Author Topic: DSOX2000 and 3000 series - licence , have anyone tried to hack that scope ?  (Read 1682174 times)
a23633238 and 39 Guests are viewing this topic.
Offline Alanme
  • i am not perfect but i know that
Re: DSOX2000 and 3000 series - licence , have anyone tried to hack that scope ?
« Reply #2000 on: September 04, 2018, 02:27:31 pm »
I have not a network card, so i wan't to try with old version, but i don't find them in the web,.
Have you these version please?
Offline TheSteve
  • Living the Dream
« Reply #2001 on: September 04, 2018, 04:29:00 pm »
You will need the network card and a serial console to recover the scope most likely.
Once you connected to the serial console post the output and we'll see where it stops in the boot process. If it is far enough along a USB drive may be able to recovery it but chances are you will need a network card.
VE7FM
Offline Alanme
« Reply #2002 on: September 04, 2018, 06:36:21 pm »
But have you these firmware please?
Offline TheSteve
  • Living the Dream
« Reply #2003 on: September 04, 2018, 06:45:13 pm »
No, I don't have them. But if you look in the firmware release notes for the exact file names of the older releases you can do a google search for them and often find copies.
VE7FM
Online PA0PBZ
« Reply #2004 on: September 04, 2018, 06:48:54 pm »
The oldest I have is 02.35.2013061800
The following users thanked this post: Alanme
Offline Alanme
« Reply #2005 on: September 04, 2018, 06:57:50 pm »
I have do that, i try the chinese site too with google translate
 - - > nothing
Offline Alanme
« Reply #2006 on: September 04, 2018, 07:04:24 pm »
Thank you TheSteeve and Paopbz for help
Offline Alanme
« Reply #2007 on: September 04, 2018, 07:07:45 pm »
Pleasa have them, i send it a PM, but he has not answer me
Offline Alanme
« Reply #2008 on: September 04, 2018, 09:44:52 pm »
I think there is something to do, because the scope boot in the usb stick.
When i put the firmware 2.35 unchanged, the led of the usb key blink a little time and it reboot with red warning, agilent logo and the 1988 2011 in the bottom of the screen.
When i put the 2.35 firmware "modified", the led of the usb stick blink a long time, that mean it load something, and after, the scope stay at blinking cycle without reboot.
When i stop and start the scope, then,  it reboot with red warning, agilent logo and the 1988 2011 in the bottom of the screen.
I don't know how force the scope to upload the firmware.
Maybe someone can do something for me please?
Offline TheSteve
  • Living the Dream
« Reply #2009 on: September 04, 2018, 09:55:00 pm »
For the USB boot to work you need the same version(or very close) that was on the scope before it became corrupted.
Also note you don't need to patch the infiniiVisionCore.dll - that is only to hack the scope to enable features, it is not needed to recover the scope and boot from USB.
You can find the older firmware - but you need to look for the exact file name.
Here is version 2.20 to try:
https://xdevs.com/doc/HP_Agilent_Keysight/DSOX/3000XSeries.02.20.2012110802.cab
VE7FM
Offline Alanme
« Reply #2010 on: September 04, 2018, 10:02:30 pm »
Thank TheSteeve, but i read 3000series and i have a 2000 series
Offline Pinkus
« Reply #2011 on: September 04, 2018, 10:03:16 pm »
I have a version 1.1 (from 2011) for you. Do you have a dropbox or something similar where I can upload it to?
Firmware for 2000 or 3000 series is the same.
Edit: if you want to google, the file name is 3000XSeries.01.10.2011031600.cab
« Last Edit: September 04, 2018, 10:05:47 pm by Pinkus »
Offline TheSteve
  • Living the Dream
« Reply #2012 on: September 04, 2018, 10:04:21 pm »
As Pinkus stated the firmware is the same.
