Author Topic: List your test equipment "scores" here!  (Read 786557 times)
Offline Berni
  • Country: si
Re: List your test equipment "scores" here!
« Reply #2275 on: February 07, 2019, 03:58:22 pm »
From what i hear the thing has a pretty extensive self test that takes a long time to run in order to test the stability of various parts. If it passes that and shows a waveform then its a good. If one of the sampling modules is busted then spare ones are easy to come by for a reasonable price.
Definitely a good idea to hold on to one of these.
Offline Martin.M
  • in Tek we trust
    • vintage Tek collection
« Reply #2276 on: February 07, 2019, 05:44:55 pm »
49,- including postage  :)
Offline Berni
  • Country: si
« Reply #2277 on: February 07, 2019, 05:54:13 pm »
I have heard of widescreen being a thing with scopes these days...but don't think that's the right way to do it.
But im sure a bit of poking around in the vertical deflection circuitry can sort it out. Nice price for it.
The following users thanked this post: LapTop006
Offline Ice-Tea
    • Freelance Hardware Engineer
« Reply #2278 on: February 07, 2019, 07:09:47 pm »
Pfftt.. Have you checked the 11801C? None of that widescreen rubbish. Ultra-narrow-screen FTW!
Offline shakalnokturn
« Reply #2279 on: February 07, 2019, 07:10:41 pm »
@ Martin.M
Decent price if you were sure there was only the display problem, no bad surprises on inputs or acquisition stuff.
All the same considering sample rate and memory depth, this is the kind of scope I'd buy only to fix and play around with a few hours before reselling.
« Last Edit: February 07, 2019, 07:12:37 pm by shakalnokturn »
Offline Martin.M
  • in Tek we trust
« Reply #2280 on: February 07, 2019, 07:27:46 pm »
the repair was only 30 minutes.  :)
« Reply #2281 on: February 07, 2019, 08:10:18 pm »
That leaves you a little more play time  :-+
I followed the repair on the TEA thread, BD139 almost had it fixed before you bought it  :-DD
« Reply #2282 on: February 09, 2019, 11:45:09 am »
Yep, what bd139 doesn't know about scopes isn't worth knowing, he's the man.
Offline Neomys Sapiens
« Reply #2283 on: February 11, 2019, 11:15:04 pm »
I got a case with 6 prehistoric Teledyne Philbrick op-amps (you understand immediately where the 'brick' comes in) and the circuit elements formerly used with them. Complete with the leaflet (i'll scan it later).
It must have been part of some educational breadboard or related.
Factually, I would have gladly spent the 30€ for the heap of Pomona double plugs with solder turrets on the side. Or for the 3  clean and 3 cleanable Pomona 2-pole cables. And that case might come handy too.
So now I can add ready-made combinations on 3/4"-spaced 4mm plugs to my kits (in addition to the 50R from Beanflying). For example a PTC like Fluke sold with the 025, or RCs, or antiparallel diodes....
The following users thanked this post: Ysjoelfir
Online BravoV
  • +++ ATH1
HP 5347A and Tektronix 2465
« Reply #2284 on: February 13, 2019, 11:05:06 am »
A 5347A with lots of dead LCD segments, and a dead 2465.  :P
Offline ascomm
« Reply #2285 on: February 13, 2019, 11:37:00 am »
Hitachi analog 20MHz oscilloscope, 20€.
« Reply #2286 on: February 26, 2019, 02:26:05 am »
So I have splurged in the last week or so. Agilent 34461A, Fluke 335D neither of which were particular scores but are in great condition.
This is the score I had more or less given up on ever getting one of due to their normal second hand price. Sika Temperature Calibrator complete with different diameter wells. Delivered to my door will be circa $150USD  ;D
One very very broke but happy Bean.
Offline Ice-Tea
« Reply #2287 on: February 27, 2019, 01:09:52 pm »
Hmmm...  :-/O :-/O :-/O
The following users thanked this post: salvagedcircuitry
Offline SoundTech-LG
« Reply #2288 on: February 27, 2019, 05:23:40 pm »
An HPAK E3631A sold as parts only. Yes, it needed a rotary encoder...  not so bad. The display was pretty good, but I decided to replace it anyway, and keep the old one as a spare. Lots of floppy pins to deal with on that. All on the cheap. Wanted one of these for a long time, but was unwilling to pay even $300 for one.
Offline Ice-Tea
« Reply #2289 on: February 27, 2019, 06:28:24 pm »
Aaahh...  :clap:
Offline Cubdriver
  • Nixie addict
    • Photos of electronic gear
« Reply #2290 on: February 27, 2019, 06:36:34 pm »
 :o Damn!!
-Pat
« Reply #2291 on: February 27, 2019, 09:43:53 pm »
@ice-tea: what is the meaning of the blue tape? It affects a device which I would be interested in (depending on subtype and options).
Offline 0culus
« Reply #2292 on: February 27, 2019, 09:55:48 pm »
Wow that's a lot of TEA in one box!  :-DD
Offline bitseeker
« Reply #2293 on: February 27, 2019, 10:28:36 pm »
Aaahh...  :clap:
Ice-Tea continues to live up to the TEA in his name. :-+
TEA in a box. I like it!
Offline LapTop006
« Reply #2294 on: February 27, 2019, 11:15:12 pm »
Aaahh...  :clap:
The R&S kit without the screen, is that a cover, or an option for no-screen purely GPIB/LAN control?
Offline 0culus
« Reply #2295 on: February 27, 2019, 11:22:36 pm »
Aaahh...  :clap:
Heh! A very very heavy box!  :-DD
Offline Ice-Tea
« Reply #2296 on: February 28, 2019, 05:04:46 am »
Nothing or so it seems. Maybe an aide to help them sort different orders out or something. Some of these units are not ready (ie need service) others are fine and they all came with blue tape.
Aaahh...  :clap:
GPIB control only
Aaahh...  :clap:
Carried it all up two flights of stairs. Including those HP8642B's that weigh over 30kg each.
Offline Ice-Tea
« Reply #2297 on: February 28, 2019, 12:52:49 pm »
Aaahh...  :clap:
GPIB control only
[/quote]
Allow me to correct myself here... The frontpanel buttons still work and make it pretty easy to control the unit. Just no display to tell you what you set it to :D
Offline CJay
« Reply #2298 on: February 28, 2019, 05:07:48 pm »
Interesting, how much are they worth without a screen?
Offline Ice-Tea
« Reply #2299 on: February 28, 2019, 05:49:49 pm »
*points to signature*
Just put one on the bay. Outside of eBay it's 10% less. If you can do a bank transfer iso Paypal, that's another 3%.
21% VAT is included, if you have a VAT ID that can be dropped as well.
