured inductivity
In case of measurement on T1 - the inductivity T3 with parallely connected condenser is displayed:
1 - 3  0.02- - resistance in Ohm.
600nH if 10.7nF - inductivity in mH (millihenry) µH (microhenry) of nH (nanohenry) with if capacity added parallely in nF (nanofarad).
1985kHz Q=2.5 - frequency (resonant or the frequency of a circuit) in kHz (kilohertz) and Q (good quality of L).
« Last Edit: September 23, 2015, 05:06:57 pm by indman »
Online yo0
  • Country: mx
« Reply #1301 on: September 23, 2015, 07:01:48 pm »
yo0,try this firmware for the tester. I hope everything will work!
thank you very much!, works as intended, just i having trouble with calibration, as i understand i need a 10-20 nf cap, need to find one :(
and the font you choose looks great!!
you plan to release new versions this model in the future?
best regards
Pio
« Last Edit: September 23, 2015, 07:04:29 pm by yo0 »
Offline indman
  • Country: by
« Reply #1302 on: September 23, 2015, 07:21:11 pm »
yo0, I am glad that at you the firmware earned! :)
You can use for calibration any capacity from 10nF above, it is only desirable that it was high quality.
If fresh firmwares for your clone are necessary, I will help!
I collect and I compile firmwares for different clones, on Yandex resource a disk I have a space for them. You can look at them according to the link
https://yadi.sk/d/yW8xa5NJgUo5z
The following users thanked this post: yo0
Online yo0
  • Country: mx
« Reply #1303 on: September 23, 2015, 08:08:22 pm »
thank you very much again, i already bookmaked your repository, i will visit it for any update.
thank you again!
best regards
Pio
Offline nbritton
« Reply #1304 on: September 24, 2015, 04:53:54 am »
Can someone post an executive summary of this 87 page thread? I would like to know how I can build one or where I can pickup one of these devices.
« Last Edit: September 24, 2015, 04:57:05 am by nbritton »
Offline bitseeker
« Reply #1305 on: September 24, 2015, 05:31:38 am »
There are so many to choose from. Some are assembled, some are in kit form.
Here's a high-level summary of some of the variations:
  • Compact, 2-line character LCD display: some use 9-volt, some use rechargeable battery.
  • Graphical LCD display: some have single button (test/on), some have two (test/on, off), some of the newer ones have a rotary encoder that you can press for test/on.
  • There are different models of microcontrollers on them: Atmega 8, 168, 328, 2560; some are socketed DIP (easy to replace if you fry it because you forget to discharge a cap before testing), others are SMD.
  • The ones with at least Atmega328 can use the extra features of the latest firmware such as function generator and frequency counter.
  • Some are built into a case or have a separate case that they fit into.
There are many other details, but hopefully this will get you oriented.
« Last Edit: September 24, 2015, 05:33:42 am by bitseeker »
Offline Messtechniker
« Reply #1306 on: September 24, 2015, 06:51:12 am »
6. With or without ISP connector.
In the case of non-socketed processors you will need the ISP connector for flashing.
Since I wanted to help development of this thing, I went for the GM 328. It has a socketed processor.
So it is easy to flash externally and replace if damaged. Can easily happen when connecting
large capacitors which are still charged. A protection circuit would prohibit measurements
on other components.
Yours Messtechniker
Agilent 34465A, Siglent SDG 2042X, Hameg HMO1022, R&S HMC 8043, Peaktech 2025A, Voltcraft VC 940, M-Audio Audiophile 192, R&S Psophometer UPGR, 3 Transistor Testers, DL4JAL Transistor Curve Tracer, UT622E LCR meter, UT216C AC/DC Clamp Meter
Offline bitseeker
« Reply #1307 on: September 24, 2015, 06:00:53 pm »
Thanks for the additional info, Messtechniker.
I got my kit today (socketed 328 with graphical LCD and rotary switch). Weekend project!
Online yo0
  • Country: mx
« Reply #1308 on: September 28, 2015, 12:40:51 am »
hello, somebody know the unpopulated parts of this tester pcb are intended for?
best regards
Pio
« Last Edit: September 28, 2015, 12:43:15 am by yo0 »
Offline quantalume
« Reply #1309 on: September 28, 2015, 03:27:10 pm »
This is a very good point. In fact, I would not recommend anyone buy a version without either a socketed controller or protection on the input pins.
