Author Topic: Magnova oscilloscope  (Read 339074 times)
Offline ebastler
Re: Magnova oscilloscope
« Reply #200 on: April 22, 2024, 12:30:21 pm »
In those long years where you have only been reading the forum and were not registered to post yet, a lot of words have been penned up. It must be a relief to finally let them go.
The following users thanked this post: egonotto, Qw3rtzuiop, jusaca, core, EE54
Offline core
« Reply #201 on: April 22, 2024, 01:24:57 pm »
@moerm
I'm sure you're a fun conversationalist in real life  ;D
Offline moerm
  • Country: aq
  • pragmatic realist
« Reply #202 on: April 22, 2024, 01:43:53 pm »
Friendly reminder: The topic of this thread is the new Magnova ;)
VxWorks - Yes! Linux - meh. Windows - Thanks no, definitely.
The following users thanked this post: TUMEMBER, core
Offline core
« Reply #203 on: April 22, 2024, 02:29:48 pm »
As for the powerhorse, we know that the Rigol DHO1000/4000 uses Artix-7 XC7A100T and Rockchip RK3399, but Rigol usually wastes resources.
The Siglent SDS1000X HD uses only a Zynq UltraScale+ XCZU2CG, which is somewhat similar to the XC7A100T, but manages to offer a lot more features than the DHO. We know that Siglent uses the resources provided by the hardware very efficiently. We still have no information about the components used in the SDS3000X HD.
Magnova, which can simultaneously process 4-channel FFT spectrum analysis with up to 8 million data points each and display the results on a 1920 x 1080 pixel resolution screen, should have a significantly faster FPGA than the SDS1000.
The following users thanked this post: egonotto, pdenisowski, KungFuJosh
Offline SarielTopic starter
  • Country: il
« Reply #204 on: April 23, 2024, 09:49:17 am »
The following users thanked this post: egonotto, DaneLaw, pdenisowski, Martin72, RAPo
Offline DaneLaw
« Reply #205 on: April 23, 2024, 05:53:23 pm »
The quite common Xilinx Ultrascale+ MPSoC
https://docs.amd.com/v/u/en-US/zynq-ultrascale-plus-product-selection-guide
Any info on how it's powered and if it relies on a separate AC to DC power brick with modern powering protocols?
_From the event vid, it looks like it's AC with AC to DC in-house..
The standard IEC-power connector with a case-inserted handle in the center.
« Last Edit: April 23, 2024, 06:17:45 pm by DaneLaw »
Offline Darkover
« Reply #206 on: April 24, 2024, 09:29:12 am »
Maybe more information can be squeezed from it.
They claim a very good usability with the encoder on the right side and connecting the probes on the right side.
So it is only made for right handed people? I am 101% left handed and can not imagine to use
this scope because my arm will hide the text at the encoder and the probe cable is to short when it is
connected to right side.
Olaf
The following users thanked this post: jusaca, TUMEMBER
Online Ranayna
« Reply #207 on: April 24, 2024, 09:37:33 am »
Olaf
Since the scope does not have any other buttons, it should not be too difficult to enable simple screen rotation. At worst the channel numbering is then upside down, but i would think you should be able to re-order them in software as well.
Offline Antonio90
« Reply #208 on: April 24, 2024, 09:44:53 am »
Olaf
The probes on the right side can indeed be a problem for left handed people. Right handed too, if you have to move them to the left to measure something. I'm not a fan TBH, and I don't think BNCs are on the bottom for nothing, it's actually better for usability, and what we find on Magnova, some Micsigs, and all(?) handhelds is a compromise of the form factor. (For bench use)
As for the encoder and touch, I'm not sure. I have test equipment on the left side of my bench which I often use with the left hand without problem. Pushing buttons/screens or rotating encoders is not really hard work for the offhand IMO.
Rotating the screen would mean removing and reattaching the stand. We don't know if that is supported, and I doubt it. For starters, the handle is integrated in the case and would likely block the procedure. Cooling is passive too, and convection does play a fundamental role, as opposed to forced ventilation. I don't know if putting it upside-down would affect the thermal design, though.
« Last Edit: April 24, 2024, 09:47:18 am by Antonio90 »
Offline Njk
  • Country: ru
« Reply #209 on: April 24, 2024, 01:30:23 pm »
So they're experimenting with unusual exterior forms, where the input connectors are located at the side of the instrument. That disposition can be handy in certain use cases. But it will not be unusual for a user to find that the side is wrong and the other side would be better, and the solution is to rotate the scope by 180 degrees. So obvious. Any provision for that?
Online Ranayna
« Reply #210 on: April 24, 2024, 01:32:54 pm »
You have good points... The integrated handle and convection cooling make rotating the scope awkward at best, and impossible at worst.
It looks a lot like a tablet scope, but it isn't one after all.
Both things would not be impossible to account for, but way too late now for the first revision.
Online KungFuJosh
  • TEAS is real.
