Sorry, I should have said memory depth. Before I applied the latest patch I was following along with a YouTube video showing how the thickness of the trace can be seen to change going from 4k I to 8m, but I didn't see the same difference and put it down to filtering smoothing out the trace. Than Immediately after the latest patch the trace became noticeably thicker unless I used HR mode or a lower memory depth.
This made me wonder, as the reason they sent me the patch was I complained of laggy inputs and random lockups, if there was a change to the filtering to lighten the process load, with the added benefit of a more accurate display trace.
