Author Topic: DSOX2000 and 3000 series - licence , have anyone tried to hack that scope ?  (Read 1126483 times)
haiming521 and 2 Guests are viewing this topic.
Offline mhsprang
Re: DSOX2000 and 3000 series - licence , have anyone tried to hack that scope ?
« Reply #3125 on: February 14, 2023, 11:56:56 am »
i saw you posted here that your nand flash seems to be corrupted to.
No, it doesn't.
I repaired approx 100pcs dsox2000/3000 with the programmer and no one replacement of nand flash was needed
congrats with the free repair covered by service note))
NAND corruption discussed here refers to corruption of data stored in NAND, not physical chip failure. Reprogramming the scope (seems this is exactly what you have done) with later firmware rectifies the problem. No chip replacement is needed.
I will probably never know what the problem was exactly.
All the symptoms pointed to a NAND flash corruption but I am pretty sure that the firmware was already at 2.65.
I tried all the listed methods in this thread to revive the unit, using V2.35 and V2.65 firmware, to no avail.
I reported this to Keysight, they accepted the unit and offered repair under service note but they did replace the entire front of the unit. So essentially I have a new 2014A. Customer Service Report states:
"Your instrument was repaired by core exchange. Firmware updated and device adjusted and checked". Serial number and rear housing remain unchanged."
Whether the NAND flash was just corrupted or damaged, I don't know. The repair report didn't mention that.
Offline Reprobyte
« Reply #3126 on: February 16, 2023, 12:19:52 am »
I am happy to say that I now have a DSOX2002A fully kitted out, thanks to everyone here who has contributed over the years, it's been a good read. And thanks very much to the forum user who helped me out getting it sorted and the advice, much appreciation!
Offline grafmar78
    • My github profile
« Reply #3127 on: February 21, 2023, 10:23:33 am »
Hi, i've some news about unbrick the 4000A series..(maybe someone know that  :-+)
Inside the cab 7.31.2020012900 there is a special bin , named "recover.nk.bin.comp" you can decompress and than convert into  "recover.nb0". With that you can use teraterm and load with YMODEM and command "loady 0x0361000 115200"
Thanks for the hint.
I unbricked a 4024A using the recover.nk.bin.comp from the 4000X.7.56.2022120229.ksx file (renamed to .cab). I used TFTP to upload the file. Now it boots again  :-+
The following users thanked this post: HighVoltage
Offline mlloyd1
« Reply #3128 on: February 23, 2023, 03:32:34 am »
thanks for sharing!
does anyone know if this approach works for 3000T series models also?
mlloyd1
Offline TheSteve
  • Living the Dream
« Reply #3129 on: February 23, 2023, 04:02:06 am »
The 3000T series .ksx file is packed(or perhaps encrypted) in some manor. I'm not aware of anyone who has successfully unpacked it.
VE7FM
Online switchabl
« Reply #3130 on: February 23, 2023, 10:00:35 am »
The 3000T .ksx is still just a renamed CAB archive, expand.exe that comes with Windows seems to handle it just fine. I can see there is a recover.nk.bin.comp, so I guess it might be worth a try.
The following users thanked this post: analogRF
Offline wp_wp
  • Country: cn
« Reply #3131 on: February 23, 2023, 12:44:53 pm »
Hi
I have a DSOX3034A,and I got the following info by serial port:
U-Boot 2010.03 (Oct 18 2011 - 14:28:06)Agilent P500
CPU:   SPEAr600
DRAM:  128 MiB
Flash: 512 KiB
NAND:  fsmc-ecc1 128 MiB
In:    serial
Out:   serial
Err:   serial
SerNum:serial number not programmed
Chip:  BD Board Rev: 4
Net:   smsc
Press space to stop autoboot:  0
## Booting kernel from Legacy Image at f8050000 ...
   Image Name:   PBOOT
   Created:      2015-05-07   8:18:27 UTC
   Image Type:   ARM Linux Kernel Image (gzip compressed)
   Data Size:    37749 Bytes = 36.9 KiB
   Load Address: 00000000
   Entry Point:  00000000
   Uncompressing Kernel Image ... OK
Starting kernel ...
Debug serial initialized ........OK
RTC: 2023-2-23   20:36:4.55 UTC
Microsoft Windows CE Bootloader Common Library Version 1.4 Built May  7 2015 01:38:03
Microsoft Windows CE 6.0 Ethernet Bootloader for the Agilent P500 board
Adaptation performed by Agilent Technologies (c) 2008
System ready!
Preparing for download...
