I'm up past my bedtime playing with a new toy...
Holy crap, Batman! This thing is pretty awesome. I think Batronix has been spying on all the things we complain about other scopes not having, and made sure to put them in this thing.
My first impression is that it's a nice design, mostly intuitive, with a few rough edges waiting to be smoothed out with updated firmware.
The two big things, which I believe will be resolved soon: the lack of a dedicated counter, and the web server. Once those things are mature, this is going to kill a lot of scopes on the market...at least for me anyway. I guess it already did.
The screen is awesome, no question about it. I'm very happy about the 10MHz external reference input, but it was a little awkward to find it in the acquire menu, which I guess sorta makes sense. I found it though! Haven't had to read the manual yet.
Something that bugged me on other scopes was cursors were only able to be defined by the X axis. Magnova works on X or Y axis, and it's awesome.
Another thing I love is how you can mess with the split screen section sizes. Make whatever you want, whatever size you want, and without any effort.
The touch display in general feels responsive and quick. Generally not waiting for things to happen, which is great. Even the FFT is fast and responsive, no matter what I do to it. I can adjust the start and stop points, no lag, no issues, and doesn't start over for no reason.
I did manage to get it to crash in the first few minutes of using it. That was frustrating because, it was the first few minutes, and all the customization settings, time zone, etc. got lost and had to be redone after power cycling the scope. I made sure to set everything, save a settings backup, and power cycle the scope before screwing around again.
I'll see if I can get it to crash again, but the way I did it was FFT on CH1 setup (see photo), but I hadn't selected measurements yet. It was when I was selecting measurements that it crashed, after I got to the 5th measurement added, the scope froze and wouldn't respond at all. Next time I picked my measurements before starting FFT, and there were no issues.
The screenshots were saved directly to a Kingston 128GB flash drive, no issues with that either.
I don't love the side jacks. It's impossible to use/mount the way I wanted to, and I'm going to have to buy a rack to mount it in and make it work well on my bench. But it's worth it! I really dig the scope. Obviously.
One thing that is slightly concerning is how hot it seems to run. The right side of the scope gets pretty hot, and all the jacks and everything connected takes heat too. The metal BNC connector on the cable was hot, the metal shell of the Kingston flash drive was also hot. Thermal camera said max of about 115F, which isn't crazy, but is that normal? I assume if I change the default fan settings that should improve. Perhaps tomorrow I'll try that out.
Thanks,
Josh
