Author Topic: New Rigol DC Load DL3000 Series  (Read 121287 times)
Offline mrprecision
Re: New Rigol DC Load DL3000 Series
« Reply #200 on: August 27, 2021, 04:35:51 pm »
I have got an answer from Rigol:
Speaking of your question, what the status of the E-load will be when it has a reverse connection, there is a diode in the E-load, and all the loads will not be really disconnected, but if the current is too large (over the current range), then the current will burn the diode.
Thanks for the Rigol support!
Online HKJ
    • Tests
« Reply #201 on: August 27, 2021, 04:46:03 pm »
Sorry for nagging again. What do you need electronic loads for? I never understood that. If I'm a power supply manufacturer, okay.
You are aware that most electronic includes a power supply om some sort? With a load you can test that power supply (including cooling) before the rest of the circuit is ready or without having to drive the circuit into the extremes to check that the power supply can handle it.
It can also be used to test batteries.
Another possibility is to turn any power supply into a constant current source.
In my opinion it is a very useful type of equipment and luckily it is also fairly cheap.
Offline sugenk
  • Country: id
« Reply #202 on: September 10, 2021, 09:18:07 am »
Has anyone flashed the new firmware (1.04 / 1.05) and then tried the battery discharge app? The new firmware broke that feature for me, load wont go above 0.1A regardless of settings. I found 1.02 firmware hosted online and rolled it back, and suddenly it works fine again.
Curious to see if anyone can replicate that or if it's just mine.
Hi all,
I had DL3031A, the HW version 01.00
Already flash the new firmware 00.01.05 and this bug is also happened. Sometimes, the load is wont run. Then need to power off and on again to start normally. Do you have link for old firmware 1.02 ?
Today I just join the forum, to ask help for fixing the PS protection. The INPUT is not working at all. Checking by SCPI command
-> *TST?
<- (Return Count:100)
OppRef:FAILED,VmonTrig:FAILED,ImonTrig:FAILED,OcpRef:FAILED,OvpRef:FAILED,Temp1:FAILED,Temp2:FAILED
-> :STAT:OPER:COND?
<- (Return Count:5)
8192
Think I got big trouble, cause the device is not working right now, since there is no opertion manual to clear this PS protection.
note of DL3000 programming guide in page 1-7, SCPI Status Register, opertion condition is 8192 --> PS  :
Protection Shutdown. When overcurrent, overpower, or overtemperature occurred, the load's input is turned off (protection shutdown).
 |O
Offline electr_peter
  • Country: lt
Re: New Rigol DC Load DL3000 Series, 4.2V ripple check
« Reply #203 on: November 25, 2021, 01:08:35 pm »
I saw that Jerry Walker solved some rebooting issues on RIGOL DP832 power supply. He tracked it down to unstable 4.2V supply for pretty complex processor due to insufficient decoupling - ripple was massive 1-2V P-P. Additional caps solved the issue. 5V regulator overheating due to small heatsink turned out to be secondary issue.
Source: Rigol DP832 Repair Part3 (see parts 4&5 for more detail)
Now, RIGOL DL3000 DC load uses the same processor as DP832 (see screen shots from EEVblog #511 - Rigol DP832 Power Supply Teardown and EEVblog #1023 - Rigol DL3021 Electronic Load Teardown) It also should have 4.2V rail which is important for regulation.
Can anyone with DL3000 check 4.2V rail for ripple just to be sure?
« Last Edit: November 25, 2021, 01:54:06 pm by electr_peter »
  • Country: lt
Re: New Rigol DC Load DL3000 Series, hack to DL3031A
« Reply #204 on: February 14, 2022, 04:01:18 pm »
Forum member confirmed that all models of DL3000 range share the same HW and can be simply hacked to top version (dl3021-to-dl3031-conversion-discussion)
The following users thanked this post: ben_r_
Offline ornea
« Reply #205 on: February 16, 2022, 04:01:42 am »
As has been mentioned, testing batteries a PSU's.
I recently plotted my fully charged mobile phone battery and could clearly see that the battery was at 1/3 capacity so I could eliminate the phone as the cause of poor battery performance.  I tested the phone and observed startup currents  in excess of 1.4amps!!! and thought the phone was suspect so tested the battery.
I regularly test 7Ah batteries that maybe used in UPS's, it removes the guess work.
We use it to test PSU's after repair.  However, it seems that DC loads behave strange when testing PSUs for power up load tests.  Seems we have to resort to resistive loads for those tests.  I think the DC load takes to long to respond and the PSU sees it as excessive current so goes into shutdown
Offline ben_r_
  • A Real Nowhere Man
« Reply #206 on: September 30, 2022, 02:52:56 pm »
Wow, you're kidding. DL3031A for the price of a DL3021!? Well that's all I needed to hear Im in!
