Author Topic: $20 LCR ESR Transistor checker project  (Read 5474713 times)
0 Members and 264 Guests are viewing this topic.
Offline TheSteve
  • Living the Dream
« Reply #2150 on: June 29, 2016, 04:43:15 am »
I was sent these three files, they are instructions, schematic and parts location. - I have not yet verified the schematic matches the board.
VE7FM
The following users thanked this post: bitseeker, indman, stj
Offline bitseeker
Offline stj
« Reply #2152 on: June 29, 2016, 05:15:31 am »
i found the top image, but no underside shot.
https://www.eevblog.com/forum/testgear/$20-lcr-esr-transistor-checker-project/msg964111/#msg964111  :-/O
wrong kit - that's the GM328R from EZM studio, i'm looking for the TFT kit with the red pcb. :)
Offline bitseeker
« Reply #2153 on: June 29, 2016, 05:21:38 am »
I see. Unfortunately, that was the only one I saw both sides of. :(
Offline stryker
« Reply #2154 on: June 29, 2016, 05:48:31 am »
Actually there are some Chinese $20 LCR testers that come with adapter for SMT parts for a long while but not as well done and integrated as the russian units.
They do look well constructed - have you bought a russian kit, or from that seller?
Offline indman
  • Country: by
« Reply #2155 on: June 29, 2016, 07:20:15 am »
stj,Look according to this link, here I have all information on this clone and the photo.
https://yadi.sk/d/SPMZccK-smKEf    ;)
Offline imidis
« Reply #2156 on: June 29, 2016, 08:12:32 am »
So, I don't know about the EZM studio, this is mine (see attached)
« Last Edit: June 29, 2016, 08:19:34 am by imidis »
Gone for good
The following users thanked this post: stj
Offline stj
« Reply #2157 on: June 29, 2016, 10:40:30 pm »
that's what i was after - thanks.
i wanted to see where the smd protection diodes were fitted.
i also see a big space along the top edge - perfect for a 10pin programming header - perfect.
well almost - they should have included it in the design along with a 16MHz crystal.  :palm:
Offline bitseeker
« Reply #2158 on: June 29, 2016, 10:41:50 pm »
Yeah, I was a bit surprised that after including the protection diodes, etc., that they didn't use a 16 MHz crystal. Odd.
Offline imidis
« Reply #2159 on: June 30, 2016, 06:30:18 am »
Glad to help  :) , it also had me fixing on solder point and cropping off a a piece that was bothering me LOL, the things you notice in photos.
That would have been nice indeed. Got it from a seller alicehappy on ebay, it took 38 days to get here from HK for around 13 US.
Gone for good
Offline all_repair
« Reply #2160 on: June 30, 2016, 08:05:05 am »
I got 3 Chinese LCR meters now.  So the next one need to have a big improvement to justify for my space.  I did bought a ESR meter from the Russia seller before.  Form factor is good, but has no input protection and my 2nd carelessness of putting a 12-50V charged cap killed it totally.
Offline Willem52
« Reply #2161 on: June 30, 2016, 09:57:11 am »
Got my M328-KIT-CTFT working after getting a replacement M328p IC.
Indeed, they used the older 1.12k firmware.
I would like to see the newer versions with color settings too :)
Here some pictures I took when I got the kit.
Offline madires
  • A qualified hobbyist ;)
« Reply #2162 on: June 30, 2016, 12:57:41 pm »
That's something for the ATmega664 or 1284. I'll put in on the to-do list just below touch screens ;) With the ATmega 664 we have enough pins (and flash memory) for driving touch screen controllers.
Offline indman
  • Country: by
« Reply #2163 on: June 30, 2016, 01:21:49 pm »
Hi, friends! Karl-Heinz Kubeller made new revision of a firmware of SVN 681 for a clone of M328KitTFT which allows to set up font color and back color through the menu. :-+
Offline hapless
« Reply #2164 on: June 30, 2016, 05:18:33 pm »
Wow, a lot going on on the inputs. Makes me wonder how high the stray inductance and capacitance are on this one. Also, what's the power consumption? Something tells me that a regular 9V battery won't survive very long in it even if the crystal remains at 8MHz, let alone 16.
Offline imidis
« Reply #2165 on: June 30, 2016, 05:26:11 pm »
About 23.27 mA
Edit, modified with average
« Last Edit: July 01, 2016, 09:23:33 am by imidis »
Gone for good
Offline hapless
« Reply #2166 on: July 01, 2016, 02:41:05 pm »
Backlit color LCD + MCU with <25mA average during testing? OK, color me impressed.
Offline jasonmrc
  • Country: mt
« Reply #2167 on: July 01, 2016, 09:54:31 pm »
I bought the same kit and i was sent the same files. looking at the schematic , the battery is wired funny/ wrong . both terminals looks like they are being shorted ..
i am looking in designing a case for this little test equipment .. and print it later !
Offline jasonmrc
  • Country: mt
« Reply #2168 on: July 01, 2016, 10:19:05 pm »
look here if you want the english version
https://github.com/svn2github/transistortester
Offline stj
« Reply #2169 on: July 02, 2016, 06:11:34 am »
given the present space situation,
i wonder how much bytes extra are needed for the colour display.
also, i'm sure most of you have seen the one sold by TomTop with a multi-colour display - be nice to get the code from that!
Offline madires
« Reply #2170 on: July 02, 2016, 10:45:06 am »
Not much (directly), but driving the display becomes slow because the firmware has to send a lot more of data. For a monochrome display it's a byte for 8 dots. For a color display it's a color value (12-18 bits) for each dot. And since color displays usually got more dots anyway, it becomes even more worse. That also requires a larger font which increases the firmware size indirectly.
Offline stj
« Reply #2171 on: July 02, 2016, 05:53:56 pm »
well that's an issue, i am already at the point of limiting the font size to keep the serial port.
Offline Willem52
« Reply #2172 on: July 03, 2016, 08:38:09 am »
What would just upgrading to a 16MHz clock do...
It could help a lot in this situation, not?
Offline madires
« Reply #2173 on: July 03, 2016, 11:16:37 am »
Not a lot, it's just a factor of two :) If you like to get an impression about the issue please watch a full screen clear for an ILI9341 based LCD. Anyway, a 16MHz crystal will also help with several measurements (inductance, capacitance, frequency) and the squarewave gen. And both firmwares support 16MHz for a long time now. Actually I'm surprised that most clones still got 8MHz crystals.
Offline stj
« Reply #2174 on: July 04, 2016, 07:17:25 am »
i would like to see someone work out the delays needed to run the atmel at it's rated 20MHz myself :)
