I have done step 6. After that, the display shows a flat line (with noise), around -60dB up to 3.2GHz, instead of a line reaching -50dB at this value before (not sure of exact values). Test with a 950MHz signal shows the right level.
Info system shows same options as for SSA, but all valid for a limited time.
Before and after step 6, telnet is never valid at startup, I must connect to web page, send DEBTTT SCPI command and connect to port 23 with root and ding1234. Step 3 has been done, file is modified, but it doesn't work (or just after modification and first reboot, but after some time, it no longer work).
Some time later, I've done step 8 (skip step 7). And after that, system info shows many new options, all permanently valid (except one, don't remember what option), and the display shows no longer a flat line but a line slowly climbing, as before cross flash. And then I've done step 7 (4 lines deleted, product type 2 to type 5).
Tested VNA mode, and of course Smith chart indicates cable is missing.
Tomorrow, I will open the Siglent, solder the 2 connectors and add the cable. I've found SMA connectors with center pin smaller, will fit in the printed board.
I think the most important is done, with success !