Offline indman
  • Country: by
« Reply #1310 on: September 28, 2015, 04:11:25 pm »
yo0, these details are necessary to provide a supply and illumination for displays of different types. If everything works for you, there is no need to solder them
Online yo0
  • Country: mx
« Reply #1311 on: September 28, 2015, 10:09:52 pm »
thank you for the info!
Pio
Offline Electro Fan
« Reply #1312 on: October 01, 2015, 03:17:44 am »
Don't know if this one has been nominated in the tester + frequency generator category:
http://www.amazon.com/gp/product/B00OOQC2E8/ref=pd_luc_rh_top_sim_03_03_t_img_lh?ie=UTF8&psc=1
Offline indman
  • Country: by
« Reply #1313 on: October 01, 2015, 07:16:58 am »
Any tester with a new firmware from Karl-Heinz Kübbeler contains this function of the generator
Offline wasyoungonce
« Reply #1314 on: October 01, 2015, 08:24:06 am »
Yeah I have one...from fleabay  works ok but no in circuit programming port.
Here it is.... in a feable box.  Had to remove the display SIL header and lower the display (so it wasn't too high wrt the ZIF socket), butcher the box and heat bend the zif socket actuator arm to fit.
What can I say...it works, no prizes though.
I'd forget my Head if it wasn't screwed on!
Offline amirtebyan
  • Country: ir
« Reply #1315 on: October 01, 2015, 09:59:45 am »
Hi guys:
My english is not very good.
I have some problems with my tester.
I use 1.12k ver with graphic lcd st7920 and atmega2560.
1_ some times When no component connected and i press test key a capacitor in range of micro farad is shown.
2_ When "not calibrated" massage is shown on lcd i do calibration prosses and after finishing it this massage shown again.
3_ when i connect any inductor and press test button lcd dosen't show any thing and i should reset microcontroller for back to normal opration. This happen some times when i connect larg capacitor to tester like 2200 uf .
Do you know the reason?
Offline klaus11
« Reply #1316 on: October 01, 2015, 10:26:05 am »
with open programming spl7 extension schemes.
HP3458A, HP3245a, Keithley 2000, Fluke 87V, Rigol DP832, TEK TDS5052B, HP33120A
Offline indman
  • Country: by
« Reply #1317 on: October 01, 2015, 11:42:26 am »
Diagrams in the spl7 format open the sPlan7.0 program. Link to this software:
http://abacom-online.de/uk/html/demoversionen.html
« Last Edit: October 01, 2015, 12:16:07 pm by indman »
Offline madires
  • A qualified hobbyist ;)
« Reply #1318 on: October 01, 2015, 12:11:58 pm »
Do you power the tester with a battery or a switching mode power supply?
Offline klaus11
« Reply #1319 on: October 01, 2015, 01:16:17 pm »
Offline amirtebyan
  • Country: ir
« Reply #1320 on: October 01, 2015, 01:50:30 pm »
I use switching power supply with 9v 1000mA output.
Offline madires
« Reply #1321 on: October 01, 2015, 01:59:26 pm »
Please try a battery or a linear regulated power supply.
Offline amirtebyan
  • Country: ir
« Reply #1322 on: October 01, 2015, 02:13:12 pm »
Thanks I will try it.
I have another questions to
1- When I connect capacitors like 2200uF and 100uF are shown  much lower (1.7mF and 79uF). what is the reason?
2- I use atmega2560 and i set clock source 8Mhz internal rc oscillator , is it ok? how should i set the other fuese?
Offline madires
« Reply #1323 on: October 01, 2015, 04:01:14 pm »
I'd think it's caused by normal tolerances.
For a higher accuracy I'd recommend an external crystal. The fuse settings are in the setup.mk file (included by Makefile).
Offline bitseeker
« Reply #1324 on: October 02, 2015, 12:09:38 am »
Check what's the tolerance for those capacitors. For example, if they're 10%, then the 2200uF can be from 1980-2420uF (2200+-220uF). Looks like those two are a little over 20%, which might be close enough for 20% caps if your tester is a little out of calibration.
