Author Topic: Magnova oscilloscope  (Read 340497 times)
ADT123 and 55 Guests are viewing this topic.
Offline Martin72
Re: Magnova oscilloscope
« Reply #75 on: April 09, 2024, 10:38:16 pm »
Sample rate is one of the most powerful selling points of all, and they will certainly not have voluntarily given up "more".
I don't know the architecture, but there may have been no other way.
More sample rate is "better", even if the bandwidth is not so high, keyword fast signals and their correct display.
The following users thanked this post: egonotto, rusoaie
Offline Fungus
« Reply #76 on: April 09, 2024, 10:44:42 pm »
2x1.6 GSa/s sampling rate (while being capable of sampling at 4x1 GSa/s) seems like an unusual choice. Any idea why they would do that?
Maybe less crosstalk between channels at the slightly reduced rate...
Offline tggzzz
« Reply #77 on: April 09, 2024, 10:53:29 pm »
Nobody has ever demonstrated I could hear a smartphone, so there's no point in my having one.
You don't know about messaging apps?
Not a phone call. Requires the other person to have access to the right app.
Good luck calling for an ambulance , or similar.The
Won't fit in trouser pocket alongside keys (for more than 5mins).
My phone has survived being dropped off a roof onto concrete. Daughter's can't survive someone gently sitting on it.
« Last Edit: April 09, 2024, 10:57:16 pm by tggzzz »
Offline tggzzz
« Reply #78 on: April 09, 2024, 10:59:40 pm »
Bandwidth is king. Samples/s beyond the minimum necessary is marketing wank.
Good to see this device has a light mode GUI.
Offline nctnico
« Reply #79 on: April 09, 2024, 11:22:08 pm »
I think that still qualifies as a (Maxwell) SMART  Phone
From the discussion The Magnova Scope appears to be a fine device. I guess if I needed a new scope,I would consider it.. Now we have to wait till a few folks try it out.
It all depends on how well everything works when introduced. The specs can be great on paper but it needs to work for real. Too much vapourware is being put out nowadays and promises made features will be added after buying the product. Given the specs the development effort (and thus costs) to bring a product like this on the market is huge. You can easely sink a 7 digit euros figure into developing an oscilloscope like this due to the sheer amount of development time needed. It is a brave thing to bring out a product like this in a very competitive market but also very risky.
What would be interesting is whether this scope can bridge the gap between typical signal analysis oscilloscopes and oscilloscopes which are more suitable for doing embedded work. That would be a major achievement.
« Last Edit: April 10, 2024, 08:12:07 am by nctnico »
Offline tooki
« Reply #80 on: April 10, 2024, 01:19:25 am »
the signal acquisition rate of 300,000 wfms/s (12,000,000 wfms/s history mode) beats everything I know so far by light years.
300K is not even close to “beats everything”. Keysight 3000-series and up all do 1 million, and R&S MXO 4 and MXO 5 do 4.5 million.
The following users thanked this post: pdenisowski
Offline egonotto
« Reply #81 on: April 10, 2024, 01:33:41 am »
Hello,
I mean the 12,000,000 wfms/s history mode.
Best regards
egonotto
The following users thanked this post: Doctorandus_P
Offline DaneLaw
« Reply #82 on: April 10, 2024, 01:35:36 am »
His own current MHO3 scope is likely quite close to that 300.000 peak with 360mpts in auto mem mode
If I recall the MHO3 unit got 230.000wfps/360mpts on paper, and Micsig had a tendency to undersell their ratings, which in practice were quite a bit higher.
but Keysight 3000 series, got what 4mpts?
Same with the 1000 series that got 2Mpts and on paper will do 200.000.. but one thing is specifications..
I remember Dave comparing Tek's new MSO2 series with an appalling slow update rate to Keysight DSOX1204G that peaked at around 50k to 55k..even though 200k on paper, but it's a long time ago so very likely something I missed.
But 300.000 with 320mpts in normal mode on Magnova is definitely a good start.
