Ok, it looks as though, if i were to measure a 2.048v level, i would get between 2.0473 and 2.0486. Thats going to be much better than my current meter. Which is only 2000 count, much lower accuracy, and only 2 decimal places in the 20v range. Just looked at the specs, thats 1.5% +4d, I could expect to read between 1.97 and 2.12 or there abouts. In any case, a serious upgrade.
Im not (quite) a beginner. I did a degree in computer systems engineering 20 years ago. Although i followed a career in music, since leaving university I got into building hifi and analogue synthesisers.
Im currently developing a digital control system for an analogue poly synth and Im just finding myself needing to get a better idea of what value the components and voltages Im cobbling together actually is.
Id like a better scope, but that's on hold at the moment. But being able to read voltage and frequency in particular, reasonably accurately will go a long way to help me fine tune and figure whats what. Itll be using substantially less than 1v/oct internally, probably nearer 0.4v/oct which in tern means 33mV per semitone. My current scope and meter just aren't really up to this. I want this to work reasonably well before software correction.
I just haven't bought decent test equipment before and wanted some advice over getting one of these devices stock or whether i should get them calibrated. But having seen the photos of several of these next to higher end bench measurements, I fairly sure this will meet my needs.
