Author Topic: REVIEW - Rigol DS2072 - First Impressions of the DS2000 series from Rigol  (Read 1100828 times)
Offline drieg
  • Country: cz
    • Silcon Electronics
Can someone with 2072 and new software test this setup file..
This setup file gives a DS2072 a   2 nSec   timebase..
What's the matter, Wim - afraid you won't be able to downgrade?  ;)  That's the main question - and I haven't tried it yet; still hoping Drieg will answer the question before I take the risk  ;D  I suspect, because of the problems with the update procedure - that it's still possible to downgrade back to 05.
So far, I've seen two versions of DS2 bootloader and none of them was checking the firmware version, so if you use bootloader update method with HELP button, you should be able to downgrade. The bootloader remains unchanged after this FW uprade...
For the FW update itself - please use the bootloader method with HELP button described here.
« Last Edit: April 12, 2013, 03:30:50 pm by drieg »
Bricked Rigol? This thread might be of any help.
Offline marmadTopic starter
  • Country: aq
    • DaysAlive
Maybe they disabled their RTC...  :palm:
You mean the clock for trial options?
Oh, they have a different calendar.
Huh? How do you mean?
Doh! ...finally got the joke  :-[   ;D
« Last Edit: April 12, 2013, 03:16:49 pm by marmad »
  • Country: aq
    • DaysAlive
Updated (per marmad):  :scared:  :scared:
You should now have email fairymail  ;D
« Last Edit: April 12, 2013, 03:06:06 pm by marmad »
Offline zibadun
the dance worked, thanks
It doesn't work on the new firmware. "File version doesn't support!".
I guess kind of like  "All your bases are belong to us!"  >:D
  • Country: aq
    • DaysAlive
Re: Rigol Firmware update IS NOT RELEASED to the USA yet
« Reply #704 on: April 12, 2013, 03:26:03 pm »
Rick contacted Rigol N/A and the word is: Not released to the US yet 'It's coming around the World' and it may take up to 30 days before we see it.
Well, I hate to break it to Rigol NA, but somehow it went from Australia to the EU to NA in 1 day.  ;D  I'm afraid all of us current owners (early adopters that we were) had been waiting too long already for this to wait anymore than a single day. If there had been a way to make it upgrade all of our DSOs simultaneously - we would have figured it out.  ;)
  • Country: aq
    • DaysAlive
Well, honestly, it was being posted here exactly what was happening with the setup files (along with the files themselves) - what do you think? But still, if they have just altered the file system a bit, you might be able to do the same thing again.
Offline EV
  • Aficionado
Firmware fairy has been here too!
:scared:  :scared:  :scared:  :scared:
Offline Wim13
So then also your former setups, if ever used wont work anymore.
They changed the layout.
Did you use any setup files before, or other saved files, that wont work..??
  • Country: aq
    • DaysAlive
Yes, they've changed the file structure for setup files. I tried loading a few different ones but it doesn't work. But, Wim, why don't you just upgrade and check it out? I'm sure you can downgrade after - when I insert FW 05 on a USB stick, the message on the screen says something like "Older firmware detected - Proceed to downgrade?"
Offline EV
  • Aficionado
Saved picture looks like this now:
Offline zibadun
the 2ns one worked on the old fw. sorry I did not save any other setups.  If you have an old setup from 2072 I'd give it a try.
  • Country: aq
    • DaysAlive
Wow, I hadn't noticed that - and I even captured an image to crop the System Info box for the initial bug post. That seems kind of a weird change to me - I'll have to edit the code in RUU to clip that off the top.
Why would I want my serial number attached to an image I'm going to presumably show others? Stupid.
« Last Edit: April 12, 2013, 03:57:33 pm by marmad »
Offline zibadun
They could have put that info into Exif header like all the digital cameras do...
Offline EV
  • Aficionado
Here is a new bug. I noticed that rise time and fall time are the same on the earlier picture. Here is picture saved with RUU. It is on track auto mode. It is still not possible to save on track manual mode either with this firmware.
Offline xrunner
  • hp>Agilent>Keysight>???
Well, they wrote back fast -
To answer your question, we are planning to add that later but not yet. I'd say that today we only post and notify customers of important updates. Smaller updates we supply on a request basis. At any time you can call/email in and get the latest from us as long as there is an appropriate new version.
Thanks.
Steve
Steve Barfield
(NN5U)
Rigol Technologies, Inc.
7401 First Place
Suite N
Oakwood Village, OH 44146
440.232.4488 x114 (Office)
877.4RIGOL1 x114 (Toll Free)
440.232.4499 (fax)
404.374.5902 (Cell)
steve_barfield@rigoltech.com
www.rigolna.com
Offline EV
  • Aficionado
I installed back the old firmware. This rise time bug is so bad that I am waiting next update.  :( :-//
Offline Hydrawerk
Well, what's the problem with the rise time bug? I don't understand it...
OK, it is an auto measurement fail.  :--
« Last Edit: April 12, 2013, 09:34:13 pm by Hydrawerk »
Offline zibadun
mine does not have this problem.  also it stopped printing S/N and time on top of the pictures
« Last Edit: April 12, 2013, 07:30:25 pm by zibadun »
Offline bmwnomad
I foolishly did a self-cal on my new Rigol DS2072.  I had thought that version .05 of the software (as shipped) fixed the losing the trial options bug, sadly reading back through this thread I discovered the bug is still there.
Has a workaround been discovered to reenable the trials?  I think I still had over 2000 minutes left on them.  I have an email into Tequipment.net to see if they can be of any assistance.  Or am I just SOL?
Thanks,
Steve
  • Country: aq
    • DaysAlive
What caused it to stop - or - how many saves did you do before it stopped?
Offline EV
  • Aficionado
I intalled back the new firmware. In the picture is antisymmetric ramp wave. Rise time and fall time are both 160 ns!  |O |O :-//
  • Country: aq
    • DaysAlive
Yes, I confirmed the bug. I think the Rise time is actually just the Fall time repeated. In fact, if you chose either Rising Edge or Falling Edge with Auto cursor - it goes to the same edge.
It seems like it might be an easy bug to fix (pointer problem, etc) - I wonder if we can get Rigol to do it quickly?
« Last Edit: April 12, 2013, 08:52:52 pm by marmad »
Offline EV
  • Aficionado
I closed the scope and started it again and now it works correctly!!!!  :-+ :-+ :-+
Offline zibadun
very strange, the only difference is that yours is 2202.  I've tried again and it shows different raise/fall.  Where does it place the markers if you switch to fall mode?
BTW, can you please post your 2ns setup file, I'll see if it works here with raise/fall times  ;) ;)
Didn't do anything. just powered off/on and no more header.  gremlins...
« Last Edit: April 12, 2013, 08:55:57 pm by zibadun »
  • Country: aq
    • DaysAlive
That's no solution. I've had my DSO on and off several times since changing firmwares - and it's having the bug right now.
« Last Edit: April 12, 2013, 10:47:46 pm by marmad »