« Last Edit: April 10, 2024, 01:55:46 am by DaneLaw »
Offline egonotto
« Reply #83 on: April 10, 2024, 01:54:50 am »
Hello,
the high wfms/s can only be achieved with small memory. With 3 Gpts/s, 36 kpts already require 12 us. The maximum wfms/s that can be achieved here is less than 84 kwfms/s. With larger memories than about 12 kpts, the specified 230000 wfms/s will not be achieved.
Best regards
egonotto
« Last Edit: April 10, 2024, 01:57:01 am by egonotto »
The following users thanked this post: tautech, 2N3055
Offline DaneLaw
« Reply #84 on: April 10, 2024, 02:14:22 am »
Hello,
the high wfms/s can only be achieved with small memory. With 3 Gpts/s, 36 kpts already require 12 us. The maximum wfms/s that can be achieved here is less than 84 kwfms/s. With larger memories than 12 kpts, the specified 230000 wfms/s will not be achieved.
Best regards
egonotto
What are the highest waveforms you can encounter, is it 230k? the fact that it's highly timebase dependent is what it is, and the same across the scene,
but to make it somewhat apples to apples...Your highest peaked waveform update rate in normal/auto mode.
Did you try to follow the video from the MHO3 thread?? What waveform peak value did you get with that approach?? also at 50ns it peak'ed at?
To put Magnovas 300k in normal mode into perspective. the Tek2 series that resamples it a little and around the same base price.. the highest waveform update rate Dave could muster with it was around 18k with just 250 mem-points, and obviously also in a fast timebase mode like 10ns or 50ns, but 18k is pretty dang slow with 10mpts (per ch)... that is even slower than DHOxxx series (that according to Daves video) peaks at around 27k in normal mode.
The add-ons for the Magnova seem like a mixed bag, but mainly down to the fact that BW-SW update pricing reflect MSRP & not the current introductionary pricelevel.
LA 200€       [1*Set of digital logic probes 8 channel + 2 ground -8v /+8v  1600MSa/s]
AWG 400€    [Waveform Gen hardware module.. Arbitrary & isolated Wav gen with 1 channel & 90 MHz bw (sine) sampling rate of 400 MSa/s].
BW upgr. 100 to 200MHz  1000€
BW upgr. 200 to 350Mhz  1000€
BW upgr. 100 to 350Mhz  2000€
[+ VAT]
« Last Edit: April 10, 2024, 03:14:13 am by DaneLaw »
Offline egonotto
« Reply #85 on: April 10, 2024, 03:49:22 am »
Hello,
as I have written in the Micsig thread:
it is 8.1 Hz with 360 MS
and 40 Hz with 10 ns/div and 1.8 kS
50 kHz with segmented memory 1 ns/div and 1.8 kS and 10000 segments.
But the intervals between individual trigger points are sometimes only about 1.1 us.
It looks like there are still errors. I also cannot change the brightness of the waveform.
Best regards
egonotto
Offline emerald13
« Reply #86 on: April 10, 2024, 07:23:36 am »
Here a short video just taken at our booth at embedded world 2024. Showcasing some example setups for our new Batronix Magnova BMO series.
https://youtu.be/GuHaMUE857w
« Last Edit: April 10, 2024, 07:31:32 am by emerald13 »
The following users thanked this post: egonotto, Mortymore, pdenisowski, KungFuJosh, Martin72, core, Anthocyanina, RAPo, axantas, Andre77, fredo_
Offline emerald13
« Reply #87 on: April 10, 2024, 08:23:42 am »
The following users thanked this post: egonotto, Mortymore, pdenisowski, KungFuJosh, Martin72, core, Anthocyanina, Andre77, fredo_
Offline Martin72
« Reply #88 on: April 10, 2024, 08:43:37 am »
I would also like to have the direct display of the wfms/s.... 8)
Offline ebastler
« Reply #89 on: April 10, 2024, 08:51:49 am »
Yes, that caught my eye too. Whether one is just curious about scope performance, or wants to optimize the settings to search for rare events, it's convenient to have that information without the need for a counter on Trigger Out. Oh, and I guess bragging rights are yet another application for that display.  ;)
The following users thanked this post: egonotto, jusaca, Anthocyanina
Offline joeqsmith
« Reply #90 on: April 10, 2024, 12:32:11 pm »
Guy turning the adjustment knob on the one video didn't seem to sure they wouldn't damage it.
