Author Topic: 4ch 100MHz 1GS/s per channel cheap-o-scope  (Read 16154 times)
Offline MrWolfTopic starter
  • Country: ee
« on: November 02, 2016, 10:26:18 am »
Hello,
usually I mess around with low frequency and have been spoiled by having excessive resolution of waveforms. But specific task has emerged that will require 4 channels, at least 100MHz and most importantly at least 1GS/s on all channels at the same time.
Currently I have 25MHz PicoScopes and no real complaints about them. They do take abuse and software is feature-packed (FFT!). Initially I wanted to buy PicoScope 2408B or Rigol DS1054Z  (and hack it), until I realized that instead of being cheap-o-scopes these are actually fake-o-scopes because they are only 250MS/s on 4ch and 100MHz - which is basically a sad joke, not scope.
After quite a bit of search I found that only (?) cheap-o-scope doing full 1GS/s on 4 channels is Tek TBS1104, but it hopelessly outdated otherwise (low memory etc).
Proper PicoScopes start at €2,795.00 with 6402C, but this is out of budget currently (about €1500 max).
I do like (toy-o-scope  :P) GW INSTEK GDS-2204E (has FFT!) but its only doing 500MS/s with all ch in use.
Currently almost out of ideas. Maybe buy two of something 2ch with trigger in-outs and  sync but this will probably go out of budget.
Used stuff do not like, only maybe refurbished with new knobs. Do not like knobs that have been rubbed by someone else :(
Maybe TBS1104 low mem is not an issue at full tilt since there is only 10 samples per wfm anyway?
Almost forgot - there must be option do display non-interpolated raw waveform. 10 samples per wfm is not much and when interpolated all the useful info will be lost for good.
« Last Edit: November 02, 2016, 10:28:19 am by MrWolf »
Offline rf-loop
Re: 4ch 100MHz 1GS/s per channel cheap-o-scope
« Reply #1 on: November 02, 2016, 10:44:12 am »
SDS2104X all 4 channels on 1GSa/s for all channel. 2 channels on, 2GSa/ch
Also enough memory for most use,
Powerful fast segmented memory acquisition.
Always backround working Waveform history buffer.
In your budget due to factory offer.
Also it keep raw data independent of interpolation and display settings.
I drive a LEC (low el. consumption) BEV car. Smoke exhaust pipes - go to museum. In Finland quite all electric power is made using nuclear, wind, solar and water.
Wises must compel the mad barbarians to stop their crimes against humanity. Where have the wises gone?
Offline TopLoser
« Reply #2 on: November 02, 2016, 11:02:45 am »
Keysight DSOX2004 hacked up to 200MHz does 1GS/s on all 4 channels and is way under your budget.
Offline Ice-Tea
    • Freelance Hardware Engineer
« Reply #3 on: November 02, 2016, 11:10:13 am »
Or you could, you know, get an older scope from a reputed brand with the specs you need...
*whistles innocently* :popcorn:
  • Country: ee
« Reply #4 on: November 02, 2016, 11:11:56 am »
Thats good news about SDS2104X, I actually looked at it but important info in datasheet was only in fine print (missed that) so I decided that it is probably only 500MS/s and went searching further. Since this is selling point they should make it more prominent in datasheet I think...
Also I think people should stop buying substandard fake-o-scopes and just push them out of the market. Dave makes some good points in this old video:
Sadly seems that many newbies do not realize this and go for products based on analog front end rating only (almost did fall for that).
Offline JPortici
« Reply #5 on: November 02, 2016, 11:26:38 am »
but they are cheap! and can get the job done.
And they are 100 MHz scopes.
You don't use a 100 MHz tool for a 100 MHz signal. 5-10 times the bandwidth and the adequate rise time if you want to have a good approximation of a square wave.
Offline tggzzz
« Reply #6 on: November 02, 2016, 11:41:50 am »
Why is 1GS/s important to you, given the 100MHz spec? Often it is better to concentrate on the risetime.
You don't mention whether the signals are repetitive or single-shot, nor whether it is necessary to export waveforms to other devices.
The following users thanked this post: Kilrah
Offline rf-loop
« Reply #7 on: November 02, 2016, 11:46:28 am »
No. Absolutely not. It have 1GSa/s for every single channel simultaneously when all 4 channels are on.
There is 2 channel group.
I
CH1 + CH2 they have one 2x1GSa  Analog devices ADC. If one of these channel is in use ADC work in single 2GSa/s mode.  140M memory.
II
CH2 + CH3 they have one 2x1GSa  Analog devices ADC. If one of these channel is in use ADC work in single 2GSa/s mode. 140M memory. 140 for one channel and 70 per channel if both are in use.
If there is in group I or II both channel on, then other group can use only 1GSa/s even if in this group only one channel is in use.
(principle is that channels in use at same time, can use only same speed)
If select group I  one channel in use and group II  one channel... both can use 2GSa/s and both have max 140M acquistion memory (+ more for waveform history buffer, what principle is explained more in SDS1000X thread. Same principle in SDS2000X but 2kX have lot of more processing power and memory)
Also about many information in web. You need really be careful because most of informations are Obsolete. And if you look some videos, even from Dave, be careful and keep in mind there is many kind of "user errors".   Also many times there have been perhaps even many FW updates after these some videos.
« Last Edit: November 02, 2016, 12:04:45 pm by rf-loop »
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #8 on: November 02, 2016, 12:01:02 pm »
Another alternative is the DS4014E, which goes up to 2GSPS per channel and is around €1.6k.
If I am not mistaken, the GW Instek GDS2104A has 1GSPS per channel at 100MHz. At €1.3k it fits in your budget.
