Author Topic: new killer scope in town - a true game changer from R&S - RTB2002 & RTB2004  (Read 829167 times)
0 Members and 13 Guests are viewing this topic.
Offline WattSekunde
Looks like at least Farnell Germany might have the app bundle available soon?
http://de.farnell.com/rohde-schwarz/rtb-pk1/software-bundle-oszilloskope/dp/2723131?ost=RTB-PK1.02&selectedCategoryId=&categoryNameResp=Alle&searchView=table&iscrfnonsku=false
Thank's! That looks good. But it's a software only bundle. Better than nothing.
Two days ago I asked R&S about the early adopter bundle for Europe and they are moving the question to some sales office...
The complete bundle (RTB2004 OSCILLOSCOPE 4 CHANNEL, 300MHz PROMOTIONAL PACKAGE) is for 5500,- Euro + VAT. Compare that to $ 2080+VAT in the US?  >:(
http://de.farnell.com/rohde-schwarz/rtb2k-com4-launch-edition/rtb2004-complete-bundle-300-mhz/dp/2723153?categoryId=700000005797&searchView=table&iscrfnonsku=false
And now the "rtb2k-com4-launch-edition" at de.farnell is gone even before there was a unit available :palm: ... Let's hope it come back with a similar price point to the US offers.   :=\
Offline Gabri74
Starting today they are listed by Elpav (Italian distributor):
http://elpav.it/pagina_oscilloscopi.htm
RTB2002 (70MHz 2Ch)            euro 1.250,00
RTBM2004 (70MHz 4Ch)            euro 1.900,00
RTB-221 (up 100MHz 2Ch)    euro 275,00
RTB-222 (up 200MHz 2Ch)    euro 895,00
RTB-223 (up 300MHz 2Ch)    euro 1.700,00
RTB-241 (up 100MHz 4Ch)    euro 225,00
RTB-242 (up 200MHz 4Ch)    euro 745,00
RTB-243 (up 300MHz 2Ch)    euro 1.750,00
RTB-B1 (up to MSO)                    euro 700,00
RTB-B6 (gen. arb. 25MHz)    euro 700,00
No mention of decode options cost  :-//
Offline irakandjii
To: Mike
I watched your teardown and remembered your comments on the beeper.  Turns out you can set the beeper to beep on trigger.
From pg. 181 of the manual, Remote Control Commands
SYSTem:BEEPer:TRIG:STATe
Enables or disables the beep if a trigger occurs.
Parameters:
<TriggerBeep> ON | OFF
I was under the impression that there is a button / menu choice for all commands, but I have no way to test my assumption. yet ^-^
Cheers and thanks again for all your work.
Online mikeselectricstuff
    • Mike's Electric Stuff
To: Mike
Parameters:
This does work, and it is persistent across power cycles, However it's extremely quiet - if you have something next to it with a more noisy fan you can barely hear it. On the plus side you can leave it on and it won't be annoying
Haven't seen it in any menus, and don't think there is a way to enter SCPI on the scope - you can do it via the web interface.
Incidentally I just noticed that interfacing is via USB OR Ethernet, but can't have both enabled at the same time, and it's not smart enough to auto-swap to ethernet if USB is not plugged in.
I did a port scan and looks like HTTP is the only service on Ethernet.
Day Job: Mostly LEDs
The following users thanked this post: edavid, irakandjii
Offline salviador
    • https://www.youtube.com/user/mancio92M
Grazie Grabi!
The following users thanked this post: Gabri74
Offline irakandjii
To: Mike
Parameters:
 :-DD Just wait, some dude will come out with a "hack" that puts a whacking great buzzer on it! (won't be me!) :palm:
Offline JoHr
To: Mike
Parameters:
Nice ... if the beeper is still available. The HMO & RTB series do support a kind of open setup file format which is called  SCP (from SCPI).
This is a simple text file which can be loaded as device setup, e.g.
CHAN1:STAT ON
CHAN2:STAT ON
CHAN1:SCAL 0.5
CHAN2:SCAL 0.5
The law of conservation of bugs states that the total amount of  bugs of an isolated system remains constant. Bugs can neither be created nor destroyed; rather, they can be transformed from one form to another.
Offline JoHr
To: Mike
Parameters:
... :-DD  no need for a "hack" just use the arb gen or the trigger out pulse ...
Offline ebastler
Why would the 4-channel upgrades to 100 or 200 MHz be less expensive than the corresponding 2-channel upgrades??