« Reply #211 on: April 24, 2024, 01:41:39 pm »
Unless they already accounted for it, but we don't know since we're all just speculating. 🤷
Best Continuity Tester Ever
Offline joeqsmith
« Reply #212 on: April 24, 2024, 01:57:30 pm »
Interesting idea to rotate the scope.  Personally, having the connections all on one side, left or right, I can't see causing a problem outside burning up more width on the desk.  My current scope has the USB and Ethernet ports on the side.  The cooling fans are also on both sides.  So this area isn't usable anyway.
I normally would be working right in front of the scope.  One concern I would have is not paying attention and putting any tension on cables.   Now we have a tight 90 degree bend rather than straight.
Offline Antonio90
« Reply #213 on: April 24, 2024, 02:09:43 pm »
Mi concern was more about partialy obstructing the screen view when crossing the probes over. But maybe it isn't a problem.
Offline vk6zgo
« Reply #214 on: April 25, 2024, 01:22:34 am »
Why not place the 'scope to the left of the DUT?
That would mean the leads wouldn't obstruct the screen.
The downside is that if you want to use your left hand to adjust the DUT, you will have to swing your head back & forth, or have a swivel chair.
A number of analog 'scopes have the coax sockets on one side, & the controls on all CROs vary, but at least on the more compact ones, area mostly on the left side, & people of both "handedness" used both styles without problems.
Most left or right handed people can quite effectively use the other hand to do things, otherwise, we would all be pretty much disabled.
Online nctnico
« Reply #215 on: April 29, 2024, 12:51:21 pm »
Yokogawa has / had a whole bunch of scopes which have the input & controls under the screen. So the casing is narrow & high.
Since the Magnova is basically a tablet with 4 encoders and 2 push-buttons, allowing to use a rotated screen (0 - 90 - 180 degrees) is only a matter of supporting this in software. From the description is sounds like there is a fan inside so use in a rotated position shouldn't pose a problem cooling wise.
« Last Edit: April 29, 2024, 02:25:46 pm by nctnico »
Offline Antonio90
« Reply #216 on: April 29, 2024, 03:10:33 pm »
They said it is passively cooled.
Rotating it 180 probably isn't a problem, 90° probably is.
In any case, the stand doesn't look reversible. Maybe with a VESA mount, if available.
Online nctnico
« Reply #217 on: April 29, 2024, 04:58:42 pm »
No. From the description: Therefore a fan is unnecessary in normal operation and the Magnova can run silently. This clearly says the Magnova oscilloscope does have a fan. Just that is may not be on all the time depending on use & environment temperature.
The following users thanked this post: Antonio90
Online Martin72
« Reply #218 on: April 29, 2024, 05:26:08 pm »
That's right, that's what it says.
But what would be abnormal operation...
Online KungFuJosh
  • TEAS is real.
« Reply #219 on: April 29, 2024, 06:53:21 pm »
More implies than clearly says, but I wonder how much more speculating we'll do before they drop some more info on us. 😉
Online Martin72
« Reply #220 on: April 29, 2024, 07:19:43 pm »
Yes, there could be more to come. ;)
Offline DaneLaw
« Reply #221 on: April 29, 2024, 08:40:44 pm »
Magnova
New development. New paths.
Rethought. New concept
Silent operation. Enjoy the silence. The passive cooling concept ensures that you no longer have to be disturbed by fan noise. With the Magnova, the largest heat sources (processor, FPGA, RAM) are thermally connected directly to the metal case. This means that most of the heat is dissipated directly outside the case. Therefore a fan is unnecessary in normal operation and the Magnova can run silently.
I do get the impression it's a passive cooling concept, but the wording " unnecessary in normal operation" do make you wonder, as what is normal versus non-normal usecases with an oscilloscope.
Online KungFuJosh
  • TEAS is real.
« Reply #222 on: April 29, 2024, 08:45:34 pm »
Watching youtube probably counts. 🤷
Offline core
« Reply #223 on: April 30, 2024, 05:16:58 am »
I wonder why they announced this oscilloscope, but after almost a month there was no news.
Maybe they just wanted to see how interested users would be. But this method might backfire on them, as it creates unrealistic expectations. Does that "Damn Good Software" exist?
It seems that nowadays rushing might become a habit.
On the other hand, Rigol came out with the new series all of a sudden, in a total surprise. What we know for sure with them is that we are subsequently left with what we originally got. Very little chance of major improvements in firmware.
Offline Andre77
    • Batronix
« Reply #224 on: April 30, 2024, 07:04:51 am »
The Magnova operates up to an ambient temperature of 40°C without the built-in fan. In 'normal' office environments, the fan is therefore switched off. However, if the Magnova is operated in a particularly warm environment (> 40°C), such as on a hot summer day without air conditioning or in some server racks, the built-in fan is switched on.
We presented our prototypes three weeks ago at embedded world and published the first brochure and initial web pages. We are still on schedule to begin delivering the series devices around the beginning of June. The devices are already available for pre-order on our website, and we will release further information in the upcoming weeks. The datasheet will be available in a few days, and the "damn good software" exist. :)
The following users thanked this post: nctnico, egonotto, Kean, newbrain, mahi, 2N3055, jusaca, pdenisowski, KungFuJosh, Martin72, core, RAPo