  • Country: ee
« Reply #9 on: November 02, 2016, 12:22:43 pm »
No plans to use it for digital signal tinkering. Analog sine-waves in 50...100MHz range with phase shifts involved. Basically want to learn about transmission line stuff in freq area where lines are getting reasonably short for experimenting. If I can get general picture at 4ch 1GS and pinpoint more exactly at 2ch 2GS will be more-less on top of things. With stable signals can even enable ETS and get hires. However I do realize that this is absolute minumum tech for this... But you do not spend big bucks in area where you are novice. Upgrade to GHz gear after year or two learning curve...
  • Country: ee
« Reply #10 on: November 02, 2016, 12:43:24 pm »
CSV export would not hurt. Signals analog, modulated, repetitive eg transmission line suff. Replys got me thinking maybe should go for 200MHz, 1GS. In some cases seems to fit in budget.
Offline Ice-Tea
« Reply #11 on: November 02, 2016, 12:55:01 pm »
Or, you know, 1GHz, 4GSa/S
*Whistles some more*
Offline Fungus
« Reply #12 on: November 02, 2016, 01:03:49 pm »
Later on you'll find out that 250MS/s is the correct sample rate for sampling 100MHz signals and then you'll realize that your post is embarrassing.
That specification makes no sense.
Offline tggzzz
« Reply #13 on: November 02, 2016, 01:27:04 pm »
In that case you really want a TDR. A Tektronix 1502 will enable you to resolve small impedance changes 2cm apart. That's a system risetime of  140ps, roughly equivalent to 2.5GHz - and you get a 50ps step generator included.
See https://entertaininghacks.wordpress.com/2016/08/30/a-traditional-tdr-cable-tester-with-2cm-resolution/ for pretty pictures.
Its primary use is finding small and large problems in cables and connectors and PCBs, or cable length, or dielectric constant. Let me know offline how much you would pay for a working example, because I have a spare one for sale :) I'll see if anyone wants it at a hamfest on Sunday
N.B. my spare is the "normal" variant, calibrated in feet and inches, sigh!
Offline EEVblog
« Reply #14 on: November 02, 2016, 01:46:53 pm »
Will you ever use the full 100MHz bandwidth on all 4 channel simultaneously?
  • Country: ee
« Reply #15 on: November 02, 2016, 05:16:47 pm »
Has it occurred to you that I have actually tested my scenarios at lower frequencies with exactly matching analog freq / sample ratio? Findings conform exactly to that old EEVBlog video. "Fatal data loss" occurs at about 10 samples per wave for basic sine wave. So in short you are saying that owner of this blog is talking BS in that video. Way to go.
Barely enough for starters. Monitoring for both voltage and current tends to eat up channels fast...
  • Country: ee
« Reply #16 on: November 02, 2016, 05:38:19 pm »
Advice is correct but as ex-CCCP citizen Im used to making fine carpentry with axe ;)
Offline JPortici
« Reply #17 on: November 02, 2016, 06:33:36 pm »
oh get that sweet lecroy of his already ;)
  • Country: ee
« Reply #18 on: November 02, 2016, 06:56:26 pm »
This kind of stuff will come after I had my way with something fresh and probably chinese. Also not very portable... forgot to mention portability req because all the low-end stuff is pretty portable nowdays...
...ok who Im fooling - Its too big to hide from my wife in small apartment   :-//
Offline JPortici
« Reply #19 on: November 02, 2016, 07:14:13 pm »
the lecroy can be disguised as a vintage tv  :-+
or a futuristic microwave  :-//
get creative
anyway measuring sine wave phase shift.. is a scope the correct tool? and i think you'd need a lot higher bandwidth than the signal as i believe the input antialiasing filter is not gaussian.. sure is not on old DSOs or cheap modern DSOs, with lower samplerate-bandwidth ratio.
Is the input channel bode plot even provided on higher end scopes?
Offline Ice-Tea
« Reply #20 on: November 02, 2016, 07:27:58 pm »
But... It has a carying handle! And you can use it as a boat anchor!
I see your point, though ;)
Offline Fungus
« Reply #21 on: November 02, 2016, 07:54:43 pm »
Which video? What 'scope?
Offline rsjsouza
  • Eternally curious
« Reply #22 on: November 02, 2016, 08:15:41 pm »
Fungus, the video is linked above.
Regarding analog bandwidth versus digital sampling rate, there are many discussions in this forum (here, here and here for example) with varying degrees of experience and opinion, with the offending pissing contest and mud flinging... :)
Offline nctnico
« Reply #23 on: November 02, 2016, 09:09:25 pm »
Just clean the knobs and they'll look as new. Easy job for the amount of money you save. Perhaps your best paid job ever! If you don't need protocol decoding then there are many choices out there on the second hand market.
Sorry but no information gets lost due to interpolation. Interpolation is there to make the signal interpretable with our eyes. Just read about the Nyquist theory and you'll learn that 10 times oversampling is overkill and you won't get any extra information. Just more money gone from your wallet.
Perhaps you could elaborate on your other requirements. You mention FFT but are they other things which are important like connectivity, math, measurements, filtering, etc?
« Last Edit: November 02, 2016, 09:13:18 pm by nctnico »
Offline Someone
    • send complaints here
« Reply #24 on: November 02, 2016, 11:18:12 pm »
You forgot this epic thread too: https://www.eevblog.com/forum/testgear/will-keysight-upgrade-the-2000-3000t-x-series-oscilloscopes-within-a-few-months/?all
I would like to live in your magical world where measurements have no noise in them and the front end antialias filters are perfect, the rest of us will happily continue buying scopes with sample rates 5-10x higher than required by nyquist (or more!).
The following users thanked this post: rf-loop