Or do I have to buy them both, e.g. RTB-222 to upgrade the first 2 channels to 200 MHz, plus RTB-242 to upgrade the other two channels?
Offline NA5WH
That does seem silly.
In the US market, looks like the
100MHz Upgrade is $305 for 2, $250 for 4   ... eh? ....
200MHz upgrade is $790 for 2, $815 for 4.
300MHz upgrade is $1860 for 2, $1915 for 4 ...
Saa..... that is pretty weird.
Offline Lukas
    • carrotIndustries.net
Don't get me wrong, the RTB2000 are perfectly usable scopes, but lack the fun of using the Agilent/Keysight infiniivision scopes. On the dated MSO5000/6000 series, turning the dedicated intensity knob brought up a vu-meter style popup indicating the intensity level. One may believe that the needle and the knob are linked with gears, there's zero lag. The same goes for the timebase knob: Spinning the timebase knob makes you forget that you're operating a DSO, it's as fast as with a good old analog 'scope. Perhaps I'm kinda spoiled, but that's what I expect from DSOs these days. Agilent managed to do it with a PowerPC CPU and an ASIC 10 years ago, so it shouldn't be rocket science today...
Offline TK
I still use my Agilent 54622D scope a lot more than my Rigol MSO2702A.  It boots very fast.  It can trigger CAN, LIN, SPI, i2c, pattern... even USB on CH1, CH2 and any of the 16 digital channels.  It lacks color and serial DECODE, but for a 15 year old scope, it is amazing.  And as Lukas says, the vu-meter intensity indicator works very well.  You can buy used units on eBay for around $250-$300 and they are usually in a good shape.  Digital probe cable is missing on most of these items, but you can get replacements also on eBay for little money.
Offline WattSekunde
These are nearly copies from http://shop.rohde-schwarz.com
The decode options are:
RTB-K1 (I2C/SPI)                   euro 480,-
RTB-K2 (UART/RS232)            euro 480,-
RTB-K3 (CAN/LIN)                  euro 480,-
RTB-K15 (seg.mem & hist.)     euro 700,-
Farnell have/had been some packages:
RTB-PK1 (? ? ? ???)                             euro 1172,-
RTB-COM4 (RTB2004+B243+B1+PK1)  euro 5500,- (It's now gone.  ???)
« Last Edit: March 24, 2017, 05:57:02 pm by WattSekunde »
Offline WattSekunde
I think I go for HMO1212 or Rigol DS4014E (all options free until June 30th) or DSOX1102G if I win one this month ;). The RTB with the needed options is out of my personal range.
« Last Edit: March 24, 2017, 06:44:37 pm by WattSekunde »
Offline Zebble
Ordered from the Canadian site, and the order went through!  Only to get an email today from Newark that the order has been cancelled due to "export restrictions".
Fail #2.
Offline irakandjii
Fail #2.
Oh man that sux ...
Offline Gabri74
Yeeahhh... not in my country  :'(
Buying used equipment outside USA at honest prices seems almost impossible
The following users thanked this post: station240, Frost, Yansi, exe, fonograph, MrBungle
Offline irakandjii
To: Mikeselecticstuff
Would it be possible for you to try setting up the decode to capture very long frame delayed captures?  One (1) protocol packet every x seconds. 0<x<7200+ for example.
I understand the method would be:
1) Select the sample size of the record in memory.  (10k Sa, 13k of them) for instance
2) Set trigger (Frame start)
3) Not sure how you do the next part, to ensure just one capture in a single record
4) Review the records in history
The idea is there could be minutes between each frame / record.  Yet we could look at them contiguously in history, and even save that history to a file.
I trust this is not a bother, and thanks in advance.
 That should be doable with segmented memory. I've not explored that yet.
The following users thanked this post: irakandjii
Offline TK
Trigger Mode: NORMAL
That only gives you the last record. You need segmented to capture multiple records
Offline TK
Sorry, I was answering only question #3.
You need segmented + Trigger Mode in NORMAL.  I don't have the RTB2000 but I tested on the Keysight 1000X series and you can capture up to 50 segments using any delay between one segment to the next.
Offline agdr
    • agdr Audio
WOW - R&S still hasn't sent a review scope to Dave after all this time?
Offline MrBungle
Dave still hasn't reviewed scopes he does have  ;D
The following users thanked this post: thm_w, agdr
Offline agdr
    • agdr Audio
I'm looking forward to Mike's next reviews. Hopefully that test of a 20Hz 400uV sine on high res mode to see if it can do what the HMO1212 did. :)