If at first you don't succeed, redefine success!
Offline ganevson
  • Country: bg
« Reply #207 on: January 12, 2025, 03:41:51 pm »
Hello colleagues.
My Christmas present was DL3021. I bought it to supplement my laboratory with the range of instruments. At first glance it looks good. The fan needs smart control. It does not need to work when the device is cold.
But I was very disappointed by the extremely underdeveloped computer software. I ask the engineers to work on this issue. I have the feeling that this product was created by students. This is my first contact with Rigol products. The graph on the DL3021 display cannot monitor more than one value at the same time. There is no measurement of the internal resistance of batteries. When I load switching power supplies, I want to know the limit current but also the power with one measurement. For this purpose, in Rigol I have to do a test separately for amperage and separately for watts. I have no indication of how many volts the power supply was at when the OCP and OPP test was completed. There is much to be desired from the device.
Cheap Chinese products like DL24MP have a richer set of tools and parameters and cost under 50usd.
Online HKJ
    • Tests
« Reply #208 on: January 12, 2025, 05:08:47 pm »
Download TestController and try it on the load, it has considerable more functionality.
Thread: https://www.eevblog.com/forum/testgear/program-that-can-log-from-many-multimeters/
Download (Bottom of page): https://lygte-info.dk/project/TestControllerIntro%20UK.html
The following users thanked this post: ganevson
Offline ganevson
  • Country: bg
« Reply #209 on: January 12, 2025, 06:27:44 pm »
Sorry my friend. I don't have COM on my computer and I can't connect it.
Online HKJ
    • Tests
« Reply #210 on: January 12, 2025, 06:48:49 pm »
Then try a LAN connection, it is called socket or LXI in TestController (They are not the same, but both uses LAN).
Offline mcinque
  • I know that I know nothing
« Reply #211 on: January 14, 2025, 09:04:27 pm »
A com can be easily created with a cheap USB to SERIAL converter
Offline ganevson
  • Country: bg
« Reply #212 on: January 14, 2025, 09:08:43 pm »
HKJ Thanks. All wotking perfectly
  • Country: lt
« Reply #213 on: May 29, 2025, 06:55:07 pm »
Be very careful with SHORT button on DL3000 - configuration setting is misleading and display can show 0A with current flowing.
SHORT function can be programmed to be TOGGLE/HOLD/disabled. TOGGLE/HOLD setting is back front (should be HOLD/TOGGLE instead).
When load is ON, enabling SHORT will cause actual short circuit on terminals, display will show actual voltage at the inputs and actual current drawn.
When load is OFF, enabling SHORT will cause actual short circuit on terminals, display will show actual voltage at the inputs and 0A current.
Offline ToThePub
« Reply #214 on: October 24, 2025, 12:12:22 am »
Just for the record:
BTW, the FW contains these Model Types:
00 - DL3021     03 - DL3021A
01 - DL3031     04 - DL3031A
02 - DL3051     05 - DL3051A
  <- it seems this line hasn't seen the light of day
Took a while but Rigol have added another model:
https://rigolna.com/products/dc-power-loads/dl3000/
DL3041    450 Watts   200 Volts   70 Amps   1 channel(s)    $2,099
Not a 3051 but a 3041
Looks like they finally added more MOSFETs to fill the palcehold PCB footprints that were in there empty from the other models.
  • Country: lt
« Reply #215 on: October 24, 2025, 01:44:10 pm »
From pics additional fan on backside is visible. Are you sure additional MOSFETs were added?
Would Rigol fix bugs in DC load with release of DL3041? I am not holding high hopes
« Last Edit: March 07, 2026, 01:00:04 pm by electr_peter »
Offline ToThePub
« Reply #216 on: October 25, 2025, 01:04:30 am »
My "added MOSFETs" comment was pure specialation and an assumption (I should have made that clear).
I don't know what they actually did.
We could only hope they have finally fixed some of the problems.
« Last Edit: October 26, 2025, 07:15:09 am by ToThePub »
Offline tito
  • Country: ar
« Reply #217 on: March 07, 2026, 04:50:03 am »
Hi tv84!!
can you help me with dp712 SN:DP7B252900657
pleaseeeee
thanks
Offline CKaiser
« Reply #218 on: March 10, 2026, 11:27:49 am »
Hello,
Can't find the 1.02 firmware anywhere. Does someone have a backup to share please?
Thnaks in advance.
Offline giovannirat
  • Country: at
« Reply #219 on: March 10, 2026, 09:46:46 pm »
Hope this helps...
The following users thanked this post: core, CKaiser
