Battery celvin clips do not compatiable with gx connectors, used in YR1030 YR1035 RC3563
They are not using the same connector.
As I speculated earlier in this thread. [#15] on the standard used in YR1035.
While YR1030 is using USB-A, while RC3563 (if I recall correctly) are using GX16-4p
So, what model of Kelvin clips did you try with?
Obviously not YR1030, as that one is based on a USB-A-socket (same as DC-YR2050, as I'm cycling Kelvin-clips between those two models)
While the one I speculated could be used was YR1035, and perhaps without any modifications if the pinout matches.
YR1035 =
RC3563 =
YR1030 =
