EEVblog® Electronics Community Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Products
Test Equipment
Fluke 116 multimeter - hidden modes
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Fluke 116 multimeter - hidden modes (Read 261 times)
hexbus
Contributor
Country:
on:
September 24, 2026, 08:00:04 pm »
I saw this post here and saw the same P2 serial jumper on my main board and figured I'd investigate...
https://www.eevblog.com/forum/testgear/what_s-going-on-with-my-fluke-117-meter/msg1207154/#msg1207154
https://www.eevblog.com/forum/testgear/hacking-the-fluke-117-dmm/
Holding down HOLD and turning the knob to AUTO-V (LoZ) displays FCTY, flashes the backlight [shared with serial], and appears to send data out the serial port P2
Holding down HOLD and turning the knob to Volts DC shows "1.02" which is I'm guessing the firmware revision of the meter
Holding down HOLD and turning the knob to mV (AC/DC) shows "F116" which is the model
Holding down HOLD and turning the knob to Ohms shows "CAL" which is calibration. If you press the light button, you will see "n001" likely which is probably because it's been calibrated once. (Turn it back off from here. If you press the light button twice, you will see a prompt for the calibration password. You can screw this up - but if you really want to know:
https://media.fluke.com/65244ea8-3346-478e-8a31-b10800c0e534_original%20file.pdf
Holding down HOLD and turning the knob to Continuity displays FCTY, flashes the backlight [shared with serial], and appears to send data out the serial port P2
Still don't know the serial protocol, but I do plan on hooking the pins up to a scope while measuring continuity or a small voltage <3V (which apparently is the only thing you can monitor that I've found shortcuts.)
Anyone else have tips and tricks that they've learned about their meters? I really wonder if they put hardware in these things and firmware cripple them to sell more expensive hardware. Wouldn't put it past them.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Products
Test Equipment
Thanking...
EEVblog® Main Site
EEVblog® on Youtube
EEVblog® on Twitter
EEVblog® on Facebook
EEVblog® on Odysee
