Author Topic: Magnova oscilloscope  (Read 283587 times)
Offline Xyphro
Re: Magnova oscilloscope
« Reply #1325 on: November 09, 2025, 03:55:26 pm »
Interesting, that "grip" looks not as efficient heatsink compared to yours. Though likely the thermal design was changed internally a bit further too.
« Last Edit: November 09, 2025, 04:06:28 pm by Xyphro »
Looking for a unique, cheap versatile USB to GPIB adapter with standard USBTMC interface? Build it yourself :-) https://github.com/xyphro/UsbGpib
Too lazy to build one?: https://www.elecrow.com/xyphrolabs-gpibusb.html
Interested in I3C protocol? Check this out: https://github.com/I3CBlaster
Offline Tomki
« Reply #1326 on: November 09, 2025, 04:13:04 pm »
Which Device Version have you got? Mine is 1.0
Offline Xyphro
« Reply #1327 on: November 09, 2025, 04:28:08 pm »
Cannot check for the next 7 days - hanging around a few thousand miles away from home in California :-) But as I just bought it, it'll be likely a newer one.
Online KungFuJosh
  • TEAS is real.
« Reply #1328 on: November 09, 2025, 04:51:29 pm »
Quick question, where did you get these BNC end caps? ;)
I bought these: https://www.amazon.com/dp/B07MM8YHMB
They have a shorting pin that can be unscrewed with a pliers, so more useful than just a dust cover. ;)
Best Continuity Tester Ever
Offline rf-messkopf
  • Mario H.
    • Homepage
« Reply #1329 on: November 09, 2025, 07:36:26 pm »
Mine also has the "grip"-type heatsink and is showing device version 1.0.
Offline egonotto
« Reply #1330 on: November 10, 2025, 12:11:54 am »
Hello,
when referring to  327.2 Mpts and 981.6 Mpts, does 1 M = 1000000 in the physical sense or 1 M = 1048576 in the computer science sense?
Best regards,
egonotto
Offline Andre77
    • Batronix
« Reply #1331 on: November 10, 2025, 07:53:55 am »
BTW: What is the purpose of that strangly shaped metal bracket between AWG module and backside USB ports?
It's a heatsink (Sorry, I must have overlooked your post earlier).
You ordered the Magnova right after the release, so your device is from the first batch.
We changed the heatsink design later on. After testing a few different options, we found that the tube-shaped version was the most effective in that spot. The main heat sources (CPU, FPGA, RAM, etc.) are thermally coupled to this area, and the pipe structure helps to spread and move the heat more efficiently (somewhat inspired by the Bullerjan stove concept).
The difference is small but if you want, I can send you the updated heatsink. You can replace it without opening the device.
Even with your heatsink, the processor core temperature remains below 70 °C under full load, which is also fine.
In the physical sense, 1 Mpts = 1,000 kpts = 1,000,000 pts.
The following users thanked this post: egonotto, jusaca, KungFuJosh, Martin72, rf-messkopf, Christian K
Online Gadolinium
« Reply #1332 on: November 11, 2025, 05:40:02 pm »
I used the magnova today for some noise measurements and noticed (something I also noticed while playing with the demo) that there is no AC-RMS Measurement option. For sure you can AC-Couple the input, but you then still have the ADC-Offset-Voltage in the DC-RMS measurement.
Did I miss a way to measure AC-RMS or is this option simply missing?
The following users thanked this post: Christian K
Offline egonotto
« Reply #1333 on: November 11, 2025, 05:44:05 pm »
Hello,
Std. Dev?
Best regards
egonotto
The following users thanked this post: jusaca, Christian K
Online Martin72
« Reply #1334 on: November 11, 2025, 08:27:18 pm »
Yepp...
The following users thanked this post: Christian K, rusoaie
Online Gadolinium
« Reply #1335 on: November 12, 2025, 04:17:28 am »
Thank you very much. I was too focused on finding word-for-word AC-RMS without thinking for a second about alternatives  :palm:
Offline ralphrmartin
    • Me
« Reply #1336 on: November 12, 2025, 06:01:27 pm »
Thsi is an unsolicited testimonial for Batronix service. When the AWG came for my Magnova, UPS messed up the delivery (to the UK), repeatedly showing it as coming the next day, only for ir not to arrive. (UPS tracking is pointless, basically just showing "in transit", rather than where the parcel is on its way - not what I would call tracking.) After many days of this, I presumed it was lost in transit.
