Author Topic: HP VEE or LabView  (Read 4168 times)
Offline IconicPCBTopic starter
HP VEE or LabView
« on: April 25, 2017, 09:58:14 pm »
Just acquired an Advantech UB data logger.
Wondering wihc way to gowith regards to programing it....  LabView or VEE?
Are there any other not-so-steep -learning-curve sofftware envirnments to consider?
LabView seems to be horribly expensive.
Comments please
Offline edpalmer42
Re: HP VEE or LabView
« Reply #1 on: April 25, 2017, 10:48:50 pm »
Labview Home Bundle - $50 - deliver by download so you can have it today!  :-+
http://store.digilentinc.com/labview-home-bundle/
(No relation to seller)
Ed
Offline pigrew
« Reply #2 on: April 26, 2017, 03:20:31 am »
I used HP Vee about five years ago in a previous job. I found it horrendous. It often crashed, and it was very difficult to work with it for large projects or create libraries/modules. I'd only suggest it for small projects with a single developer. Version control will be a nightmare.
I do not have significant experience with LabView. But, my impression is that it is much more reliable than Vee, and is much more popular. I'd go with it if possible. Last I used it, it is not compatible with high-DPI monitors, so the graphics will be ugly or small.
Offline DavidDLC
« Reply #3 on: April 26, 2017, 03:53:25 am »
LabView Student version for $20.00 at studica.com
But you need to be a student, or maybe you want to buy it for one of your kids that are on school.
David DLC
Offline DavidDLC
« Reply #4 on: April 26, 2017, 03:55:06 am »
I will use LabView, because it is widely used on the industry. I have heard and seen more job post requiring LabView knowledge
David DLC
Offline thermistor-guy
« Reply #5 on: April 26, 2017, 05:28:18 am »
I'm writing my own s/w to control test equipment, using gawk (GNU awk) scripts running on a laptop with Cygwin (Linux environment). Later, I'll move the s/w to a raspberry pi.
gawk is turning out (IMHO) to be brilliant for this application. It's a lot of fun, writing code, and seeing it work. I set up remote VPN access to the test equipment LAN, so from off-site I can start, stop, and monitor experiments as they run, or set them up for overnight operation.
If you like Linux, you can do all this yourself, if you want.
« Last Edit: April 26, 2017, 05:39:40 am by thermistor-guy »
Offline mtdoc
« Reply #6 on: April 26, 2017, 05:39:54 am »
Yep Labview Home Bundle. $50.  Easy to learn for basic data logging with a GUI.
