Author Topic: Hacking the OWON SDS7102 to SDS8102 or better  (Read 6477 times)
Offline sbeukersTopic starter
« on: January 22, 2013, 03:29:07 pm »
Hi all,
I was just poking around in the firmware of the owon SDS7102 and i found something interesting.
First manualy unpack the file by opening it with 7-zip (winrar etc doesn't work)
Then go to the following directory
....\$_OUTDIR\SDS7102
you will find 5 file in there
OS_H2
OS_H4
OS_H5
OS_H6
OS_H8
Open those files with 7-zip and find
help
me
os
readme.txt
In readme.txt there is a line that says help=xxxx serial number i guess.
The files in the folder \SDS8102 and others are just slightly different.
Well I thought that maybe... just maybe we can take the firmware from the \SDS8102\OS_Hx and modify the readme.txt then put it in \SDS7102\ and pack it back to OS_Hx
Is there a chance that the number after OS_H? stands for a certain hardware revision.
Anyone brave enough to try this?
grt Sjoerd
Offline rf-loop
Re: Hacking the OWON SDS7102 to SDS8102 or better
« Reply #1 on: January 22, 2013, 07:06:00 pm »
No way!
HW is really different.
SDS7102 use ADC08D500 clone
SDS8102 and 8202 use ADC08D1000 clone made by RuiFeng. (propably same as Rigol DS2000 serie.)[/b]
Also new SDS7102 versions have (typical) BW -3dB point between 170-220MHz depending of voltage range if you have seen tests. It is more than enough for realtime 1GSa/2x500MSa/s scope.
Then also 7102 have full speed memory up to 2x10Mpoints. With one channel it can capture 1GSa/s to 10M sampling buffer. And with 2 channel in use it can 2 x 500MSa/s to both channels own 10Mpoints memory.
If go to 8xxx models all memory over 10k is same speed as in 7102. 8xxx do not give anything more.
I drive a LEC (low el. consumption) BEV car. Smoke exhaust pipes - go to museum. In Finland quite all electric power is made using nuclear, wind, solar and water.
Wises must compel the mad barbarians to stop their crimes against humanity. Where have the wises gone?
« Reply #2 on: January 22, 2013, 10:26:55 pm »
How do you know that the hardware is really different?
I really doubt that.
The Rigols were the same, why not the Owons?
*edit* I am really happy with the bandwidth of my scope but hacking stuff is always fun.
« Last Edit: January 22, 2013, 10:40:37 pm by sbeukers »
Offline Matje
« Reply #3 on: January 22, 2013, 11:03:59 pm »
Judging from his signature I would guess he sells this stuff. ;-)