RTC: 2023-2-23   20:36:4.59 UTC
 Loading image 1 from memory at 0xD0600000
LLD_GetInfo::Device parameter page is not ONFI compatible!
So,what does "Device parameter page is not ONFI compatible!" mean?
How can I solve it?
Offline grizlikoff
  • Country: ru
MSOX-3034A fixed need
Offline grizlikoff
  • Country: ru
Hi guys! I have MSO-X 3034A ( 4 Chanel , w/o LAN and VGA)
FW 02.50.2019022736
Installed License MSO, SGM, EDK, WAVEGEN, DVM, RML
How to unlock other tools?
Offline grizlikoff
  • Country: ru
Ok. Thx for my freind allredy done. PM if you need some one.
Offline grizlikoff
  • Country: ru
Another question - can any one explain ho to decod SMBUS? i2C - workin but SMBUS not
Offline maurit
I have some cards available if you are interested,
I sell, DSOX-Lan card for Agilent Keysight MSOX DSOX 2000 3000 InfiniiVision Series oscilloscope,
 for Debugging and add Options.
This interface is HOMEMADE, new and professionally built on gold plated printed circuit boards and 3D printing plastic frame.
45,00 Euros plus shipping costs.
I ship worldwide from Italy.
Thanks for watching.
maurizio - Italy
Ebay Title: "Agilent Keysight DSOXLAN Card MSOX DSOX 2000 3000 InfiniiVision Oscilloscope"
Offline Gribo
I'm getting a 'LAN/VGA module concern' on boot up with 2.65. Obviously, Telnet is not working, however standard LXI and web panel do work
Did anyone encounter this issue before?
I am available for freelance work.
Offline TheSteve
  • Living the Dream
I assume you have a fake/clone LAN card?
If so this will always happen if the LAN card enable line is connected on the clone PCB as the scope is trying to load the VGA output FPGA and failing. You can open the LAN card detect lines on your card and the error will go away but you will also lose the network config options in the scope menu, and perhaps some other stuff. It has been well documented in this thread previously. A search would provide full details.
VE7FM
Offline Gribo
Ok, so nothing to worry about. Thanks.
Offline Yetisnail
  • Country: at
Thank you all for your contributions over the years. On the off-chance that somebody might read this, I'd like to ask where I can find or get a patched version of the 2.65 firmware for the 2000x series. All the links I found so far have been taken down. If you know or have something the like I'd very much appreciate a pm or a response. It is maybe a bit blunt to just ask for something, if you are new. But I sadly have nothing to contribute to this amazing thread. Wish ya all a pleasant week.
Offline nb_haha
  • Country: hk
Hello everyone, can anyone help me connect to the Telnet of DSOX4000A (software version 7.56),
or send me a copy of the newer special firmware,
or help me modify the model number of DSOX4000A,
can send me a private message.
I am willing to exchange a genuine 2000/3000 BDL license.
Thanks!
Offline wirelessnet2
Was there ever a 7.50 FW released for DSOX4000 Series scopes? If anyone has it and would be willing to send it to me, that would be awesome, thanks!
(Also, was there ever a patched FW newer than 7.50 released for 3000T or 4000X scopes?)
Offline Boppeldibop
Can some kind member here maybe help me out with a working link to PhillyFlyers FW: DSOX 3000T Series:  FW:  7.40.2021031200_patched   edit: or newer, I think 7.50 was the last version(?)
Would be very much appreciated  :).
« Last Edit: April 01, 2023, 03:59:46 pm by Boppeldibop »
Offline ArtemSR
  • Country: al
Hi friends.! I have DSOX3012t ( 2 Chanel , w/o LAN and VGA)
FW 07.25.2018101442
and
MSOX3024t ( 4 Chanel , w/o LAN and VGA)
FW 07.40.2021031200
Thanks!
Offline Boppeldibop
Do you mean an official version or a patched one?
Offline gamalot
  • Correct my English
    • Youtube
Just upgraded my DSO-X 2002A to a DSO-X 3104, the video has all the necessary info.   :popcorn:
« Last Edit: March 31, 2023, 10:14:17 pm by gamalot »
Offline TheSteve
  • Living the Dream
Not April 1st here yet.
VE7FM
Offline obsoletepower
  • Your heart is not a fuse you can replace. Be safe!
Would anybody be so kind as to send me a working link to the PhillyFlyers patched FW 2.65 for the 2000-X series scopes? It would be greatly appreciated. Thanks!
Online HighVoltage
Finally a video that everyone understands, Thanks
