Author Topic: Hacking the Rigol MSO5000 series oscilloscopes  (Read 1544647 times)
0 Members and 43 Guests are viewing this topic.
Offline oelapaloma
Re: Hacking the Rigol MSO5000 series oscilloscopes
« Reply #2075 on: September 28, 2021, 06:20:37 pm »
It seems I have a new build and a different checksum. Now what?
System Information:
Firmware: 0A.01.03.00.01
Boot: 2018.06.27
Build: 2021-05-04 15:50:32
Checksum:
<root@rigol>md5sum appEntry
4669caa3cfb3d19f98adff7833e321db  appEntry
I have successfully created a backup, I am able to activate SSH, I can connect with WinSCP and provide files for analysis, if needed. I think I understood how to hack the scope, but the checksums will not match (I have not tried, but that's why I created the MD5 hash to know in advance).
« Last Edit: September 28, 2021, 07:14:43 pm by oelapaloma »
Offline d86d1864
« Reply #2076 on: September 28, 2021, 07:12:52 pm »
Curious. That does not match any version, or even naming scheme, I have ever seen.
I had a quick look at all the usual places Rigol publishes firmware but they all point to 00.01.03.00.01.
The stock 00.01.03.00.01 does not come with ssh enabled, so I assume you ran some USB script to enable it - did you by any chance run a script that might've modified your appEntry?
Offline oelapaloma
« Reply #2077 on: September 28, 2021, 07:31:38 pm »
I created USB Sticks with GEL files on it. I'm not sure whether one of these modified appEntry, but the Firmware version was like that all the time. I recorded it when I bought the scope. The GEL files I used were those for backing up files (no need to modify appEntry, I hope) and running the SSH server (also no need to modify appEntry, I hope).
Offline d86d1864
« Reply #2078 on: September 28, 2021, 07:57:31 pm »
I just went through the six patches I have on file and I was not able to find any that matched the MD5 you gave.
It is of course possible I've missed several patches, but if you say the factory fresh version had the 0A, then it's entirely possible you're running some as-yet-unpublished version of the firmware.
It's easiest to put together a patch if we have the full firmware, but if you can attach your appEntry that's likely enough.
(Unfortunately I can't personally promise I'll have time to have a look, but perhaps someone else out there can.)
Good luck!
« Last Edit: September 28, 2021, 08:15:05 pm by d86d1864 »
Offline oliv3r
    • Rigol related stuff!
« Reply #2079 on: September 29, 2021, 08:30:32 am »
System Information:
Boot: 2018.06.27
Checksum:
I'm very curious in that release :)
Did you do a 'full nand backup'? Would you mind sharing that one so I can add it to the gitlab repo?
Offline oliv3r
« Reply #2080 on: September 29, 2021, 08:31:49 am »
While the promo still appears to be running (I'll check again okt. 1st to see if it was extended again :p) I can't actually reach the form.
https://www.rigolna.com/promos/ does list the link, but the link is dead, from the EU and the USA :(
https://beyondmeasure.rigoltech.com/acton/ct/1579/p-0080/Bct/-/-/ct20_0/1/fu?sid=TV2%3AKt5oPeWlY
can anybody confirm it is indeed, dead?
Offline PA0PBZ
« Reply #2081 on: September 29, 2021, 09:18:26 am »
Both the link on the rigolna site and the direct one work fine for me (Netherlands IP)
Offline oliv3r
« Reply #2082 on: September 30, 2021, 06:44:15 pm »
That is so sad :( I also have a Netherlands IP and get:
This site can’t be reached
beyondmeasure.rigoltech.com refused to connect.
Offline oelapaloma
« Reply #2083 on: September 30, 2021, 06:59:19 pm »
Same issue here right at the moment. I had problems on September 28th as well, but 2 hours later it worked again.
'full nand backup'
I don't know what that is. Is there a GEL file to create that kind of backup? Ok, got that one as well from https://www.eevblog.com/forum/testgear/hacking-the-rigol-mso5000-series-oscilloscopes/msg2757356/#msg2757356. Will try.
At the moment I only have a calibration backup. But I can connect to the scope using WinSCP and I can access /rigol/appEntry and likely other files if needed.
Find appEntry (22 MB) for a few days on http://37.120.179.6/appEntry-0A.01.03.00.01
« Last Edit: September 30, 2021, 07:13:09 pm by oelapaloma »
The following users thanked this post: d86d1864
Offline PA0PBZ
« Reply #2084 on: September 30, 2021, 07:07:09 pm »
Just checked again and it still works for me, very strange
Offline oliv3r
« Reply #2085 on: September 30, 2021, 07:26:06 pm »
'full nand backup'
Heh, you found the link faster then I did :p I was looking for that link from our very own @tv84 :) but the script only does a simple `dd if=/dev/mdX of=/media/usb/mdX` so nothing super special :)
Offline oliv3r
« Reply #2086 on: September 30, 2021, 07:33:48 pm »
Didn't work in the NL; used a USA proxy; worked this time around ... weirdness.
