Author Topic: Keithley 2000 / 2015 / 2016 / 2010 VFD to LED Display Conversion  (Read 14876 times)
Offline KhronX
    • Khron's Cave - Electronics Blog
Re: Keithley 2000 / 2015 / 2016 / 2010 VFD to LED Display Conversion
« Reply #25 on: July 04, 2025, 08:16:31 am »
Any idea about the ballpark cost of one of these?  ;D
The pricing will stay the same as it was for our initial display.
You could have possibly considered either typing out the actual number, or at least posting a link to wherever the "initial display" price was mentioned  :wtf:
Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
Offline tooki
« Reply #26 on: July 04, 2025, 08:35:52 am »
Are you going to be offering the new color for 53131A/53132A/53181A also or only for the Keithley line?
These are brand new LEDs that weren't available when the 53131A LED project began.
Honestly we need to sell the first batch of blue displays before we can offer the new color, assuming there's still demand.
I love the new color.
But FYI, cyan LEDs have existed for many years now. I bought my first pack of them over 5 years ago, and I had known of their existence for years before that. One could make potentially even nicer displays using regular pure blue LEDs and adding phosphors to the encapsulation epoxy (in other words, make them the same way white LED displays are made, but with less phosphor, to skew it to baby blue). And of course white LED displays, filtered with a color gel, would have been another, very viable approach. Pure blue LED displays are awful.
« Last Edit: July 04, 2025, 08:38:36 am by tooki »
The following users thanked this post: dimmog
Offline Shimonu
« Reply #27 on: July 04, 2025, 01:34:43 pm »
Where will these be available for purchase?
Offline dimmogTopic starter
    • Hubequip
« Reply #28 on: July 05, 2025, 06:43:58 pm »
I meant LEDs in a form factor suitable for display production. Of course, this color has been around for a while.
Hubequip.net :: test equipment parts and more
www.hubequip.net
    • Hubequip
« Reply #29 on: July 05, 2025, 06:46:21 pm »
They will be available on hubequip.net or ebay
www.hubequip.net
Online KungFuJosh
  • TEAS is real.
« Reply #30 on: July 05, 2025, 06:57:51 pm »
Are you going to offer the 53132A LED displays in different colors too?
Thanks,
Josh
Best Continuity Tester Ever
    • Hubequip
www.hubequip.net
Online KungFuJosh
  • TEAS is real.
« Reply #32 on: July 05, 2025, 07:51:49 pm »
https://www.eevblog.com/forum/testgear/keithley-2000-2015-2016-2001-vfd-to-led-display-conversion/msg5966177/#msg5966177
Thanks. I already ordered the blue one anyway. Too bad they don't have color switchable ones. ;)
Offline tooki
« Reply #33 on: July 06, 2025, 08:43:57 am »
Meaning what exactly? I would have figured that display manufacturers buy LEDs as bare dice from an LED foundry.
And of course, as I said, making phosphor-converted light blue doesn’t require any special LEDs at all, just the same blue they use for white LED displays. That’s literally just a matter of using less phosphor in the epoxy (and ideally, tweaking the phosphor blend to get just the right hue).
    • Hubequip
« Reply #34 on: July 06, 2025, 05:50:51 pm »
That's not accurate. The display manufacturer uses standard off-the-shelf SMD LEDs that match the required package dimensions, color, and power specifications.
www.hubequip.net
Offline tooki
« Reply #35 on: July 07, 2025, 07:27:58 am »
Oh, it’s not the kind where the display is potted in epoxy, like individual LED displays are? (Those have essentially a metal leadframe inside, with LED dice bonded directly on.)
Of course, this doesn’t change the fact that the manufacturer could have procured the desired color SMD LEDs. Sure, cyan isn’t as common as regular blue, but definitely are available in basically the whole range of packages and power levels.
Offline Taviman
« Reply #36 on: July 16, 2025, 06:17:58 am »
Unfortunately, the K2700 uses DD-61, which is different from DD-52.
    • Hubequip
« Reply #37 on: July 16, 2025, 03:28:40 pm »
You're correct. They appear to be partially compatible. Unfortunately, the only difference seems to be in the annunciators.
www.hubequip.net
« Reply #38 on: July 18, 2025, 05:23:48 am »
I was planning a oled conversion for my 2 units with dim display.
But your solution will save me a lot of time so I will be following this post.
