Hi all,
I was just poking around in the firmware of the owon SDS7102 and i found something interesting.
First manualy unpack the file by opening it with 7-zip (winrar etc doesn't work)
Then go to the following directory
....\$_OUTDIR\SDS7102
you will find 5 file in there
OS_H2
OS_H4
OS_H5
OS_H6
OS_H8
Open those files with 7-zip and find
help
me
os
readme.txt
In readme.txt there is a line that says help=xxxx serial number i guess.
The files in the folder \SDS8102 and others are just slightly different.
Well I thought that maybe... just maybe we can take the firmware from the \SDS8102\OS_Hx and modify the readme.txt then put it in \SDS7102\ and pack it back to OS_Hx
Is there a chance that the number after OS_H? stands for a certain hardware revision.
Anyone brave enough to try this?
grt Sjoerd
