Author Topic: Keithley 236/237/237 interlock connector  (Read 1753 times)
Offline balageTopic starter
  • Country: hu
« on: September 16, 2020, 10:27:14 am »
Hi Fellowes,
Can anybody help me identify which connector fits the rear interlock connector of the good old Keithley SMUs?
This is the 3-pin version, not the 4 that is used with the picoammeters. I just want to try buying one instead of changing them to LEMOs instantly.
Thanks
Offline coromonadalix
Re: Keithley 236/237/237 interlock connector
« Reply #1 on: September 16, 2020, 10:29:58 am »
can you give me some diameters measurements, pins spacing  etc ..... not sure but i think i have a tons of them at my job ... i have the chassis mount too, not pcb mount
« Reply #2 on: September 16, 2020, 11:20:16 am »
so far
external   od                 8mm
space between pins     3mm   ?
Switchcraft  tiny QG  series,  model TA3FX
pdf attached
« Last Edit: September 16, 2020, 11:22:22 am by coromonadalix »
The following users thanked this post: balage
  • Country: hu
« Reply #3 on: September 16, 2020, 12:26:06 pm »
On the images it seems this is the one I need. And available at Mouser and Digikey.
I will measure the dimensions to be sure, but it must be the one!
Thanks! Recognizing a specific connector on an image - that needs experience. :D
Offline justanothername
  • Country: at
« Reply #4 on: September 16, 2020, 01:17:56 pm »
It is known as "mini XLR connector"