Offline PabloSanchez
  • Country: ru
« Reply #2087 on: September 30, 2021, 08:44:40 pm »
Hi!
I have the firmware 00.01.03.00.01 from 30.03.2020
can someone tell me where to download the firmware FW 01.03.00.01 build 2020-05-18
Offline tv84
  • Country: pt
« Reply #2088 on: September 30, 2021, 09:11:33 pm »
Hi!
Nowhere. Up till now it's only flashed at factory.
  • Country: ru
« Reply #2089 on: September 30, 2021, 09:24:30 pm »
And what versions do you recommend to do ?
Offline K9DTV
« Reply #2090 on: September 30, 2021, 09:48:29 pm »
I applied the patch to unlock my scope and this unlocked everything.
However, I am unable to run selfcal, as it never starts.
Channel one goes rail to rail, so it will never start selfcal.
Scope channel is working fine otherwise.
Any ideas?
Mine just ran successfully (first one post-hack).
See attachment
1286395-0
  • Country: ru
« Reply #2091 on: September 30, 2021, 10:48:41 pm »
Any ideas?
See attachment
(Attachment Link)
what exactly did you use, I have the same firmware version and nothing works, please describe in more detail where to start and what files?
Offline K9DTV
« Reply #2092 on: September 30, 2021, 11:55:46 pm »
Download the attached files
01_03_00_01.bspatch.txt  rename to  01_03_00_01.bspatch
DS5000Update.GEL.txt      rename to  DS5000Update.GEL
patch.txt
Copy to root directory of usb flash drive
insert into front scope usb
run update
Now can some one help me with my problem?
« Last Edit: September 30, 2021, 11:58:12 pm by K9DTV »
The following users thanked this post: sem21, PabloSanchez
Offline Kean
    • Kean Electronics
« Reply #2093 on: October 01, 2021, 07:54:38 am »
I just noticed that while the free bundle is apparently still available for purchases until 31 March 2022, it is now only offfered for 4 channel models.
Not really a big deal for those wanting to hack their scope, unless you wanted those features to increase un-hacked resale value.
From: https://beyondmeasure.rigoltech.com/acton/form/1579/0065:d-0001/0/-/-/-/-/index.htm
Valid Models: MSO5074, MSO5104, MSO5204, MSO5354
note: Other models no longer qualify for the free bundle offer when purchased after 9/30/2021. For purchases of any UltraVision II Oscilloscope that occurred before 10/1/2021 please fill out the form below and your bundle will still be sent per the previous promotion.
Offline oliv3r
« Reply #2094 on: October 01, 2021, 02:35:10 pm »
Hi!
Do we have a nand-backup of someone with that firmware? we can generate it then if really needed.
Has anybody reached out to rigol to request the GEL file from them?
Offline kc55
« Reply #2095 on: October 02, 2021, 08:09:29 am »
I have same problem especially on channel 1 of my MSO5074. When I switch on only that channel the offset is smaller. around -70 mV. With at least one other analog channel also switched on, the offset becomes larger at around -160 mV at 1 V/div scale setting.
I ran self calibration a few times but it didn ‘t fix the offset.
Anyboby here have similar observation? Is the amount of offset to be expected?
« Last Edit: October 02, 2021, 08:16:33 am by kc55 »
Offline oelapaloma
« Reply #2096 on: October 02, 2021, 08:16:10 pm »
I have created a Full NAND Backup and a Data FRAM Backup of the scope with 0A.01.03.00.01 firmware. Please PM on how to procede. I don't want to see my full dump on the Internet.
Offline d86d1864
« Reply #2097 on: October 03, 2021, 12:10:15 pm »
Thank you for sharing the binary.
Curiosity got the better of me so I had a crack at porting the previous patches to the new binary (attached below).
It's a little harder to test when we don't have the firmware available, but I managed to get the binary running on 00.01.03.00.01 with a little fiddling, and it appears to work.
But as always, use at own risk and naturally only for educational purposes. :)
Offline flash2b
  • Everything I like about myself is better with you.
« Reply #2098 on: October 05, 2021, 12:02:15 pm »
My scope came with this:
Is this hackable and what do I need to do?
They say attention is a shovel. It's time to dig 'em out.
Offline atembedded
« Reply #2099 on: October 07, 2021, 02:13:34 pm »
Hello, newbie here.  Received my MSO5074 the other day and have been trying to apply the hack.
Downloaded the files as listed in the earlier post on page 85.  Last list with attached files I believe.
FW version is  00.01.03.00.01
HW version is 01.01.000
Boot               2018.06.27
Build               2020-05-18  11:42:06
Can't get the scope to recognize any of 3 different USB sticks.
Just says "No Package Found" From local Upgrade and "Upgrading Failed, please check the package"
Probably doing something dumb.  Any specific formatting requirements?
Thanks.
