Author Topic: Hacking the Rigol MSO5000 series oscilloscopes  (Read 1547927 times)
RoisnoG, LorenzoDL and 10 Guests are viewing this topic.
Offline ktro
  • Country: ru
Re: Hacking the Rigol MSO5000 series oscilloscopes
« Reply #2200 on: January 05, 2022, 08:54:36 am »
You can. XY is just perfect.
Offline savytechlover
  • Country: id
« Reply #2201 on: January 12, 2022, 02:55:33 am »
guys i have mso5074 for about 3 months now...
i stumble across mso 5000 hacking... and i did watch few videos... from imsaiguy... i think the name...
also some of russian do the hacking... im still abit confused though...
anyone can give a little clearer guides or something on how to do it... what should i do and whats not...
Offline ON4FI
« Reply #2202 on: January 12, 2022, 07:26:45 am »
Offline fengwumu
  • Country: cn
« Reply #2203 on: January 12, 2022, 09:33:44 am »
Turn on the device with the left hand, while pushing the single button with the right hand.
Keep pushing it, over and over and over don't stop pushing, don't wait between pushes.
It works, I don't know why you are having problems.
After many attempts, I think I know the problem,
time1: Press the power button, the keyboard light is on, and the screen is dark;
time2: The keyboard light is off and the screen remains dark;
time3: The screen displays RIGOL, and the startup progress...
Just press single at time2, and the mysterious menu will appear.
 :-+Your operation method is correct! I have the same problem. Demote successfully in your way. Thank you!
Offline core
« Reply #2204 on: January 15, 2022, 06:14:13 pm »
I have upgraded from v00.01.03.00.01 to v00.01.03.00.03, then hacked.
Everything seems to be fine.
Steps I've followed :
1. Backup everything just in case
https://www.eevblog.com/forum/testgear/hacking-the-rigol-mso5000-series-oscilloscopes/msg2757356/#msg2757356
- get and unzip the first script file, put DS5000Update.GEL on USB stick, then Utility/Help/Local upgrade
- wait until 100%, then turn off/on
- repeat for the second script
2. Install the official firmware v00.01.03.00.03
- get the official firmware and unzip
- same steps like above, with the firmware file of course
3. Hack
https://www.eevblog.com/forum/testgear/hacking-the-rigol-mso5000-series-oscilloscopes/msg3869852/#msg3869852
- get and unzip the file Patch.zip and put the three files on USB stick
4. Calibration - very important
- remove the input probes
- Utility/System/SelfCal
- then turn off/on
Thanks everybody !
P.S. XY mode it's OK.
« Last Edit: January 15, 2022, 06:29:05 pm by core »
The following users thanked this post: PeterG, kahuna0k, jord4231, sjm, eklein, vutt, Varz, satellit72, crgarcia, ON4FI, gtube, Uunoctium
Offline ON4FI
« Reply #2205 on: January 16, 2022, 07:38:34 pm »
Super all OK
upgraded scoop first from 0A.01.03.00.03 to 00.01.03.00.03
above patch is ok
I measure more than 400 MHz bandwidth now
Thanks everybody
Offline kc55
« Reply #2206 on: January 17, 2022, 12:53:46 pm »
Hello everybody,
I apologize to everyone for the previous problems.
Here is a new patch for real fix all previous problems (finish tested it's working perfectly well for me).
FW:01_03_00_03
Build: 2021-10-18
(Attachment Link) " alt="" class="bbc_img" />
Hello qali.pro, thanks for the updated patch. I had previosly applied your first patch (i think from post #2142). How can I update to this patch? Thanks in advance
Offline core
« Reply #2207 on: January 18, 2022, 08:34:13 am »
Hello everybody,
FW:01_03_00_03
Build: 2021-10-18
Just install the official firmware v00.01.03.00.03, then patch it again.
Offline Wintel
« Reply #2208 on: January 18, 2022, 02:50:26 pm »
Any new bug in firmware v00.01.03.00.03 now?
Offline skes71
« Reply #2209 on: January 21, 2022, 11:37:35 am »
Hello,
I’ve just got the MSO5074 with the free MSO5000-BND for the serial protocols, the signal generators etc.
I just wanted to ask if the firmware patch enables the sshd.
If so, are the credentials still root/root or have they changed?
Thank you!
Firmware: 0A.01.03.00.01
Offline Wintel
« Reply #2210 on: January 24, 2022, 10:46:49 am »
Thanks!
Have you tried to upgrade the MSO5072 to MSO5504 (BW:500MHz) with firmware 01_03_00_03?
You are welcome.
I'll try (BW:500MHz) as soon as possible .
Hi qali.pro,
Have you try to upgrade to 500MHz and get 500ps/div?