I'm curious how fast they can update the screen.  Also what techniques do they offer to look at deeper memory and how responsive is it.
Online Anthocyanina
  • The Sara
« Reply #91 on: April 10, 2024, 02:22:24 pm »
the 200k waveforms per second on the keysight 1200x was after a firmware update. Dave said he didn't have the latest firmware on it and so it was limited to the original ~50k wfms/s
Offline Fried Chicken
« Reply #92 on: April 10, 2024, 03:18:22 pm »
oooooooooooooooooooooo
Offline SarielTopic starter
  • Country: il
« Reply #93 on: April 11, 2024, 12:15:17 pm »
What is the noise floor for different V/div settings?
Offline hpw
« Reply #94 on: April 11, 2024, 12:50:32 pm »
Not only this:
- ENOB as most Siglent HD still at 8..9?
- ERES supported or as only full BW?
- Jitter of the reference clock see LeCroy figures for HD series  :phew:
- external clock connection?
- Custom Probe attenuation, Siglent 1E6...-1E6
- Custom color settings for trace and text ?
just my 2 cents, while those are not really cheap. IMHO. so real specifications to provide and not only to attract turtles / rubias.
Offline vk6zgo
« Reply #95 on: April 12, 2024, 01:57:05 am »
and another one...
https://youtu.be/9nBShoROJb0
Why do people love this weird way of displaying a waveform?
It seems to be the default amongst YouTubers but in my experience, is not really something which is used in practice.
The signal input is conventional AM as is shown on the signal generator display & the normal way to display it on a 'scope would be triggered by the modulation, showing several cycles of the RF envelope at the modulation frequency.
Such a display allows a rough measurement of modulation percentage & linearity, which are things which would be important to someone using AM.
The display which is commonly used in YouTube videos is triggered at carrier rate, showing several cycles at that frequency, with the waveform amplitude variation shown as in the above video, which may disclose some information, but just seems to be used for a "pretty" display.
Magnova are at least using it to obtain the time interval between zero crossings, although my old HP22s calculator disagrees a bit as to frequency for that time interval, but why not just use a CW carrier?
On reflection, the weird display may be useful for obtaining a very approximate measure for Incidental Carrier Phase Modulation,
The only time I have ever tested for ICPM was with an analog TV transmitter, & that was just because NEC showed how to do it in their handbook.
Offline joeqsmith
« Reply #96 on: April 12, 2024, 12:09:56 pm »
I wonder from a review standpoint, if using some of the X-Y analog scope, musical demos would be any benefit.  Obviously the idea is not to start the debate  of analog vs digital that we see repeating in the forums, but rather to get some feel as how they update the screen.
Offline Antonio90
« Reply #97 on: April 12, 2024, 01:04:41 pm »
¿Could we have a working example of the Bode/FRA feature?
What's the maximum frequency? Is it the 90MHz of the AWG?
« Last Edit: April 12, 2024, 01:54:28 pm by Antonio90 »
The following users thanked this post: egonotto, core
Online KungFuJosh
  • TEAS is real.
« Reply #98 on: April 12, 2024, 01:35:47 pm »
With very little effort, and lowered memory depth, I was able to get a very responsive musical demo on my digital scope. I posted it in the SDS2000X Plus thread.
Best Continuity Tester Ever
The following users thanked this post: egonotto, Anthocyanina
Offline joeqsmith
« Reply #99 on: April 12, 2024, 03:22:21 pm »
Thank you very much.  I don't normally follow the scope threads and would never have seen it.
https://www.eevblog.com/forum/testgear/siglent-sds2000x-plus-coming/msg5424095/#msg5424095
Could you please post the audio track you used along with any information about the setup.   Basically, I would like to attempt to replicate your setup using my scopes and see how they compare.
