Author Topic: Magnova oscilloscope  (Read 275170 times)
Offline Xyphro
Re: Magnova oscilloscope
« Reply #1425 on: December 16, 2025, 08:56:10 pm »
Do you want me to mark them in a special way such that you know which one relate to MAgnova? For now I created this here:
https://github.com/ngscopeclient/scopehal/issues/1032
Looking for a unique, cheap versatile USB to GPIB adapter with standard USBTMC interface? Build it yourself :-) https://github.com/xyphro/UsbGpib
Too lazy to build one?: https://www.elecrow.com/xyphrolabs-gpibusb.html
Interested in I3C protocol? Check this out: https://github.com/I3CBlaster
The following users thanked this post: Andre77, fredo_
Offline fredo_
« Reply #1426 on: December 16, 2025, 09:59:05 pm »
Thx for the feedback @Xyphro!
If you have more reports, better add them as comments to the Magnova Driver Pull Request here: https://github.com/ngscopeclient/scopehal/pull/1031
The following users thanked this post: Xyphro, Andre77
Offline KungFuJosh
  • TEAS is real.
« Reply #1427 on: December 17, 2025, 12:52:19 am »
I've updated the Batronix Magnova driver for TestController. This version now includes an Other button to execute a QuickSave remotely. Available here.
Thanks,
Josh
Best Continuity Tester Ever
Offline Andre77
    • Batronix
« Reply #1428 on: December 17, 2025, 07:47:18 am »
I think these are great new features, thank you very much for providing the update. However, I would like to reiterate my proposal to add a normalization feature for Bode plots which I already made here. It would be fantastic if you could add that.  :)
Thank you for the reminder and the positive feedback on the firmware update.
The Bode plot normalization that you suggested is a good idea, and it is still on our to-do list. We plan to implement it, but we ask for a bit more patience as it will be included in a future update.
To give you a quick status update on your other suggestions, the "Bode plot cursors" and the "amplitude scale for the generator" have already been implemented. The remaining suggestions, "trigger hysteresis indication" and "set to next peak left/right" for FFT markers, are also good points and are planned for a future update.
The following users thanked this post: rf-messkopf
Offline john74
« Reply #1429 on: December 21, 2025, 11:45:32 am »
@Batronix,
Thx for the firmware update, the new decoding view is very nice.
I am not sure if this was allready meantioned in this thread
but the cursor functions could be improved.
When I try to measure a time difference, the cursors should stick to the actual x-position
during a change of the timescale or during change of the timeOffset.
Lets say I put cursor "A" to -10ms (at a rising-edge of a signal) on a timescale of 10ms/div.
At the moment, when I change the resolution to 20ms/div, the cursor is then at -20ms...10ms away from the rising-edge.
I would prefer that the cursor is moving with respect to the analog channels, also when the offset is changed.
(the same goes for the cursor on the y-axis e.g. to measure a voltage difference)
I am not sure if my explanation is somehow understandable :-)
« Last Edit: December 21, 2025, 11:53:38 am by john74 »
Offline Andre77
    • Batronix
« Reply #1430 on: Yesterday at 09:44:14 am »
Hi John,
Thanks for your feedback on the update and your suggestion about the cursors.
Other users have requested this as well — to have the cursor reference stick to the actual time and voltage values rather than the screen positions. I agree that this would make cursor measurements more practical.
I can’t promise that it will be implemented in the very next update, but it’s already high on our priority list and should be included in one of the upcoming releases.
Offline fredo_
« Reply #1431 on: Yesterday at 01:26:24 pm »
Hello,
I've just published a new build of Ngscopeclient with Magnova driver (Github login required):
- Windows : https://github.com/fredzo/scopehal-apps/actions/runs/20429605897/artifacts/4942554667
- Mac (ARM) : https://github.com/fredzo/scopehal-apps/actions/runs/20429605887/artifacts/4942404333
- Linux (Ubuntu) : https://github.com/fredzo/scopehal-apps/actions/runs/20429605911
This build should fix deadlocks (application freeze) reported by @Xyphro.
It also adresses scope/application Time Scale / Memory Depth / Sample Rate synchronization issues.
Known limitations :
- For now, Magnova's SCPI implementation does not support digital signal acquisition,
- Selecting specific Arbitrary waveform from function generator is not possible either yet.
- Time Scale / Memory Depth / Sample Rate synchronization only work if the scope is in "Extended Capture" mode (Acquire menu).
For the record:
When running ngscopeclient for the first time, you will have to go to “Add>Oscilloscope>Connect…” then give an nickname to the Scope (e.g. “Magnova”), select “magnova” driver, select “lan” transport and set the “Path” to Magnova’s <IP>:5025.
For next launches, just click to “Add>Oscilloscope>Magnova”.
Any feedback / bug report is welcome!
Cheers,
Fredo.
« Last Edit: Yesterday at 04:04:35 pm by fredo_ »
The following users thanked this post: Xyphro, jusaca, Andre77, hotze
Offline Xyphro
« Reply #1432 on: Yesterday at 09:46:07 pm »
Thanks so much Fredo! Will try it out still today, even though tomorrow is approaching soon :-)
Would be cool if ngscopeclient would have a UsbTMC client support too, have so much equipment with USB, but no Ethernet. Maybe time for me to reconsider building a tiny Ethernet/WIFI to UsbTMC bridge once my current project is finished.
« Last Edit: Yesterday at 09:53:24 pm by Xyphro »
Offline Xyphro
« Reply #1433 on: Yesterday at 10:15:54 pm »
DAMN, very sorry, I managed to crash it to unresponsive state within first 30 seconds. Very sorry, this is not to demotivate you :-(
Hope that issue report location is a good one: https://github.com/ngscopeclient/scopehal/pull/1031
As Wireshark can give significant more visibility what is happening, I added a wireshark trace too - from the same session where the ngscopeclient trace was taken with for consistency/correlation.
Packet 5880 is created from me terminating ngscopeclient once it was hanging, so is not part of the issue - see also timestamps.
Protocols like Vxi11 or HiSlip would have means to handle such "lack of response" scenarios gracefully due to having a secondary communication channel active for items like clearing on timeouts, etc... But I think Magnova mainly supports the RAW socket only. I'd be curious to know if the communication could be recovered somehow or if it is really stuck, but as ngscope hangs I cannot test it easily.
Edit: what is the main OS you test with? Would it make sense to test with macos or linux rather than windows? I volunteer for more experiments, you can also PM me. Just not having too much time before end of this year to make own tests with the tcpip raw socket.
« Last Edit: Yesterday at 10:30:46 pm by Xyphro »
The following users thanked this post: fredo_
Offline fredo_
« Reply #1434 on: Yesterday at 11:26:45 pm »
Thanks for the feedback @Xyphro, let's exchange in PR comments not to pollute this topic.
