Author Topic: Fluke 190 II Windows 10, Windows 11, x64 drivers  (Read 7024 times)
Offline patpatTopic starter
« on: November 02, 2024, 11:24:22 pm »
I recently got a 190-502 II and accessing the console or running any software on Windows 10 or 11
was not possible because drivers were only available for old Windows versions.
The Scope has an internal FTDI chip converting USB<->RS232.
The old XP/Win7 drivers originally provided by Fluke are just the FTDI drivers but using Fluke hardware identifiers:
VID_0F7E&PID_9006.DeviceDesc="Fluke USB Serial Port"
VID=0F7E
PID=9006
I took the modern x64 FTDI drivers, added Fluke IDs, rebuilt it, and it worked.
For installation just run "install_3.cmd" on an elevated prompt (for this just open a cmd instance as Admin)
For de-installation you can run FTDI CDMUninstallerGUI_v1.5.exe adding the corresponding Fluke identifier ( VID & PID ) from the ones mentioned before.
After driver installation and connecting the scope to the Windows 10/11 x64 PC you'll see the Fluke 190
in the Device Manger as shown below.
Edit 01:
Tested on Windows 11
  Firmware Upgrade -> OK
  FlukeView-1 version 5.4  -> OK
  FlukeView-2 for ScopeMeter® Test Tools version 3.2.0 64bit -> OK
« Last Edit: November 23, 2025, 07:14:56 pm by patpat »
The following users thanked this post: hugos31, coromonadalix, brint.corb, alset
Re: Fluke 190 II Windows 10, Windows 11, x64 drivers
« Reply #1 on: February 21, 2025, 12:23:02 am »
I wonder why this page recently included in its HTML header
<meta name="robots" content="noindex"/>
Then is not indexed by Google...
Offline brint.corb
« Reply #2 on: November 10, 2025, 08:07:49 pm »
This worked for me thanks a lot!   Win 10,  fluke 190-104
Offline hugos31
  • Country: pe
« Reply #3 on: March 18, 2026, 04:01:42 pm »
  Hello, I buy Fluke 190-204 II  in eBay, please help me update the software or firmware ,thanks
« Last Edit: March 18, 2026, 09:08:02 pm by hugos31 »
Offline hugos31
  • Country: pe
« Reply #4 on: March 19, 2026, 06:28:25 pm »
Thanks. I've already updated it.
« Last Edit: March 19, 2026, 06:30:34 pm by hugos31 »
Online squadchannel
  • Country: jp
  • deepl translate user
« Reply #5 on: May 02, 2026, 11:21:15 am »
I found a driver for the 190II listed in the Microsoft Update Catalog.
I’m not sure why it isn’t available through update, but I’ve attached it. :-+
https://www.catalog.update.microsoft.com/Search.aspx?q=0f0958db-f8df-4b07-9eef-35aae7b96bd8
« Reply #6 on: May 18, 2026, 05:04:33 pm »
This driver attached by @squadchannel detects:
USB\VID_0403&PID_6001.DeviceDesc="USB Serial Converter"    <-   FTDI FT232R USB UART IC
USB\VID_0F7E&PID_9007.DeviceDesc="Fluke 430 Series II"
USB\VID_0F7E&PID_9006.DeviceDesc="Fluke 190 ScopeMeter"
Binaries are from 2011.
« Last Edit: May 19, 2026, 03:55:49 pm by patpat »
