Well, one advantage of having the jacks up a little higher is that the strain reliefs don't hit the table when you have the meter up on the tilting bail. On the Fluke 11x if you use leads with larger strain reliefs on the banana plugs you have to rotate the plugs like / \ to clear the table.
