Author Topic: DSOX2000 and 3000 series - licence , have anyone tried to hack that scope ?  (Read 1674783 times)
0 Members and 15 Guests are viewing this topic.
Offline EE-digger
Much appreciation for the great work  :-+   Tested on 7.20.  You must use the launcher from the version you are using, if it is not 7.10.  Also, I performed the cmd operations manually but they look correct.  LAN settings appeared as zeros until 2nd boot.
The following users thanked this post: mlloyd1, Andrew, JeffreyLatter
Offline gamalot
  • Correct my English
    • Youtube
I am slowly getting familiar with my first 3D printer.  :)
I'm a poet, I didn't even know it. |  https://youtube.com/@gamalot | https://github.com/gamalot
The following users thanked this post: Andrew
Online PlainName
Nice  :-+
Offline Safar
  • Country: ru
Re: DSOX2000 and 3000 series - licence , have anyone tried to hack that scope ?
« Reply #1778 on: January 18, 2018, 12:08:46 am »
Color like... first channel. Hope you will make three else in known colors :))
BTW how your USB converter?
« Last Edit: January 18, 2018, 12:10:52 am by Safar »
Offline KrudyZ
Looks very nice.
How do you remove it from the housing, since the spring clips don't look accessible from the outside?
Offline gamalot
    • Youtube
Nice  :-+
Thank you  :)
There will be hig-tech silver grey and EEVBLOG blue.  :)
It's a USB to UART converter connect to the console port on main PCB.
Looks very nice.
A slotted screwdriver or something like that will help.  :)
Offline Safar
  • Country: ru
Yes, I remember.
I mean that you fed it from the PC side in last version.
Offline gamalot
    • Youtube
This version is isolated, so I feed them from both side.  :)
Offline Safar
  • Country: ru
Yes, I see. Very interesting. For what 3d isolated channel?
Offline gamalot
    • Youtube
There will be a problem if it's not isolated.
When the USB port has been connected to PC and oscilloscope has been turned off, the oscilloscope will steal power from the STM32 MCU I used as converter.  :(
Online mikeselectricstuff
    • Mike's Electric Stuff
You don't need isolation, just a series resistor to limit current drawn by the TXD line.
Day Job: Mostly LEDs
Offline gamalot
    • Youtube
I  believe that your solution should work very well, but for me things are a little bit different, usually I power my oscilloscope from an isolation transformer (I know it's not recommended for safety reason but I hardly touch any dangerous voltages) :)
« Last Edit: January 18, 2018, 01:58:19 pm by gamalot »
Offline PixieDust
Hi Guys,
Interested in the 2000 X. Can someone give me the cliff notes for this thread? 72 pages will probably take a week to read from start to finish.
I'm looking at this:
https://www.keysight.com/en/pcx-x205206/infiniivision-2000-x-series-oscilloscopes?cc=US
for reference about features.
« Last Edit: January 30, 2018, 01:23:15 pm by PixieDust »
Offline TK
Hi Guys,
I think this thread is mostly for hacking the DSOX2000 and 3000 series... I don't recall reading anything about features
Offline rkupka
  • Country: sk
You can find very thorough review and teardown videos on  EEVBlog  Youtube channel.
Offline PixieDust
Yes, that's what I'm interested in, to see whether people have managed to unlock the features.
Offline TheSteve
  • Living the Dream
All the info you need is in the thread - reading it all will take a long time. Probably worth it all though for 3K + in "free" features. Maybe start with the last 20/30 pages, it will have the most up to date information. Be sure to understand any changes you are making before you do it to prevent a brick.
VE7FM
Offline TK
Read the thread backwards.  You will find the latest hack method around page 60-65
Page numbers are meaningless as they depend on the user's posts-per-page setting - use post numbers
Offline TK
@mikeselectricstuff, you are right.  Post number 1529 shows the steps and includes the link to download the CAB file.  Read from there forward and backward to get some background information about the hack.
The following users thanked this post: Andrew, 77Ribetts
Offline EE-digger
« Reply #1795 on: February 03, 2018, 04:10:36 pm »
Google the apps bundle for the 2000 x to learn about the features.  If you read the thread, you'll get extra joy out of it  :)
Offline salvagedcircuitry
  • Electrical Engineer | Hobbyist | Camera Enthusiast
    • salvagedcircuitry
« Reply #1796 on: February 04, 2018, 07:14:56 am »
Is it still best to attempt this hack through the USB method and keep 2.35 firmware: (https://www.eevblog.com/forum/testgear/dsox2000-and-3000-series-licence-have-anyone-tried-to-hack-that-scope/msg322242/#msg322242)
or upgrade to 2.41 / 2.42 and use the v241_link_install method: (https://www.eevblog.com/forum/testgear/dsox2000-and-3000-series-licence-have-anyone-tried-to-hack-that-scope/msg1189010/#msg1189010)?
Are there issues with garbage on LAN with the USB method?
I am leaning more toward the USB method as it seems to be less intrusive and reversible.
A friend of mine has a 3034a and I'm lending a hand. 02.35 firmware. no installed licenses. No lan card
Thanks everybody  :-+
« Last Edit: March 01, 2018, 11:31:29 pm by salvagedcircuitry »
Offline Safar
  • Country: ru
« Reply #1797 on: February 05, 2018, 09:44:47 pm »
LAN garbage issue will be in any FW when you try start scope app (infiniivisionLauncher.exe) with keys. Any hack method do this actually.
For eliminate this issue you should patch infiniiVisionCore.dll.
Not sure about 2.35, but 2.41 and 2.42 patch methods still in this topic. Think is better to use for search "infiniiVisionCore.dll".
infiniiVisionCore.dll in 2.41 packed in FW as File and in 2.42 packed as Module, so methods and patch addresses is differ.
I patched 2.42 in nk.bin directly, and flashed it to scope via LAN telnet command, but hope that is possible just replace nk.bin in CAB file and flash scope as usually. And ksx file in 2.42 is cab actually, so just rename it.
But anyway LAN strongly recommend for use these patches.
The following users thanked this post: Andrew, salvagedcircuitry
Offline Pinkus
« Reply #1798 on: February 05, 2018, 11:01:44 pm »
and remember, at scopes with firmware versions below 2.4x the flash will be corrupted after RND(TIME). The scope will not boot anymore and is bricked and needs to be serviced by Keysight. After firmware 2.4x the scope will detect this and repairs itself .... somehow.
Thus with 2.35 or 2.38 there is the constant danger, that your scope (DSOX2000a and DSOX3000a series) won't boot anymore at some day.
« Last Edit: February 05, 2018, 11:03:46 pm by Pinkus »
Offline TopLoser
« Reply #1799 on: February 05, 2018, 11:10:19 pm »
Since firmware version 2.4x I haven’t seen a single 2000 or 3000 series scope as a customer return, they seem to be incredibly robust and reliable now. Keysight certainly sorted any problems out and have exceptional customer support.
I’ve seen quite a few new R&S RTB 2000 series ones being returned with issues though, they seem to be having some teething problems. Good warranty support from R&S as well though.