Offline Bax
« Reply #2211 on: January 28, 2022, 11:21:24 pm »
Just wondering.
Has anyone from Rigol ever admitted that they design their test equipment to be hackable by the hobby community? A modified scope looses it's warranty and that saves them support costs although the original firmware can be re-flashed.
Thanks.
Offline hafrse
« Reply #2212 on: January 29, 2022, 07:08:03 am »
Just wondering.
Thanks.
Probably true, in that way they sell >100X  more 5072 units
The following users thanked this post: Bax
Offline normi
« Reply #2213 on: January 31, 2022, 11:51:01 pm »
I think the question to ask is whether anyone has been refused warranty because their scope was software hacked.
The following users thanked this post: Bax, oldjackbob, OHR
Offline qali.pro
  • Country: qa
« Reply #2214 on: February 01, 2022, 04:55:00 am »
Thanks!
You are welcome.
Hi qali.pro,
Hi Wintel ,
straight answer No, it's not worth the effort .
To know Why? please check msg2663334 https://www.eevblog.com/forum/testgear/hacking-the-rigol-mso5000-series-oscilloscopes/msg2663334/#msg2663334
« Last Edit: February 01, 2022, 05:33:14 am by qali.pro »
Offline Fungus
« Reply #2215 on: February 01, 2022, 08:03:49 am »
It's probably true but they'll never admit it in public because they're making plenty of full-price sales to companies, education, and other people who worry about "warranties". They need to maintain a certain level of FUD around anybody with money to spend.
Simple proof: They make models which can't be easily hacked, eg. the DS1000X models with signal generators.
« Last Edit: February 01, 2022, 08:08:17 am by Fungus »
Offline jemp
« Reply #2216 on: February 17, 2022, 01:22:46 pm »
Upgraded, like described before... tnx to everybody !
The telnet, or SSH option is not enabled after upgrade..
IS there any script that enables it ? So I could Putty into it..  I searched, but can not find
Jemp
Offline Sergey Astakhov
  • Country: ru
« Reply #2217 on: February 18, 2022, 02:40:06 pm »
https://www.eevblog.com/forum/testgear/hacking-the-rigol-mso5000-series-oscilloscopes/msg2234076/#msg2234076
Offline aprusek
« Reply #2218 on: February 22, 2022, 12:56:47 am »
I did the upgrade as per instructions and cannot get Self Cal to get the scope to measure voltages properly.
Does anyone know the location of a GEL file to upgrade to FW 0A.01.03.00.01 so I can try to get back to where I started from?
Offline normi
« Reply #2219 on: February 23, 2022, 12:10:12 am »
Without the upgrade does the FW work
Offline aprusek
« Reply #2220 on: February 24, 2022, 05:23:03 am »
Managed to get things working.
Get the Firmware
Download FW 00.01.03.00.01 from message 1810
Put DS5000Update.GEL on a USB stick.
Make sure it is the only file.
Load the Firmware
 Upgrade via "Secret Menu"
(Other options failed)
Power On
Wait for lights out (Before “Rigol” and progress bar)
Press [Single]
Two options are displayed
Upgrade or Restore
Select Upgrade.
Scope should now show FW 00.01.03.00.01
Get the Patch
Download zip file from message 1665
put 01_03_00_01.bspatch
and patch.txt  on a usb stick
Get DS5000Update.GEL from message 1669
Put this with the two other files
Only 3 files should be on the USB stick.
Load the Patch
Select:
Utility>System>Help>Local Upgrade>Ok
Scope should show all options:
Utility>System>Help>Option list
Self Calibration
Utility>System>Self Cal>Start
If you are checking calibration
Make sure probes are decent and are set to x1
The following users thanked this post: dnaleromj
Offline normi
« Reply #2221 on: March 02, 2022, 01:14:23 pm »
Get the Firmware
Load the Firmware
Power On
Press [Single]
Upgrade or Restore
Select Upgrade.
Get the Patch
Load the Patch
Select:
Self Calibration
I thought you were using the new firmware FW:01_03_00_03
Offline aprusek
« Reply #2222 on: March 04, 2022, 06:21:47 am »
No, scope originally came with FW 0A.01.03.00.01.
Offline Tonkabot
« Reply #2223 on: March 09, 2022, 03:08:33 am »
I just put 00.01.03.00.03 on my 5074, because I couldn't find the 1.03.00.01 version.  Will the patch still work?  Or do I have to get the 01 version first?
  • Country: ru
« Reply #2224 on: March 09, 2022, 11:06:40 am »
The patch is individual for each version. You need to select the correct patch for the firmware version you have installed.
Firmware update resets all changes and the patch will need to be installed again.
« Last Edit: March 09, 2022, 11:20:28 am by Sergey Astakhov »
