Interesting! I wonder how responsive the UI is. If I had to guess, I think it'll be cut-down MDO4000 hardware all around, so probably just as mediocre.
3.9pF passive probes seems a lot lower than Agilent's offering with the MSOX3000 series. The entire spec sheet reads like MSOX3000 +1 (over than the wfm/s).
They support software key bandwidth upgrades, but I'm not sure what to make of this:
Because instruments can be upgraded multiple times, it is important to note the
original model number that is being upgraded, determine the “from” and “to”
bandwidth levels and the product to order.
Are they actually saying that if I go from a 100MHz unit to 200MHz (MDO3BW1T24), then want to go to 500MHz, I need to buy the 100 -> 500 upgrade (MDO3BW1T54)? That seems insane.
As mentioned before, what's the point in having a
Mixed Domain Oscilloscope, if you can't do both simultaneously!?
