Author Topic: Enabling options on Agilent ESA series E4402B E4404B E4405B E4407B  (Read 189984 times)
Offline wb0rxl
Re: Enabling options on Agilent ESA series E4402B E4404B E4405B E4407B
« Reply #550 on: March 27, 2025, 02:44:19 pm »
Paul.
I think I may have solved at least one of my issues.
You must enter the option number (e.g.: 226) and THEN the license number.
 (Picture of me beating my head against the wall!)
Personality 226 - Phase Noise is loaded and activated.
Thank you, thank you, thank you.
I will now need to go work on the others in a little bit.
John
Offline PA0PBZ
« Reply #551 on: March 27, 2025, 03:54:00 pm »
Yes, you do have to do that and here is your picture:  |O
Anyway, another mystery solved! If you run into other interesting problems we're here.
Note that you may not be able to load all the modules, depending on memory.
Offline tautech
« Reply #552 on: March 27, 2025, 07:03:13 pm »
I tried the new license key for that personality.  Unfortunately I still receive the "License not valid" error message.
Very strange, I double checked everything on my side and I can't find a reason. Maybe this model uses different seeds to produce the keys but the only way to verify that would be another user that has a working key for this model.
@TV84, any idea?
Please note, no capitals:
https://www.eevblog.com/forum/profile/?u=92796
Offline wb0rxl
« Reply #553 on: March 28, 2025, 01:21:32 pm »
Paul (and group?)
Thank you again for all of your help.
To review....
Option 226 - Phase Noise - Successfully loaded and operational
Option 229 - Modulation Analysis - Successfully loaded and operational
These were obtained as zipped files that I was able to simply unzip and install.
Problem areas...
Option 219 - Noise figure
Option 225 - Cable fault location
Option 228 - Bluetooth
The only files I have been able to locate for these are the EXE application files.  I have followed the instruction sheet from the Keysight web site on both a Windows 10 and a Windows 7 machine.  The error message is the same - that my version of Windows cannot run the application.  I have also tried to run the file under previous versions of Windows using their "Previous Versions Adjustments."  Still no luck.
Does anyone have these file packages they could upload in a zipped form?
BTW, thanks to you, Paul - I have the applications I was really looking for, so these packages would simply be icing on the cake.
Thanks to all of you.
John
Offline PA0PBZ
« Reply #554 on: March 28, 2025, 02:18:20 pm »
Hi John,
Let's see if anyone has these files already. If not I can try to 'unpack' them on a virtual XP system, maybe my memory was wrong and I didn't use Windows 7 for this.
Online Uunoctium
« Reply #555 on: March 28, 2025, 02:54:58 pm »
2-1-9
Offline wb0rxl
« Reply #556 on: March 28, 2025, 03:37:17 pm »
Thank you.
I'll get right to work on these (even though my wife calls it "play") .
John
Offline pro0575
« Reply #557 on: March 31, 2025, 08:26:19 pm »
Hi Paul PA0PBZ
My E4404b is HOST ID:  A080869C
I'd really appreciate if you could generate keys for options
J35     B.01.02
J36     A0101
Many thanks pro0575
Offline PA0PBZ
Offline pro0575
« Reply #559 on: April 01, 2025, 09:22:26 am »
Thank you, but key generation for options J35 J36 is not provided in this program.
Offline PA0PBZ
« Reply #560 on: April 01, 2025, 09:42:58 am »
I see, here are the options:
J35 F1F707BCEE6B
J36 EC010CC1F866
The following users thanked this post: pro0575
Offline swperk
« Reply #561 on: April 01, 2025, 12:35:16 pm »
I used the key generator to add a few options to my E4402B, but after doing so, there is still a problem. The licenses installed correctly, and they show up in the installed licenses screen, but there is only the option number and the license key shown. Unlike the other options that came preinstalled, the "Name" field is blank. Is that to be expected?
Of more concern is that I cannot find any of the newly installed options (e.g., Phase Noise) in the "Mode" screen. Am I doing something wrong?
Thanks,
Stan
Online Uunoctium
« Reply #562 on: April 01, 2025, 01:50:48 pm »
Did you also install the corresponding software package? Yo can pre-licensing any option - but without feeding the instrument with one or more diskettes, the textfield naming the option remains empty.
Offline swperk
« Reply #563 on: April 01, 2025, 05:51:03 pm »
No, I did not. The only software package installation files I could find on the Keysight website were for the J35/J36 options. Where might I find files for the other options?
Thanks,
Stan
Online Uunoctium
« Reply #564 on: April 01, 2025, 07:06:49 pm »
somewhere in this thread 219, 226 and 227 as attachments. Didn't remember the exactly page number
Offline swperk
« Reply #565 on: April 04, 2025, 09:03:56 pm »
I was able to find the personality disk image creation .exe files for options 219, 226, 227, J35 and J36. Now here's the new problem: when I try to create the install floppies on my Win 7 PC with an external USB 3-1/2" floppy drive I get the error message:
This image is not compatible with any available drive.
Hint: -Disk images can only be duplicated on the same drive type they were created with.
Any ideas how I can create the floppies? Do I need to find a very old PC with an internal floppy drive, or is there another method?
Thanks,
Stan
Offline Xtremexp
« Reply #566 on: April 06, 2025, 02:16:45 am »
Thanks,
Stan
I also face same issue, can someone please share the zipped image of 228, 225 option?
Thanks!
Offline pro0575
« Reply #567 on: April 07, 2025, 05:51:18 pm »
Format the floppy disk in S A, then paste the contents of the archive onto it. Good luck
The following users thanked this post: Xtremexp
Offline Xtremexp
« Reply #568 on: April 07, 2025, 09:57:02 pm »
Thanks, It worked. Can anyone please help for option 228 and 231? It gives error when try to run EXE.
Offline pro0575
« Reply #569 on: April 08, 2025, 09:57:17 am »
Offline pro0575
« Reply #570 on: April 08, 2025, 10:09:52 am »
Offline pamphonica
« Reply #571 on: June 01, 2025, 03:37:28 pm »
How do I remove options?  I have an odd fault with the input (attenuation in "AC coupled" mode, but not DC coupled), having enabled a few options, and want to return to the pre-option state to test what's happening with each option.
Options recently enabled (due to this excellent thread and the options generator) are:
UKB - LF extension
1DR - Narrow Resolution
BAA - FM Demod (probably needs hardware)
B7B - TV Trigger (also probably needs hardware)
1DS - Preamp
AYZ - External Mux
thanks
-Jeremy
Offline Coppo76
« Reply #572 on: June 02, 2025, 10:44:57 am »
Good morning,
Thanks for this very useful discussion.
I am the owner of an E4404B
Hostid 19A1FF80
I kindly ask if you can tell me the license codes J36 and J35
Offline Coppo76
« Reply #573 on: June 02, 2025, 09:03:49 pm »
I managed to install the option.
Thanks to the helpful tips I found here.
Offline pamphonica
« Reply #574 on: June 03, 2025, 09:25:29 am »
Quote from the Users Guide:
Not all options can be enabled using this system and there is no way to
turn off an option through this system.
"This System" means the normal process of entering option codes and licence numbers on the screen.
Any ideas about removal?
thanks
-Jeremy
UKB - LF extension
1DS - Preamp
AYZ - External Mux
thanks
-Jeremy
