@HighVoltage I did a test with a transformer.
I bought the DMM6500 in 2020 and never touched the fuse setting on the backside. It was set to 220V by factory. My mains voltage is at around 235 V.
Since i have a surface microphone and a EA-STT 2000B adjustable transformer, i run a test.
First one with original factory setting (220V) on mains voltage at 235V. Clearly audible humming. It's not anoying me because even the fan of my SLS2 laptop is louder.
I connected the DMM6500 to my EA-STT 2000B, starting at 220V and slowly increased the voltage. At the beginning, the humming was barely audible. At 225V it was increasingly audible. You can see it in the screenshot, after it passes 230V, the humming was nearly at max noise level.
For the last test i set the DMM6500 to 240V on the backside and connected it again to mains voltage at 235V. The humming was barely audible (for me). When powering on, the fan dominates the noise. After the relais clicking, the fan runs a bit faster, it's visible in the screenshoot.
I recorded the humming with audacity.