VE7FM
The following users thanked this post: MarkL, Alanme
Offline Alanme
« Reply #2013 on: September 04, 2018, 10:05:26 pm »
Thank the steeve, i try it and i reply
Offline Alanme
« Reply #2014 on: September 04, 2018, 10:17:41 pm »
Hello Pinkus, no i haven't, can you make please a wetransfer?
Offline Alanme
« Reply #2015 on: September 04, 2018, 10:43:21 pm »
That read the usb stick, that say "Finishing update" with 2012" , the scope boot, i have the screen of the scope with this msg"system concerns detected:OSversion is not correct. Please reload system firmware". But when i pull the stick and i push a button the scope restart.
I observ that the usb stick blink when i touch the button, i think the scope read only the firmware in the usb stick.
The system version is 02.20.2012110802
When i pull the usb stick, the scope hang, an i have the warning msg with 2011 version
« Last Edit: September 04, 2018, 10:45:38 pm by Alanme »
Offline Alanme
« Reply #2016 on: September 04, 2018, 11:00:35 pm »
Thanks a lot of Pinkus TheSteeve an Paobz, i have a lot of work, to try all.
Here the link for the firmwares
https://cal.equipment/doc/HP_Agilent_Keysight/DSOX/
Offline TheSteve
  • Living the Dream
« Reply #2017 on: September 04, 2018, 11:06:44 pm »
You can't remove the USB stick after the scope has booted - it is using it for the OS !
You need to put the firmware update file on the same drive and once the scope is booted install it.
VE7FM
Offline Alanme
« Reply #2018 on: September 04, 2018, 11:43:06 pm »
That woooooork guys tank you a lot of👍👍👍👍👍👍👍👍
Im very haaaaaaappy.
Here the procedure:
You must have 2 usb stick because the scope boot in the usb stick.
TheSteeve method in first, that permit to boot the scope with the first usb stick, in my case, 2. 20.202110802 version.
That read the usb stick, that say "Finishing update" with 2012" , the scope boot, you have the screen of the scope with this msg"system concerns detected:OSversion is not correct. Please reload system firmware.
In this state the scope read his OS, in the usb stick.
If you remove the usb stick, the scope hang.
You introduce the second usb stick with original firmware, in my case 2.35 version, go to "utility" , select the. cab, install it, that done!
Thanks thanks thanks 👏👏👏👏👏👏👏👏👏
Offline TheSteve
  • Living the Dream
« Reply #2019 on: September 04, 2018, 11:52:55 pm »
Excellent - you only need 1 USB stick though, just put the update file on the same flash drive as the boot files.
Please be sure to install the newest version 2.43 - it will prevent further NAND memory corruption issues.
VE7FM
Offline Alanme
« Reply #2020 on: September 05, 2018, 12:11:27 am »
TheSteeve, can i "modify" the 2.43 version? If yes, the warning message would be present at any boot?
I have read somwhere that, it not be possible to boot with usb with version after 2.35, i'm afraid 😨
« Last Edit: September 05, 2018, 01:00:55 am by Alanme »
Offline Alanme
« Reply #2021 on: September 05, 2018, 01:31:00 am »
In case of nand corruption
Offline Pinkus
« Reply #2022 on: September 05, 2018, 07:17:04 am »
You NEED to upgrade from 2.35 and below as you are in a constant risk that your scope will be bricked one day due to nand corruption. So an update to 2.4x is strongly recommended.
Though for any 'improvement' of 2.4x firmware you will need a LAN card.
It is all in this thread, probably the last 20-25 pages is all what you need to read.
Offline Alanme
« Reply #2023 on: September 05, 2018, 09:43:37 am »
Yes Pinkus, but i prefered a nand corruption that i can be able to repair with a usb stick,  in place of 2.43 that i must have a lan card
« Last Edit: September 05, 2018, 03:21:58 pm by Alanme »
Offline TK
« Reply #2024 on: September 05, 2018, 11:10:06 am »
You can get a homemade LAN card (without video) for around $25
