The only thing I wish to have on this kind of tools is to be multi-platform #
On platforms other than Windows you'd have to use an emulator like "Wine", for example.
I made a really simple one with processing only to use it on win and mac.
To keep the PC software stupid simple I modified the k firmware to add at the beginning of each sting sent to the serial port the number of the line and a terminator at the end of each sting.
Also throught about doing this. But decided instead inspite of the parsing difficultires
to stay compatible with the standard firmware. You might ask Kubi in the
German forum to include your fimware mod in the k firmware.
I would then adapt my progs accordingly.
How do you recognize the start/end of each sting/measure?
I simply select a suitable (unique) character in the string to split it for further
string processing. Certainly not ideal because I am forced to used different
splitting characters depending on the type of component.
Have you implemented several conditions to distinguish the parts of the measurements?
No. Is too diffucult or impossible when simply relying on what the Transistor Tester
currently spits out. Hence my request for duplex serial communication for the larger ATMEGAs.
Therefore wrote separate progs for each component. Currently these progs are
BJT, JFET, MOSFET, OPTO and RES. The prog CAP for capacitors being the last on my list
will be available soon. Still needs to simmer a bit.
Yours - Messtechniker