Batronix promptly shipped a replacement by DHL, which arrived in a timely fashion. I had to pay customs duties on each parcel. Very belatedly, UPS delivered the original shipment, and refused to take any responsibility for the additional customs duties or a  return. Batronix stepped in, and sent me a (DHL) return label, and refunded my customs duties. This was all done in a very friendly and pleasant manner.
I've also been impressed by their responses (on this forum, and to my emails) to requests for additional features / fixes to their Magnova firmware.
And all of this is in the context of a personal purchase (compare this to other equipment manufacturers who now only deal with "non-consumer" customers).
Two thumbs up to Batronix customer service!  :-+ :-+
Offline Christian K
« Reply #1337 on: November 13, 2025, 12:34:13 pm »
I had the same issue...
Problem solved. Thank you for asking and thanks for the replies!
Offline Andre77
    • Batronix
« Reply #1338 on: November 13, 2025, 02:57:08 pm »
Thank you very much for sharing your experience. I’m glad we were able to resolve the UPS delivery issue to your satisfaction. We always strive to be helpful, fair, and accommodating, so it’s great to hear that this came across well.
Speaking of testimonials or reviews - we’ve had lots of great feedback about the Magnova by email, over the phone, and here on the EEVblog (thanks a lot for that!). Still, there are only a few reviews in our online rating tool, especially on our English web pages.
Since there are several Magnova users in this forum, it would be great if some of you could share your experiences with Magnova using our online rating tool. Your feedback helps others get a realistic first impression of the product from actual users. If you want, you can post a review here:
https://www.batronix.com/shop/oscilloscopes/Batronix-Magnova-BMO350.html#yoReviews
As a thank you, we will randomly select two Magnova reviewers at the end of January and send each of them a €250 Batronix voucher. These vouchers can be used for Magnova accessories or other items from our product portfolio.
Just a few quick notes:
- Please only post a review if you actually own a Magnova, so all reviews reflect genuine user experience.
- The draw will, of course, be completely independent of the review content.
- Please use an email address in the review form that you check regularly so that we can contact the winners. Don't worry, your email address will not be displayed publicly.
Online KungFuJosh
  • TEAS is real.
« Reply #1339 on: November 13, 2025, 04:18:43 pm »
I tried leaving a review a moment ago. After submitting it, the review disappeared after refreshing the page. It didn't reappear after confirming the email from yotpo. I think I tried a while ago too. 🤷
All I see is a random review in Portuguese.
Thanks,
Josh
The following users thanked this post: Andre77
Offline Andre77
    • Batronix
« Reply #1340 on: November 13, 2025, 04:58:53 pm »
Thank you very much for your review, Josh! I've just checked and it has been received by our review system. It will take some time for the web pages to be updated. So don’t worry if it doesn’t appear immediately. As for the Portuguese review, it seems that one of our videos was much appreciated.
Online Martin72
« Reply #1341 on: November 13, 2025, 06:26:50 pm »
It's already happened... ;)
Online KungFuJosh
  • TEAS is real.
« Reply #1342 on: November 13, 2025, 06:57:40 pm »
I didn't know you speak Portuguese! ;)
Online Martin72
« Reply #1343 on: November 13, 2025, 08:32:02 pm »
Online KungFuJosh
  • TEAS is real.
« Reply #1344 on: November 13, 2025, 08:50:45 pm »
 :-DD :-DD
Online KungFuJosh
  • TEAS is real.
« Reply #1345 on: November 13, 2025, 08:53:40 pm »
I was playing around with my spectrum analyzer using the Magnova's AWG. This looks good, right?
Thanks,
Josh
Online KungFuJosh
  • TEAS is real.
« Reply #1346 on: November 13, 2025, 08:54:46 pm »
And here's the AWG with 3H, 5H, and 7H waveforms...
Thanks,
Josh
Online Martin72
« Reply #1347 on: November 13, 2025, 09:25:06 pm »
It looks plausible, I think I'll give it a try. ;)
16dB attenuation, 10+6 taken?
Online KungFuJosh
  • TEAS is real.
« Reply #1348 on: November 13, 2025, 09:51:17 pm »
I dunno exactly, I'm sure I hit the auto scale button. ;)
Actual output is 0dBm, and that's what shows on the SA.
Online Gadolinium
« Reply #1349 on: November 16, 2025, 03:33:15 pm »
It sure does look the same here (sine, 0 dBm, 50 Ohm):
2699029-0
« Last Edit: November 16, 2025, 03:37:28 pm by Gadolinium »
