Author Topic: $20 LCR ESR Transistor checker project  (Read 5452979 times)
0 Members and 534 Guests are viewing this topic.
Offline madires
  • A qualified hobbyist ;)
« Reply #1775 on: February 17, 2016, 02:03:34 pm »
I can read "PWM" and "ESR". The other lines seem to be the same gibberish. That could mean that the items got the same broken pointer. When you enter the PWM tool, do you get a nice list of the frequencies or more gibberish?
When enter the PWM, text display is good, as shown below mr...
Could be some garbage in the EEPROM. I'd try to re-flash the firmware and the eeprom.
Offline AlxDroidDev
  • Country: br
    • Arduino Web Brasil
« Reply #1776 on: February 18, 2016, 01:14:13 pm »
After a 62 days wait for delivery, I finally got mine last night. It is a M12864, exactly like this one:
It uses an 8Mhz crystal and all resistors are 1%.
It was assembled and tested and works great! I also dumped the firmware (v1.17) and EEPROM that came with it so I have a copy and can safely play with updates.
Now my questions:
- is my board compatible with the latest firmware (641) on svn? Are there any modifications required?
- if not, what is the latest firmware I can install on my board?
"The nice thing about standards is that you have so many to choose from." (Andrew S. Tanenbaum)
Offline tom666
  • Country: sk
    • Slovak discussion forum - AVR Component Tester (RLC/ESR & Semiconductors Tester)
« Reply #1777 on: February 18, 2016, 04:02:48 pm »
@AlxDroidDev
It was here several times already mentioned.
Your tester is an identical copy of the original concept and is therefore compatible with the k-version (Karl-Heinz Kübbeler aka kubi48) and m-version (Markus Reschke aka madires) of the software.
Your dump (v1.17 ???) is probably useless, because the contents of the MCU is standard locked. Basically it does not matter, because the author of this software is Karl-Heinz Kübbeler. Therefore, without any modifications you can be applied directly his original software (directory mega328_st7565_kit).
However, I recommend carefully studied the official manual ;)
:phew:
Note:
... It uses an 8Mhz crystal and all resistors are 1%. ...
Interesting, because all kits of this tester, that went through my hands contained the precise (0.1%) value of the test resistors 680 and 470k.
Offline AlxDroidDev
  • Country: br
« Reply #1778 on: February 18, 2016, 05:33:20 pm »
Thank you, @Tom.
Do you think I should set the lock bits after flashing a new firmware ?
Offline tom666
  • Country: sk
« Reply #1779 on: February 18, 2016, 05:41:38 pm »
You need to set only the standart fuses:
lfuse:0xf7 hfuse:0xd9 efuse:0x04 (0xfc)
Offline avrank
  • Country: id
« Reply #1780 on: February 19, 2016, 06:31:13 am »
Please help me,
I use a yellow board t3 t4, and compile file M, but the display is still not perfect as in the picture. What's wrong ? Thankyou.
Thank you sir ...
Offline MLXXXp
« Reply #1781 on: February 19, 2016, 09:33:42 pm »
I have an older EZM Electronic Studio version bought from eBay a couple of years ago
I have the exact same unit.  I've made a few modifications:
  • Replaced the 8MHz crystal with a 16MHz one.
  • Replaced the test switch with a rotary encoder.
  • Added a 1nF capacitor on AREF.
  • Put additional 100nF capacitors directly on the socket's Vcc and AVcc pins (just because I have lots lying around).
  • Replaced the 10uF/16V electrolytic capacitor C6 with a 22uF/35V tantalum (just because I have lots of them, too).
I try to keep mine up to date with the latest M-firmware.
I used to remove the processor to program it, but then I made a cable for my USBASP programmer, using IC test clips. With the display removed, I clip them to R4, R5, R6 and R7 for the signals, and on C6 for power.
« Last Edit: February 19, 2016, 10:46:28 pm by MLXXXp »
Offline timelessbeing
« Reply #1782 on: February 20, 2016, 06:30:17 am »
Markus,
I have the ST7565 kit tester. The rotary encoder is connected to PD1 and PD3. How do I configure this in your software please?
Also, did you write code to support the extra ADC pins of the m328 QFP package? And if not, do you plan to?
