Author Topic: #53 HP 410A vtvm repair part 1  (Read 5819 times)
Offline Radio TechTopic starter
  • KC4UMO Buddy
    • Hobby Forum
« on: May 29, 2016, 01:52:45 am »
In this video we go through this old HP 410a VTVM and replace all the paper capacitors.
We also have to fabricate a new DC probe since the original is damaged.
Manual link:
http://www.hparchive.com/Manuals/HP-410A-Manual.pdf
Capacitors and resistors:
http://www.justradios.com/
Link to Diode modification kit:
http://gokarters.com/smf/index.php?topic=2579.msg18393#msg18393
  • KC4UMO Buddy
    • Hobby Forum
Re: #53 HP 410A vtvm repair part 1
« Reply #1 on: May 29, 2016, 02:15:33 pm »
So I got lucky today and was rambling through some old parts drawers. I found a pack of 20 meg resistors. I went through them and found one that read 22.1 ohms. The DC probe is now complete. I can now troubleshoot the ohms setting and complete this unit.
Offline xrunner
  • hp>Agilent>Keysight>???
« Reply #2 on: May 29, 2016, 02:30:58 pm »
Very interesting I'll be following this.  :-+
  • KC4UMO Buddy
    • Hobby Forum
« Reply #3 on: May 29, 2016, 02:50:19 pm »
Thanks. Since I have the DC probe fixed up I am ready to dive back in and get the ohms setting working.  I really like this meter and want to fabricate a RF adaptor for it. This turns the meter into an RF power meter and should be able to read very low wattage. I saw a video from Mike at mikesradiorepair on YouTube demonstrate this. Lets see if I can find the link....
Offline xrunner
« Reply #4 on: May 30, 2016, 12:32:40 pm »
So is the tube in the probe down-converting the RF or just amplifying it for the meter?
  • KC4UMO Buddy
    • Hobby Forum
« Reply #5 on: May 30, 2016, 03:05:22 pm »
The tube is a 2-01C. This is a low capacitance high frequency diode. Sort of like a geranium.
This acts as a shunt diode circuit.
Offline TimFox
« Reply #6 on: May 30, 2016, 04:21:18 pm »
The 2-01C is literally a "hot" diode, with a substantial current at zero voltage due to the high cathode temperature.  Some 410A's have a second vacuum diode inside the box to compensate for the DC offset, but others used a solid-state diode.
The polystyrene end cap on my 410A is cracked, and I haven't been able to glue it successfully.  Do you have any suggestions?
I have a coaxial through-line adapter that the probe fits with the cap unscrewed.
  • KC4UMO Buddy
    • Hobby Forum
« Reply #7 on: May 31, 2016, 05:19:48 pm »
Mine has the tube inside also. But I have the diode modification kit installed.  This eliminates having to use matched tubes and the kit uses a balance tube.  I worked on part two of the video yesterday and hit a brick wall. Ohm scale now works but lost AC and DC scales. Meter creeps and pegs. After checking filament voltage for V1 and V2 I found the voltage was below 3 volts and the transformer is getting very hot.  So now have to troubleshoot this issue.
Polystyrene is almost impossible to glue back together. Perhaps there is a way to thermal weld this. Will have to look into that.
Offline xrunner
« Reply #8 on: July 02, 2016, 12:24:20 am »
Any news on the project?
  • KC4UMO Buddy
    • Hobby Forum
« Reply #9 on: July 02, 2016, 12:45:53 am »
Waiting on an order. Had a tube that was bad. Hope to have it next week.
