Author Topic: Lecroy options -=recovery=-  (Read 186725 times)
Offline sprit
  • Country: vn
Re: Lecroy options -=recovery=-
« Reply #350 on: August 17, 2026, 08:14:09 pm »
Did anybody know calibration procedure of the MXS-B series? I typed in the code to access the system menu, but I couldn't find the calibration section there. Currently, one of the four channels is displaying a sine wave at a frequency of 3MHz.With an amplitude of approximately 500mV even though nothing is connected. I searched the development and production menus but couldn't find that item. Maybe this model doesnt have that option?
Thanks
Feng.
“To live is the rarest thing in the world. Most people exist, that is all.”
Offline Momchilo
« Reply #351 on: August 19, 2026, 03:15:38 pm »
Never heard that someone performed a calibration by himself on those scopes. This is only possible in the Lecroy factory as far as I know.
A 500mV sine wave doesn't sound like a calibration issue but more like a hardware issue.
Offline sprit
  • Country: vn
« Reply #352 on: August 21, 2026, 03:48:44 am »
Thank you for your reply.
I checked again, and it's likely that some contacts weren't properly connected during the disassembly and reassembly process, leading to this issue. I disassembled the FE board and reassembled it, and now everything is fine. I also updated it to Windows 7 with the latest 8.6 software and everything works quite stably, and I can even connect to the internet and watch YouTube hahaha. But this model is quite noisy... I still haven't found a fan model with slightly higher power but less noise. Cramming a bunch of components into a small body causes the machine to constantly operate at high temperatures. Does anyone have any suggestions? Thank you.
Regards,
Feng.
Offline jujava
« Reply #353 on: September 10, 2026, 10:42:50 am »
Dear all,
I just want to report on my attempts to improve on a lecroy 960 wavePro 2GHz. Originally it was 1Mo max acquisition memory with 64Mo of Ram.
Opening it (following the post about a similar 950 model found on the forum) was quite easy but the bezel is very brittle (maybe plastic aging). I could not avoid breaking it in a corner dismounting it ... and breaking it again in the same bottom corner after gluing it when I mounted the scope back together. Yet this is a detail solved with tape.
Beyond cleaning a bit inside I could install the network option (totally made of unobtanium but by luck I found a card on ebay for 100€).  It is not accepting auto-negotiation for RX-TX and needs a crossed cable, unless your network card on the PC is able to make the switch itself. The card is 10MBit/s and not 100. It means the theoretical peak is 1.25Mbytes/s and indeed, I could reach 1Mbytes/s on large transfer (a few MBytes at least) using VICP protocol (scope is older than LXI-VXI so you need to make creative coding) Comparatively, a USB-GPIB directly connected to the scope would give me 300kB max, on equivalently long transfers. I let you judge if a factor 3.3 justifies the work and the money. For me, it did.
I installed on the main board (easy access) a second hand 512Mo stick of SDR133 memory. Some sticks of 512 were recognized only as 128Mo while another (kingston value ram) got me up to 256Mo. I could not get anything better and I dont know if 512Mo can be recognized properly. I updated to the last bios/firmware available.
With the kind help of forum user Momchilo I could understand how option licence would work. I could increase acquisition memory to 64Mo putting option M, then L, then VL and XL. Notice that with the original stick of ram of 64Mo, acquisition memory was capped at 4Mo. It is quite certain that the ADC Memory is the same on all scopes of this series as mine was having the poorest configuration and could be improved to the max, the RAM can limit the effective memory depth, even with all options installed and you need at least 256Mo of RAM to get 64Mo acquisition memory working properly. (with 128 I had 32 working and with 64 RAM only 4Mo data). Quite possibly, the data from ADC memory goes to the main RAM before being displayed which would explain the limitations.
That is all, with those improvements this scope is totally usable for my applications. Big screen, decent transfer speed, nice bandwidth and --insane-- acquisition memory, still up with modern standards. Consider that the equivalent Lecroy DDA-260 can be found very cheap on ebay <800€. For people who need bandwidth+large memory and dont mind the 30kg and the associated fan noise, I find this 25 year old dinosaur to be still competitive.
thank you again for all your help, in particular Monchilo, and dont hesitate if you have any questions
JJ.
Offline Seatek1
« Reply #354 on: October 01, 2026, 10:27:44 pm »
Does anyone have the python setup for recovery of lost options?
« Last Edit: October 09, 2026, 08:26:55 pm by Seatek1 »
Offline ollopa
« Reply #355 on: October 02, 2026, 01:45:11 am »
Does anyone have the python setup to get 16 digit hex keys for Lecroy LT584?  I would like to install the same 6 options in 2 different scopes:  JTA PMA1 ATP DFP EMM WAVA.
PM sent.
Offline Seatek1
« Reply #356 on: October 02, 2026, 02:47:55 am »
PM sent.
« Last Edit: October 09, 2026, 08:35:56 pm by Seatek1 »
Offline Seatek1
« Reply #357 on: October 02, 2026, 03:00:53 am »
ATP
« Last Edit: October 09, 2026, 08:31:46 pm by Seatek1 »
Offline Seatek1
« Reply #358 on: October 02, 2026, 03:58:33 am »
PM sent.
Ollopa:  You are a life saver.  My gratitude to you for your help.  I am having difficulty replying back to you.  I think it is because I don’t have 10 posts yet.  Thanks again.
Offline Seatek1
« Reply #359 on: October 03, 2026, 03:05:44 pm »
Can someone help me with hex code keys for recovery of some options?
Many thanks.
« Last Edit: October 09, 2026, 08:29:15 pm by Seatek1 »
Offline Seatek1
« Reply #360 on: October 03, 2026, 04:57:14 pm »
Need help with hex code for software keys for 2 Lecroy LT scopes.
Thanks.
« Last Edit: October 13, 2026, 12:54:23 am by Seatek1 »
Offline Seatek1
« Reply #361 on: October 09, 2026, 08:34:17 pm »
Need help with Python and Python.py.