Thanks.
Offline caius
    • Caius Arcade Repairs & Engineering
« Reply #1783 on: February 20, 2016, 08:34:49 am »
Offline tom666
  • Country: sk
« Reply #1784 on: February 20, 2016, 12:58:22 pm »
@caius
A rotary encoder is used for easier menu navigation and control functions of the tester. For this DIY KIT of the tester can be used directly to original k-version software without any modifications - either way, this Chinese clone contains exactly this firmware (v1.12k) ;)
Offline caius
« Reply #1785 on: February 20, 2016, 01:09:14 pm »
@caius
OK, thanks for explanation.Is v1.12K the latest and best firmware available?Which are issues(I know there are)?
Offline tom666
  • Country: sk
« Reply #1786 on: February 20, 2016, 01:31:30 pm »
@caius
Currently is it the most appropriate version of software. K-version is under development and testing, but so far everything is working normally. If you know of any bugs, please give some information. I recommend carefully studied the official manual!
Offline caius
« Reply #1787 on: February 20, 2016, 01:34:55 pm »
@caius
OK, I'll get the kit and test the assembled unit reporting feedback.Thanks for you help.
Offline tom666
  • Country: sk
« Reply #1788 on: February 20, 2016, 01:40:41 pm »
@caius
Off topic:
Please, do not use unnecessarily the button quote :)
Just use only the reply ;)
Offline caius
« Reply #1789 on: February 20, 2016, 01:43:44 pm »
I was going to use the reply button but then I thought someone would not have understood mine was a reply to your post  :)
Offline tom666
  • Country: sk
« Reply #1790 on: February 20, 2016, 02:18:18 pm »
@caius
OT: If the question or reply is immediately after the post msg, it is not unnecessary to use the quote. Some users have also problem with this :(
Note:
Button "Quote" should not be used to the last post - but it would have to set the administrator of this discussion forum.
Offline caius
« Reply #1791 on: February 20, 2016, 02:22:19 pm »
OK, roger  :)
Offline madires
« Reply #1792 on: February 20, 2016, 02:35:49 pm »
Everything is in config.h ;) Enable the rotary encoder option (#define HW_ENCODER), set pulses/detents (#define ENCODER_PULSES   2) and adjust the encoder I/O pins (#define ENCODER_A   PD1). And there's a dedicated section for the M12864's display.
Not yet, but if an interesting hardware option for one of the extra pins comes up ...
Offline all_repair
« Reply #1793 on: February 20, 2016, 02:37:02 pm »
LCR-TC now in color, and shall probably sell for 50usd on ebay.  Not an owner yet, I can't show more.
« Last Edit: February 20, 2016, 02:39:28 pm by all_repair »
Offline tom666
  • Country: sk
« Reply #1794 on: February 20, 2016, 02:41:55 pm »
OK, roger  :)
Sorry. I did not intend to touch you somehow :)
Offline caius
« Reply #1795 on: February 20, 2016, 02:50:10 pm »
No, you are perfectly right!We have to respect the netiquette all the time.
Offline madires
« Reply #1796 on: February 20, 2016, 02:54:16 pm »
That modified firmware has nice graphics. Unfortunately the author doesn't provide the source code and ignores that the firmware is open source. :-- But we have color support too. And I think I'm able to add touch screen support for an ATmega 664/1284 version.
Offline AlxDroidDev
  • Country: br
« Reply #1797 on: February 20, 2016, 06:18:14 pm »
I got mine working with Trendy 1.21m!
I want to thank Markus for the superb job he`s done with the firmware, and specially thank him for supporting all the hardware that others have developed around his initial project. He's done such a great work, I don't even care about losing 7x1 to Germany!
I also want to thank tom666 for the huge amount of help he`s been giving everyone and the time and effort he's put into this forum.
Guys, you are awesome!
« Reply #1798 on: February 20, 2016, 08:36:18 pm »
 :-BROKE
Oscilloscope input of course.  ;)
« Reply #1799 on: February 20, 2016, 08:48:20 pm »
Tom, this is a poor choice of the word "touch". We understand what you mean, but in another situation, it might sound criminal.
Use instead: I did not intent to piss you off/irritate you.
