https://www.chinyoo.com/multimeter-symbols-guide/Every few weeks someone posts a blown fuse or a meter that "just stopped reading" and the root cause is almost always the same: they didn't actually know what the dial position meant. So here's a working engineer's breakdown of the symbols you'll find on a typical handheld DMM, what they actually do, and where people get burned.
V, mV — DC VoltsStraight lines over the V. This is your DC voltage range. On a handheld, mV is usually a separate position or a shifted function. Input impedance is typically 10 MΩ, which is fine for most logic and supply rails but will load high-impedance nodes. If you're probing a reference divider above a few hundred kΩ, know that your meter is part of the circuit.
V~ — AC VoltsWavy line. Most handhelds are averaging or True-RMS. If it doesn't say "True RMS," it's averaging and will lie to you on non-sinusoidal waveforms. Bandwidth is usually 40 Hz–1 kHz on cheap meters; don't try to measure switching noise with it.
A, mA, µA — CurrentThe tricky one. Current is measured in series, and the shunt is internal. On most handhelds, the µA/mA range uses a different jack than the 10 A range, and the 10 A range usually has a separate fuse. Cross the jacks and you'll blow the 10 A fuse or, worse, dump load current through the mA shunt. Also: never measure current across a voltage source. That's a dead short.
Ω — ResistanceTwo-terminal, unpowered measurement. The meter sources a small current and reads the drop. Anything above ~1 MΩ is sensitive to finger contact and probe lead resistance. For low-ohm work, use relative mode or a 4-wire meter.
⏛ / Diode — Diode TestShows forward voltage drop. Typical silicon is 0.5–0.7 V, Schottky 0.2–0.4 V. If it reads OL both ways, the junction is open. If it reads ~0 V both ways, it's shorted.
))) — ContinuityUsually shares the diode position. Beeps below some threshold, often 30–50 Ω. Don't trust it for anything below a few ohms — it's a go/no-go indicator, not a precision measurement.
Hz — FrequencyCounts zero crossings. Works fine on clean digital signals, gets confused by noise and slow edges. Check the meter's trigger threshold before trusting it on a 3.3 V signal.
CAP — CapacitanceHandheld cap meters are slow and inaccurate below ~1 nF. Fine for bulk electrolytics, useless for compensation networks.
°C / °F — TemperatureUsually a K-type thermocouple input. Cold-junction compensation is in the meter, so accuracy depends on the meter's ambient temp. Don't expect better than ±2 °C.
The jacks matter more than the dial.
COM is your reference. VΩmA is the low-energy input. 10A is the high-current input with its own fuse. If you're not sure, start on the highest range and work down. And if you're measuring something you can't afford to short, put the meter on volts first and check the jacks before you even touch the circuit.
Final thought: the symbol guide on the dial is not decoration. Every position has a failure mode. Learn the failure modes and you'll stop blowing fuses.
