I have always wondered on what is the use case for pass\fail on my hantek. Could one of you guys please give me an example, or point me to a link that shows a usage example?
Hi!
The Pass/Fail feature on an oscilloscope is used to automatically verify if a signal meets specific criteria. For example, you can test if a clock signal's pulse width, frequency, or voltage stays within acceptable limits. It's great for automating repetitive testing, debugging, or ensuring signals comply with standards.
Here are some usage examples for the Pass/Fail feature on an oscilloscope:
- Clock Signal Validation: Verify frequency and pulse width of a clock signal within defined tolerances.
- Voltage Threshold Testing: Ensure a power supply's output voltage stays within an acceptable range (e.g., 3.3 V ±0.1 V).
- Signal Integrity: Check for overshoot, undershoot, or signal glitches against a predefined waveform mask.
- Communication Protocol Testing: Validate UART, SPI, or I2C signals for correct timing and logic levels.
- Transient Detection: Monitor for unexpected spikes or drops in signal levels.
Check these videos for some examples:
