I don't think a 50 Ohm termination is proper. I think high impedance is what you want. If you still insist on 50 Ohms you certainly need a blocking capacitor or you will damage the terminator in the oscilloscope.
Ripple, especially if small, isn't measured casually. You will need to be precise in your connection of the oscilloscope, especially the ground lead.
Next question is:
In the AN-1144 document is described this method by adding external blocking capacitor and using an internal 50 ohm terminating in oscilloscope. Why?
Every oscilloscope that it has 50 ohm terminator also has blocking capacitor inside, therefore it just AC mode, isn't it?.
Why do they suggest add next external blocking capacitor?
QuoteEvery oscilloscope that it has 50 ohm terminator also has blocking capacitor inside, therefore it just AC mode, isn't it?.I don't know about "every" and neither do they.
They are also including Spectrum Analyzers not just oscilloscopes.
When the difference between "hoping" DC will get blocked and "knowing" you are blocking it , is one capacitor, use the cap!
inputs on scopes don't have a DC blocking capacitor and are DC coupled, which usually limits the maximum DC input voltage to around 5V to avoid excessive power dissipation in the 50
termination resistor. If you did have a DC blocking capacitor in the scope you would need a really large one (some 10's of uF) to get any sort of useful low frequency (<1kHz) response . Such large capacitors have a lot of undesirable parasitic elements eg. inductance that are not conducive to accurate measurements at higher frequencies where the 50
input termination is normally used.
probe would be usually sufficient unless you are interested in measuring noise components >100MHz where the 50
termination will give better signal fidelity and more accurate measurements. With a 10M
probe selecting AC coupling on the scope input has much less effect on the low frequency response and you can still get good measurements down to low frequencies (<10Hz). However, obtaining good signal fidelity and accurate noise measurements with a 10M
probe requires careful attention to the grounding of the probe: use the shortest possible ground lead on the probe and connect it as close as possible to the circuit point where the signal is being measured.
input with no internal blocking capacitor. The input to a spectrum analyzer can't tolerate any DC voltages as even a small DC voltage (<1V) can destroy the input mixer diodes. This is why the connection diagram shows the blocking capacitor as this is essential for the spectrum analyser. You could go even further and add a power limiter to spec analyser input to protect against the voltage spike that occurs when the DC blocking capacitor charges up. Such a power limiter would be recommended if the PSU under test has an output >10V. Otherwise set the input attenuation on the spec analyser to its maximum level to protect the mixer diodes.
Generally 50inputs on scopes don't have a DC blocking capacitor and are DC coupled, which usually limits the maximum DC input voltage to around 5V to avoid excessive power dissipation in the 50
Measuring PSU noise with a scope using a quality 10Mprobe would be usually sufficient unless you are interested in measuring noise components >100MHz where the 50
The situation with spectrum analysers is different; these almost always have a fixed 50input with no internal blocking capacitor. The input to a spectrum analyzer can't tolerate any DC voltages as even a small DC voltage (<1V) can destroy the input mixer diodes. This is why the connection diagram shows the blocking capacitor as this is essential for the spectrum analyser. You could go even further and add a power limiter to spec analyser input to protect against the voltage spike that occurs when the DC blocking capacitor charges up. Such a power limiter would be recommended if the PSU under test has an output >10V. Otherwise set the input attenuation on the spec analyser to its maximum level to protect the mixer diodes.
QuoteThe situation with spectrum analysers is different; these almost always have a fixed 50input with no internal blocking capacitor. The input to a spectrum analyzer can't tolerate any DC voltages as even a small DC voltage (<1V) can destroy the input mixer diodes.
This may be the case with some SA's or older boat anchor models but it is not the situation with many recent offerings to the marketplace as they often have 50V max input ratings due to DC blocking caps on their inputs which also serves to provide some quite reasonable electrostatic protection.
I think as soon as the frequency range is too large, they just drop the cap. Implementing DC protection from 5Khz to 26Ghz would be tedious.
For example the Keysight N9040B 3Hz - 50Ghz
It's commonly overlooked that a PSU rail is a low impedance source and as such ripple is adequately measured with 1x probe which in turn displays any ripple better as it's un-attenuated.
...Yes well few of us have even seen a 50 GHz SA let alone it's inputs.
This is a typical input setup of one of Siglent's SA products in the 1.5 - 7.5 GHz range.
A DC blocking capacitor by itself will not provide any protection against electrostatic discharge. The fast rise time of these transients will be coupled straight through the capacitor. To achieve some ESD protection you need some fairly severe low-pass filtering to eliminate the fast transients (not a useful technique on a SA!) or some transient suppressor diodes or diode clamping circuitry to bypass the transient away from sensitive inputs.
For reference, the blocking capacitor shown in the AN-1144 is a Hewlett & Packard 10240B. Google should reveal a datasheet for it. The internal capacitor is a 0.18uF with a voltage rating of +/- 200V.
Hello, I'm looking for the best method for measuring voltage ripple.
I've read document from Analog Devices AN-1144.
I intend to use 50 ohm terminated line of oscilloscope, but my oscilloscope doesn't have it. Therefore I design dc blocker and 50 ohm terminator.
(Attachment Link)
And when I use my design for two channels of oscilloscope by Dave's recommendations https://www.youtube.com/watch?v=Edel3eduRj4&t=1951s, I get best results.
Will it work?
Next question is:
(Attachment Link)
Thank you
You should be aware that a simulation in SPICE does not always accurately represent the actual results that will obtained in real world measurements. This is because the component models often don't exactly simulate some of the real behaviour of physical components.
From your simulation graph I gather that you have used a 10uF coupling capacitor and from the PCB design it appears to be a ceramic cap in a 2220 package. If this cap is rated at 50VDC then it would have to be an X7R dielectric or similar to fit in this package size.
X7R dielectric is great for bypassing applications but is less suitable for signal coupling applications such as this. The main problem is that the capacitance of X7R types varies quite considerably when DC voltage is applied across them; at their full rated voltage they typically lose 50% of their capacitance. This has the effect, as the DC voltage across capacitor increases, of increasing the LF cut-off frequency of your coupling circuit.
Another effect of the voltage dependence of X7R is that it introduces harmonic distortion to a signal, particularly at lower frequencies where a greater proportion of the signal voltage appears across the capacitor.
Ideally, you would use a ceramic capacitor with a C0G dielectric in this application as this doesn't exhibit the voltage dependency of X7R and also has better temperature stability and lower losses. However, a 10uF 50V C0G ceramic capacitor will be quite large and eye-wateringly expensive.