Benno
Have you seen this?
https://github.com/RM-Engineering/Keithley-2000-replacing-the-VFD-with-a-5.5-inch-OLED-
Online BennoG
« Reply #39 on: July 18, 2025, 05:33:07 am »
Have you seen this?
Yes I have but it involves destructive modifications to the front pannel.
« Reply #40 on: July 18, 2025, 05:48:08 am »
Have you seen this?
Yes, that is definitely a drawback.
    • Hubequip
« Reply #41 on: July 28, 2025, 05:37:06 pm »
The Keithley 6485 and 6487 Picoammeters appear to use the same display as the 2000 model.
www.hubequip.net
Offline skysurfer
  • Country: hu
« Reply #42 on: August 15, 2025, 10:17:30 pm »
I would be interested too for your project! This is a great instrument that is poised to death without these kind of conversions. I will stay tuned!
Laszlo
Offline minsik
« Reply #43 on: October 12, 2025, 12:31:42 am »
also interested in a 2015THD kit when available. Great work.
Confirm order placed and paid for 16/10/2025.
« Last Edit: October 17, 2025, 04:06:49 am by minsik »
Years of working with electronics. Now its just for fun.
    • Hubequip
« Reply #44 on: October 14, 2025, 01:48:55 am »
Hi everyone.
Sorry for the delay, those tariffs aren't helping. Here's a long-awaited update: we've finished the board design and tested several prototypes.
We expect to begin mass production in about two weeks!
www.hubequip.net
The following users thanked this post: Smokey, kilobyte, Zucca, yo0, Qw3rtzuiop, tooki, TizianoHV, EC8010, the Chris
Online KungFuJosh
  • TEAS is real.
« Reply #45 on: October 14, 2025, 02:04:16 am »
That looks great!
The following users thanked this post: Smokey, yo0, dimmog
Online BennoG
« Reply #46 on: October 14, 2025, 05:41:48 am »
I can not wait, can we preorder ?
Benno
Offline the Chris
« Reply #47 on: October 14, 2025, 07:39:59 am »
That's awesome, you made the digits larger than the original ones, a big plus imho  :-+
    • Hubequip
« Reply #48 on: October 14, 2025, 03:00:48 pm »
Yes, the digits are larger. This is one of those cases where manufacturing limitations actually worked in our favor.
I personally really like the bigger digits compared to the original display, which I always disliked for their small size.
That's why I used the 34401A more frequently than the Keithley.
However, there is one drawback. Since the display visible area is slightly larger, the conversion process is a bit more complex. Thanks to the Keithley engineers.  :-//
I'll make a separate post describing the minor front panel modification in detail.
« Last Edit: October 14, 2025, 03:06:40 pm by dimmog »
www.hubequip.net
    • Hubequip
« Reply #49 on: October 14, 2025, 04:26:16 pm »
Front Panel Mod for Keithley 2000/2015 LED Display Upgrade
So, about the front panel mod for the LED display upgrade. For some reason, Keithley engineers decided to paint
the left and right edges of the display window to hide some parts of the original VFD (see pic 1).
Not sure why they did that, but for the LED display, we need to remove some of that paint.
It wasn't possible to make the LED display with the exact same digit size (tech limitations), but honestly, that turned out
to be a good thing. The new digits are much bigger and now is way easier to read from across the bench.
The mod itself is simple and takes about 20–30 minutes. We found that the paint on the acrylic window dissolves nicely with
regular nail polish remover. This is super important - don't use 100% acetone nail polish remover, it will melt the acrylic.
Here's the basic process (also covered in the instructions that come with the LED kit):
Mask off the areas with painter's tape. (see pics)
Apply some nail polish remover and let it sit for a minute or two.
Use Q-tips dipped in the remover to gently rub off the paint.
After that, the window might get a few fine scratches.
You can polish it with Novus plastic polish (I used a two-step process, worked great).
This step is optional though. It'll look fine without polishing too.
We're still deciding whether to include the necessary materials in the kit or just leave that up to you.
Nail polish remover and Q-tips are easy to "borrow" ;) from your wife or girlfriend anyway, and the Novus polish can be grabbed on Amazon.
What do you guys think. Should we include all the materials in the LED display kit?
Keep in mind we probably can't ship liquid chemicals overseas, so this would be for North America only.
« Last Edit: October 24, 2025, 05:25:24 am by dimmog »
www.hubequip.net
